Question about Maytag Washing Machines
Maytag MFW9600 wont drain or unlock - Maytag Washing Machines
    Top Expert:
  • Maytag Master
  • 9,472 Answers
You will need to check the drain filter for any blockage. If this is clear you will need to replace the CCU. Here is the part to order.
Posted on Nov 06, 2012
Testimonial: "Thats exactly what it was. It was clogged with many many things. Needless to say I am $9.02 richer because of it. Very easy to fix. "
  • Richard Roth
    Richard Roth Nov 06, 2012
    I am glad I was able to help! Thanks for using FixYa!
Ou Maytag Neptune Washer MAH-3 will not drain.
This problem was answered a couple of years ago in detail. A search should produce it. Search the name Scruggs.
Sep 02, 2014 | Maytag Neptune MAH5500B Front Load Washer
I have a Maytag front load washer. The washer will not drain and the door will not unlock. All of the power sources and hoses have been checked, is there a way to manually unlock it?
If you have a wet dry shop vac you can use it. Connect it to the end of the drain hose and remove the water that way and the door should unlock.
Once the water is gone you will need to check the drain pump and hoses for anykind of obstructions.
Jan 02, 2011 | Maytag Neptune MAH5500B Front Load Washer
My maytag washer mah-24 have a "nd" msg. which mean "not draining" and now i cannot open the door to take the clothes out. pls. help.
Unlocking the door:
Turn on the washer, but don't start any wash cycles. After a few minutes, the door should unlock itself.
Troubleshooting the "nd" message:
"nd" means "no drain". Empty the (now unlocked) washer and fill the wash tub with just enough water to see a bit of water at the bottom of the tub. Run a drain cycle and check a) if it drains and b) if there are any unusual noises while it is draining. If either event occurs during the drain cycle, the drain pump may have to be repaired/replaced.
Nov 25, 2010 | Maytag MAH2400A Front Load Washer
Wont drain or unlock door
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 20, 2010 | Maytag MAH6700AWW Neptune Front-Load...
I have a Maytag washer model #9600eww on spin cycle it won't spin fast, when finished clothes still wet.
The belt is sliping on spin if not to bad it can be tighten up. but it won't last long. Replace it.
Ken
Sep 22, 2009 | Washing Machines
Maytag neptune too much water, will not drain, door won't unlock
you may have something stuck in the pump a sock or a dish towel something small. you will have to get to the pump,,,thats why it wont drain or spin out it cant.
Jan 22, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Wont drain,spin,or agitate
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
Dec 27, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
226 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
