Question about Olympus EVOLT E-500 Digital Camera
Card slot door will suddenly not close - eject button sticks out
When I push the CF card slot in the eject button pops out and blocks the card slot door from closing. I've used the camera for 2 years - this is a sudden problem.
  • 3 Answers
Push the button down after!! :P mine does the same push the card in the button comes up then push the button down!! should fix teh problem :)
Posted on Mar 04, 2009
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
Repair issue
Posted on Feb 18, 2009
How do I load the tape
I see your picture of a cassette player. Guess you are referring to that. (tapes also come in reel-to-reel, and 8-track). Just push the "EJECT" button (power may need to be applied to some units for the eject button to work). The tape slot will open. Insert tape with exposed tape on the "head" side of the opening, usually the heads are on the bottom of the slot.. You can't put it in any other way and have the door close. The "door" that opens has guides for you to slide the tape into. The side you want to listen to should face you. Either manually close the tape compartment or push the close button (depending on model). If the door doesn't close, you put it in upside down. Push play and enjoy.
Oct 01, 2014 | Audio Players & Recorders
I closed camra without memory card in, now I cannot put card in as spring has not returned up.
I'm sorry for the difficulties you're experiencing in inserting the CF Card in the Memory Card slot on the Camera. Based on the information you have provided, it appears that the spring in the slot which gives pressure for the card is not working as expected. Please check the below picture and insert the card as shown in the figure even if the CF card eject button fully extend to resolve the issue. Close the door firmly after putting the Card in the slot.
Thanks for understanding. Please let me know if you require any clarifications.
Aug 13, 2011 | Canon PowerShot S60 Digital Camera
How can i switch to a memory card?
Most digital cameras use either a secure digital (SD), compact flash (CF), memory stick, multi-media cards or XDcards.
Step 1: Power the camera off and determine what type of card your camera uses. You can check the owners manual, go to the manufacturer's site, or look on the camera to find out what card you use.
This is a picture of an "SD" card in a Digital Camera.
Step 2: Insert the memory card into the camera by locating the memory card slot on the bottom or side of the camera body. Open the memory card door by using an "Eject" button or sliding the panel to the side. Insert the memory card as advised by the icon on the inside of the door. Close the door and turn the camera on.
Step 3: Format the memory card for the camera. Many digital cameras will do this for you once the memory card in inserted and the camera is powered on. On some cameras you can do this manually:
Press your camera's "Menu" button, select "Tools," and find the "Format" feature. Select "Format" and press "OK" or "Set" to format the memory card. Press the shutter button to exit "Menu" mode.
To remove the memory card, open the camera as you were able to in Step 2. Then press the end of the card in and release. The card will slide out of the camera.
Some accessories may be required to transfer media to your computer. There may already be a slot in your computer for the card, if not, an SD to usb kit can be purchased online or from a local electronics vendor for a reasonable price.
May 05, 2011 | Cameras
Canon Si5 Lens Error message. Have tried suggestions on line
Welcome to FixYa.
There where wo reasons why do you receive a "lens error".
1. CF card slot cover or battery cover opened with camera on
2 . CF card slot cover or battery cover opened while camera was recording to CF card
In this case you have to ensure that CF card cover and battery cover is closed while camera is turn on.
You also need to be careful not to block the camera lens when turning on. Lens will have issues while retracting if your hands or even small thing that will block the lens to retrack while in motion of turning on.
Thank you for using FixYa.
Apr 08, 2011 | Cameras
I have a memory stick in my printer and can't get it out. How do I eject the stick? I have a HP Photosmart C3100 all-in-one. I had this happen yesterday and am afraid to try most things tho' I did put...
I think you are talking about the Memory Card (Memory Stick). Hope you installed it with the adapter. If there's no problem with the slot or with the pins inside the slot, it should pop out when it's pushed in with a "click" sound. Push the memory card and release, it will be ejected. But if there's problem, you'll need a pair of tweezers to pull it out. It will not be able to easily pulled out, hold it very tight and push in once and then pull out, it should come out.
If a pin or few pins are bent or twisted, it should be done by a technician or by a pro, otherwise you may damage the card.
This is all what I could suggest you about this. I wish you good luck.
Thanks for using FixYa.
Dec 05, 2010 | HP Photosmart C3100 series
The nexlink CL51 has a small button that you depress to eject a plastic card. How do you keep the button from sticking out?
After you eject the PCMCIA card you can push the button in until it clicks and stays in. Now you insert your PCMCIA card into the slot and if you want to eject the card you push the button and it will pop out then press the button to eject the card.
If this pressing the button in doesn't lock the button in place, then the spring catch on the button is broken.
Jul 08, 2009 | Computers & Internet
Same as others. DVD stuck..won't play, won't eject
I use a produce bag tie. Stick it in the bottom of the dvd slot after pushing the eject button and the disc pops out for me.
Jun 10, 2009 | Mintek LCD TV Progressive Scan DVD Player
CF card slot cover
Is the card inserted correctly?
Is the card release button- under the cover locked down?
This needs two pushed to get it to lock in.
Oct 16, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Card Eject Button Not Working
I hgave the came camera it does take two pushes to get it to lock down - just a quirk I guess
Jul 30, 2007 | Olympus EVOLT E-300 Digital Camera
Canon A310 Won't Power Up.
Try checking this... on the battery door (the outside door) along the top edge (over the CF card pointer embossed in the back of the door) you should see a little plastic piece that pokes out... tis is supposed to push a small switch located in a slot over the battery compartment. It's the sensor that tells if the battery door is open or closed.. if the plastic part breaks off or gets chipped it wont push the button and the camera will not turn on when the shutter door is opened.
Jun 09, 2007 | Canon PowerShot A310 Digital Camera
Olympus EVOLT E-500 Digital Camera Logo
159 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
