Question about RCA HD52W56 52" Rear Projection HDTV
The picture looks doubled which fuse to fix it
    Top Expert:
  • RCA Master
  • 14,553 Answers
Set you have listed has all sorts of convergence problems: look first to see if in menu the convergence option is there--if gone there is a 3 piece kit for that.
Also around and under the high voltage transformer this set is known for bad and poor solder connections that cause this problem.
see typical photo of the transformer:
Posted on Nov 06, 2012
PHILIPS 51pp9100d/37, picture is warped ? where do I get the parts i need to fix it ?
If it looks like attached photos it needs both of the convergence IC chips replaced. They should be stk=392=120 OR a few models used the -110 chip.
below is what the parts look like
Jun 15, 2012 | Philips 51PP9100D 51 in. Television
We recently moved the tv and now when we turn it on it has double vision. It kinda looks like a 3d movie. What could be the issue? Is it worth fixing?
If tv picture was fine before moved then check dry/ cold solder joints/ connections on convergence output ICs and nearby circuit area.
Local tv repairman will resolder loose/ dry solder connections to solve double vision picture problem.
TV worth fixing if picture is good.
Thanks.
Feb 18, 2011 | Sony KP-57WV700 57" Rear Projection HDTV
Doubled colors, fuzzy
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 01, 2010 | Philips 60PP9202 60" Rear Projection...
My 65'' Has a red double screen.
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 31, 2010 | Hitachi 65F59 65" HDTV
Picture has ''double vision'' with red.
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • TV shutdown - does not display video
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Red/Orange looking video
You can see some examples and find a fix here...
Feb 20, 2010 | Televison & Video
Picture showing double and color off
There are poor solder connections on the flyback transformer and a small fuse is open. Pretty tough to repair this yourself but any tech can fix this easily.
May 13, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA R52WH74 Picture is sagging, looks 3d, and double picture
Go to menu then setup look for convergence if you do not see convergence then you have A open FUSE It will be on right side of FBT flyback transfomer there is 3 of them in a roll they are small brown rectrangler looking caps but ARE FUSES it will be the one in the middle. Replace it and you have a FIXYA.
Feb 19, 2009 | RCA R52WH73 Projection Television
Unable to resolve concave issues
I am also having the same problem. I tried to replace ICs but no luck. I am also looking for service manual in case if some one can give it to me.
Thanks,
Sanjay
Jun 24, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Zenith Television Big screen
replace the convergence amps and any blown resistors or pico fuse on the board. this is a common problem of rear projection sets this repair is not for the amateur have it done by a pro. the cost of the repair may be around $ 350.00. if you so choose to do the repair yourself, look for the two large ICs on a large heat sink (stk392-xxx).repalce them use heat sink compound on the new ICs and check the resistors around the ICs with a DVOM and check any pico fuses for open.
Mar 02, 2008 | Zenith R56W36 56" Rear Projection...
Double picture
I would look for a lttle hrizontal potentiameter in the horizontal osc circuit.
or your getting hdtv signal now and it cant proscess it .
Feb 01, 2008 | Televison & Video
RCA HD52W56 52" Rear Projection HDTV Logo
14 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
