Question about Sony Ericsson P1i
Display cannt reduce to 90 % brightness
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} I Update Service on my computer when finish I do the procedure in the manual remove the battery then put the usb cable then press c ...so my wifi internet become weak..and disconected ..then i open my cellphone the
display is always at almost full bright even i save it to dimmed at 50 %.When i save to dimmed 50% in return to 90% bright.
thanks . Mr. louie
    Sergeant:
  • 431 Answers
Try formatting the phone
Posted on Jan 09, 2009
How to reduce brightness of dell vostro 1015
not sure if this will help you...
  1. Bright LCD displays under low-light conditions can strain the eyes. ...
  2. Hold the "Fn" key and press the up or down arrows to increase or reduce brightness on most Dell laptops. ...
  3. Right-click the power icon in your Windows 7 system tray and select "Adjust Screen Brightness."
How to Adjust Dell Laptop Screen Brightness ' Chron.com
smallbusiness.chron.com/adjust-dell-laptop-screen-brightness-53143.html...or try this link. How to reduce brightness of dell vostro 1015 Google Search
Oct 21, 2017 | Dell Computers & Internet
Brightness screen fn
Many computer users spend long hours online every day and don\'t realize that looking at a bright laptop screen can be hard for the eyes. If you spend a lot of time in front of a laptop screen, consider reducing the brightness of the screen at the earliest opportunity. There\'s a quick and easy way to perform this task so you can save your eyes as well as your battery power.
Press and hold the "Fn" key on the laptop keyboard. T his key is usually located at the top right or bottom left of the keyboard. Press the "Up Arrow" and "Down Arrow" keys, which are usually located in the lower right of the keyboard, to increase or reduce the brightness of your laptop screen. Adjust the level so that you can gaze comfortably at the screen without any glare. Disconnect the battery charger from your laptop and repeat the above procedure. On some laptops, the screen brightness varies considerably, depending on whether or not the device is charged.
Jan 31, 2013 | Dell Inspiron Computers & Internet
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.)
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor.
Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
Brightness and contrast symbols
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
Dear Sir, I am having dell vostro 1510, from the past few days when i put on my ac adopter the battery indicator lights gets on but suddenly after 3-5 sec it get off again.I am not able to charge my...
You either have a faulty a/c connection and need to buy a new one at any common electronics store, or your battery cannot hold a charge.
Factors affecting battery:
Mar 29, 2011 | Dell Vostro 1510 Laptop
What do I use to hook my gps to the pc, to update it
You will need a USB cable to make this connection.
Any USB generic charger will work. I used on my Garmin the Motorola cellphone USB cable.
The procedure is like this:
Connect, start Garmin Nuvi and disconnect; then reinsert the USB plug when your Nuvi model number is displayed at the bottom of the screen. You can even charge your Garmin this way. To reduce the charging time follow these steps:
# change the display brightness to less than 25%
# turn off the Garmin device.
Mar 04, 2011 | Garmin nuvi 255W GPS Receiver
I would like to reduce brightness on my ASUS VH242H
Actually, the problem isn't with the drivers. Right click on the battery icon in your system tray. Select "Power Options" (NOT Power4Gear eXtreme). On the right panel, select "Adjust the display brightness." Then, select "Change advanced power settings." Scroll down and open up the "Display" box. The options that are affecting your screen brightness on battery are "Allow SmartDimmer to reduce my brightness after," "Have SmartDimmer reduce my brightness by," and "SmartDimmer full-screen video mode." Playing with the percentages in these boxes will affect how your screen brightness adjusts itself. To get my screen to stop re-brightening itself, I changed "Allow SmartDimmer to reduce my brightness after/ On Battery:" to 100%. I then changed "Have SmartDimmer reduce my brightness by/ On battery:" to 0%. Finally, I set "SmartDimmer full-screen video mode/ On battery:" to Maximum Power Saving. This should solve your screen-rebrightening problems even with the 163.44 drivers (I use those too). Please Rate.
Thanks, Anand Fixya
Dec 23, 2010 | ASUS VW193T Monitor
I have bought a dell vostro 1015n and installed the windows 7 ultimate 32-bit operating system .. but when i play the video the colours are not good and the picture is too bright.... what can i do... is it...
The possible reason could be the VGA (Display) Drivers. Right Click My Computer and go to Properties - then Device Manager. Look for VGA Display Adapters (Drivers) in the list. Right Click the Display Adaptor and Choose update Drivers automatically. This will update the Drivers automatically from windows update and install the latest compatible drivers.
Secondly, you can adjust the brightness by Pressing and holding the Fn Key (Bottom left) and pressing the Arrow Down Key to reduce brightness and Arrow up Key for increasing brightness.
Let me know if any further clarification/ assistance is required.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 13, 2010 | Dell Vostro 1510 Laptop
I hav SE w705.when ever i download any theme the menu icons dont change so im lukin for a theme that will change my menu icon .pls help
You should need to unlock your phone and install some specific software to modify your phonev4ndre_5.jpg there is some programs and special firmwares to reflash your cell phone, but the procedure is very dangerous, do it at your own risk...
