The picture on my television looks like everything is doubled
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
If projection set likely a convergence problem--no brand or model here?
Posted on Nov 06, 2012
Overlap pictures
If picture is 3d looking it sounds like a convergence problem.
See attached photo--look at all like your trouble?
If so, let me know and tell me brand/model and I will tell you what is needed.
Mar 16, 2012 | Televison & Video
HAVE DOUBLE PICTURE
Double picture can happen for two reasons. Is it double on TV/Cable or double on all inputs. If it is the TV, try a different input. If it is double on everything you tv is defective and/or broken.
Jan 22, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Images on screen are doubled. Everything
u have bad convergence ic stk392-110 or stk392-150
Apr 13, 2010 | Hitachi 53UWX10B 53" Rear Projection...
We have a KP-51ws510.the TV has double lettering in normal color and in red. It looks like the lettering is not in sync.its doubled and the picture is slightly blurry.The whole picture looks out of sync....
You have defective convergence ICs which need to be replaced. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains this, how to perform the swap and where to get the parts. Let me know if you need more help. Thanks for using FixYa and for the generous rating.
hardrocko
Mar 22, 2010 | Sony KP-41T65 41" Rear Projection...
EVERYTHING IN WRITING IS DOUBLE AND THE PICTURE IS DISTORTED
Hello Tim this is a very common problem with the projection tv set, the problem is coming from the convergence board with faulty ICs that have to replaced in order for your tv set picture to work properly,they do sell convergence repair kits for your tv set but i would not recommend this the reason being is that if you make a mistake while changing out a component your whole tv set is gone not going to work anymore so for this i would recommend for you to call a near by tv repair shop and have a tech come out and change this ICs for you, after you change this ICs from the convergence board your tv set should go back to working normal on the link below you can check out how a convergence board looks like thank you hope this helps.
http://bestbuy.partsearch.com/content/pages/tv-convergence-boards.html
Aug 29, 2009 | Sony KP-46WT500 46" Rear Projection...
Pictures and letters have a double image.
Getting into the "convergence" menu should help with this issue.
Feb 23, 2009 | Toshiba TZ50V51 50" Rear Projection...
TV PROBLEMS
If the images are different colors (red,green,blue) then the convergence has diverged. Some TV allow re-convergence through the menu screen, older sets my need to be physically adjusted (aimed) to clear this up. a strong knock to the TV may have cause this.
Apr 21, 2008 | JVC AV-56WP74 56" Rear Projection...
Distorted picture
On the middle circuit board towards rear is a metal wavy plate.On the back side(actually towards screen when looking from rear of unit),the middle screw has a ground wire(light brown) that is loose.
Apr 08, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Samsung Hc-p4752e - Double Picture
Dane,
The convergence amps most likely failed. That unit takes two STK392-010 amps and the most likely cause for their failure are one or more of the 3.9 ohm 1/2watt resistors out in front of the Ic's which have opened or changed in value. There are several of them too, Rz142,143,146,147,144,145,123,124,125,126,127 and 128 and do check them all...
Bill
Nov 24, 2007 | Samsung HC-P4752W 47" Rear Projection...
Double Picture
Goto menu and look for convergence control and realign colors.
Sep 22, 2007 | Hitachi 57G500 57" TV
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
