Question about Avanti BCAD680 Beverage Cooler
Doesn't defrost... It cools down to the target temperature and then eventually freezes up
The fridge seems to work just find and after a day or two it seems to build up ice and then can no longer cool things and locks up
    Problem Solver:
  • 6 Answers
Please check your airflow around the back of the unit,
these units cannot be built in any way reguardless of the manual saying they can
the need a good inch of air for the compressor to cooldown.
Posted on Nov 06, 2012
5 Suggested Answers
  • 40 Answers
SOURCE: i defrosted the fridge. Took 24 hours! but it won't go back on!
if u press the defrost button of the switch after some time the switch have to come to the original position it would have been stuck due to some problem do press it once more and it would be back to work have a nice day
Posted on Jun 27, 2007
  • 205 Answers
SOURCE: our wine fridge doesnt seem to be cooling properly
it may be as simple as the coils needing cleaned you can buy a can of condeser cleaner at your local hardware store.
Posted on Oct 14, 2009
  • 12650 Answers
SOURCE: fridge not cooling freezer iceing up???
check the fan in back of freezer check or proper running condition not stuck or frozen also make sure not blocked by food the fan takes the air from freezer and blows it down into fridge area to cool it also check for ice build up in the fan housing and thaw as necessary
Posted on Nov 15, 2009
SOURCE: My Avanti wine cooler, model WC3201D, stopped cooling
same problem, can not fix. Had a authorized service tech who said that you can not add freon to this unit, the only option is to plant flowers in it.
Posted on Feb 17, 2010
Fridge won't cool but freezer working fine
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 31, 2011 | Refrigerators
Freezer side seems to work but the refrigerator side isn't
Sep 11, 2011 | Maytag Refrigerators
G,DAY. my fridge which is a hff518w does not get cold in the fridge compartment, the freezer works well.I have tested the fan on the bench and it works well but it wont run when hooked up to the fridge.I...
I think that now that the timer has been opened it needs to be replaced. However the timer doesn't generally shut of just the fan, it's designed to stop the compressor from running and turn on the electric defroster.
Most of the time that a freezer gets cold and the fridge doesn't means that you either have a bad cooling fan or a blockage from ice. A complete defrost will ensure it's not a clog.
Even bench testing the fan is not a full proof test. Usually when you test the fan its in room temperature air and most people test the fan laying down.
The fan operate on very small bearings which are very sensitive to temperature, so testing a fan outside the fridge, you would need to test it in a cold environment and move the fan in multiple directions.
I would suggest that you purchase both a new timer and a new fan.
These items can be purchased at your local appliance dealer or online at applianceparts.com.
Thanks for your question.
Aug 24, 2011 | Refrigerators
Refrigerator doesn't get colder than 55 degrees.
Aug 19, 2011 | Kenmore Refrigerators
Maytag side by side. Coils froze solid, no cooling in fridge or freezer. Replaced heat coil and thermostat assly., as well as adaptive defrost control (circuit brd.). Still don't seem to be able to...
Hi Rob,
The problem in your case is most probably with the defrost thermostat.
It can be found on the evaporator i.e. freezing coils , it's round disc like with two wires.
If you get this replaced with a new proper working unit ,
Also make sure you replace the defrost timer as well if the problem persists.
Hope this helps ..:)
Jun 24, 2011 | Refrigerators
I have a problem with my refrigerator not cooling consistently. It seems like at least once a day it will start warming up but the compressor doesn't come on. When I turn the temp up control nothing...
I believe this is normal behaviour in all auto defrost (which means virtually all modern) fridges. In fact, this short heating period is usually programmed to happen 2 to 3 times a day. You might rightly ask why the refrigerator compartment needs to undergo "defrost" cycles when the compartment is, if the refrigerator is operating correctly, above freezing? The reason is although the compartment is above freezing, its cooling coils are well below freezing temperature, and it's these coils that need the frequent defrosting, before they build up so much frost on them that they "ice up" and no longer allow the fan blown air that cools the refrigerator compartment to pass through them.
Nov 12, 2017 | Kenmore Refrigerators
Kenmore side by side Refrigirator
Sounds like you have a defrost problem. The timer could be playing up and taking too long to defrost, which causes the evaporator to ice up, hence no cold air to the fridge and the water line freezes up, hence no water dispensed. When the timer does eventually defrost the fridge then everything returns to normal. This could also be caused by a faulty defrost terminator or bad connection on the defrost element.
Sep 15, 2007 | Kenmore 50522 / 50524 Side by Side...
Avanti BCAD680 Beverage Cooler Logo
Top Avanti Refrigerators Experts
John Tripp
John Tripp
john h
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