1. Download the SEUS (Sony Ericsson Update Service) program from the main SE page. (Navigate to your phone model and download "Update Service" program at the download section.
2. After downloading the SEUS (Sony Ericsson Update Service. I will write only SEUS in the rows below) you need to make your computer ready for the update process by installing USB flash drivers for your phone. These USB drivers are not the sandard ones and it's installation is a bit different comparing to the standard ones. So to install USB flash drivers (I hope you're using Windows XP) the procedure is the folowing:
- Turn off the phone;
- Remove the battery;
- Remove the Sim card;
- Place the battery in the phone again;
- While your phone is turned off connect it to your computer via the USB cable holding the C button on the phone pressed down all the time. (Tips: "Do not release the C button until you're prompted to do it" , "REMOVE the SIM card from the phone before starting the update process" , " Keep your phone turned off when connecting it to the computer holding the C button pressed down")
- Your computer will recognize the phone now as new hardware (USB Flash Device) and then you will need to install the USB Flash Drivers for your phone. Follow the Windows new hardware wizard. It will prompt you to insert the CD for your new hardware. The flash USB drivers are in the PC Suite CD you got when you bought the phone.
- After the Drivers setup is finished successfully, plug out the phone from the cable and restart your computer. Restarting is recommended, so do not try to start the update procedure without restart.
3. The next thing you have to do is to install the SEUS program you downloaded from the main SE website (the link above). It's setup is easy and it will install in a couple of minutes. After SEUS program is installed, restart the computer again.
4. Now you can start the update process for your phone. If everything is OK it should be like this:
- First I would like to recommend you to not start the update process if you have very slow or unstable internet connection, because the new software for the phone is downloded directly from the Internet and it does not have to be interrupted with anything;
- Quit your all running programs (This is recommended if you have antivirus or firewall software which blocks the network activity of untrusted applications. If you have one like this, give the SEUS program unlimited permision to access the web anytime it needs. Or the best, turn off that software.);
- Start the SEUS program you installed;
- Then you need to follow the instructions from the wizard;
- When asked, turn off the phone;
- Remove the SIM card'
- Connect it to the computer holding the C button (Tip: Release the C button only when you are prompted to do that. Releasing the C button earlier than it need to be will interrupt the update process so you can kill your phone. Some computers won't prompt for release the C button so you can release it when the updating procedure is started.);
- Then you will see an animated picture of some gray phone connected to computer via the USB cable. In this step you can release the C button and wait while the wizard is downloading the new software for your phone and installing it. You can see the status of the flashing procedure in the screen on that gray phone on the picture. Its display will start to fill with green from the bottom to the top of the screen;
- When done the updating procedure, click the update process you will be prompted to plug out your phone from the computer and close the wizard. With that, the update procedure is successfully completed;
5. Now you'll need to see the success of your work by Turning the phone on, but when you finish the update procedure do not remove the battery to insert the SIM card. Try to turn the phone on when you plug it off the computer. Keep the power on button pressed down for some time. It won't turn on fast as usual. If it does not turn on, remove the battery then. Insert the SIM card. Let the battery out for 2-3 minutes and try turning it on again. If the update procedure is made as it needs to be, the phone will surely turn on (but not fast as usual, but it is only for the first time.).
Dec 06, 2010 | Sony Ericsson Cell Phones
Cannt show display 1100 pls help me?
A hard reset involves physically removing the battery from the smartphone and then reinserting it.To perform a hard reset, complete the following steps:
1) Remove the battery cover from the back of the BlackBerry smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
Still if it is not working kindly walk into the service center, because this might be a Hardware issue.
I hope I was able to help you.
Thank you for using Fixya.
Sep 18, 2009 | Nokia 1110 Cellular Phone
I cannt see anything on screen
U MAY BE BLIND!!!!!!! SOORRY .I WAS JOKING.DO U HAVE ANY LCD MONITOR?CRT MONITOR WILL ALSO DO.CONNECT THE VGA CABLE (CABLE WHICH WE CONNECT TO THE CPU OF UR PERSONAL COMPUTER)TO THE VGA PORT OF THE LAPTOP(IT WILL BE IN THE LEFT SIDE TOP CORNER OF THE LAPTOP)AND SWITCH IT ON.CHECK WEATHER THE DISPLAY IS COMING OR NOT.IF YES THE DISPLAY WILL BE BAD (LCD DISPLAY OF THE LAPTOP).IF NOT RAM OR MOTHERBOARD WILL BE BAD.FOR EITHER SITUATION ITS BETTER TO TAKE THE LAPTOP TO ANY NEAR BY AUTHERSISED SERVICE CENTER.SECOND PROCEDURE MAY RUIN UR WARRANTY OF THE MEACHINE.U HAVE 2 REMOVE UR RAM AND CLEAN THE RAM THEN REINSERT THE RAM IN POSITION.IF U WANT 2 KNOW MORE .PLEASE CONTACT THROUGN MY MAIL.
Jun 17, 2009 | HP Pavilion dv6000z Notebook
Sony Ericsson P1i Logo
309 people viewed this question
Top Sony Ericsson Computers & Internet Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
