Question about Tascam CD-A500 CD Player
What is cl05 error on tascam cd-a500 - Tascam CD-A500 CD Player
4 Suggested Answers
SOURCE: Tascam CD-A500 'no disk' problem
How hard is it to replace optical lens on the Tascam CD-A500?
Posted on Oct 14, 2008
gothtaz
  • 3 Answers
SOURCE: tASCOM cd a500 - DOES NOT READ DISC
There is one of two things that is wrong with it..
1 the laser lens is dirty and needs to be cleaned witch you can fine a laser lens cleaner at your local radio shack.
2 the laser lens could have been bumped off the track so is that is the case you will have to poen it up and use something soft like a Que tip and gently nudge it.
Posted on Oct 16, 2008
SOURCE: Tascam CD A500 'No Disc' error message
It's probably not the lens. Try turning on it's right side and cycle the power switch with a CD in the tray. Betcha it starts. The little vinyl gear has stripped. I'm looking for one right now and will let you know a P/N when I find it.
Posted on Feb 15, 2009
Tascam cd -rw 900 sl wont play cd burnt from my laptop
Make sure you are burning the audio files in a format it can read. The standered is Mp3, but some times you need to burn them in other formats.
Apr 05, 2014 | Tascam CD-A500 CD Player
Hi, I have a Tascam CD-A500 combo CDplayer/cassette recorder. The CD player has started skipping with very minimal vibration. This is new and never had these problems before. It is the most sensitive when...
Laser assembly is losing its ability to properly focus on the disk surface. It is going to La La land and needs to be replaced.
Get another player since repair is not cost effective.
Mar 19, 2017 | Tascam CD-A500 CD Player
Drawer keeps ejecting as soon as you close it
make sure you have nothing jammed in the drive, somthing may have been dropped behind the drive.
Dec 10, 2009 | Tascam CD-A500 CD Player
CD player does not recognise some CDs. When placed in the drawer the deck displays "no disc" if another CD player is used the disc works fine
I have two of these Tascam CD-A500 players, and one more than the other has this problem of not reading some CDs that will play fine in other players. I'm starting to loose faith in this Tascam product. Anyway, seems the consensus is to open it up and check for dirty laser optics. If that doesn't fix the problem, then send it in for repair or scrap it and buy a different brand. I've not had this problem with any other brand CD player, but very suspicious that the same problem happens on BOTH of my Tascam CD-A500 units.
Nov 15, 2009 | Tascam CD-A500 CD Player
TASCAM CD-A500 - No Volum Control Switch
You control the volume by the amplifier or receiver that you plugged the tascam into. The only volume control on the tascam appears to be for headphones, the other volume control is for recording gain input.
Jan 30, 2009 | Tascam CDa500 CD/Cassette Combination...
TASCOM cd a500 - DOES NOT READ DISC
Oct 15, 2008 | Tascam CD-A500 CD Player
Cd player reads disc error
maybe you need to change the optical eye now.
but first try to adjust the variable resistor/trimpot resistor.
try this options to your player.
(TIP)
if using a cd/vcd/dvd products, we only should play a cd/vcd/dvd dics without a bad scratches. the scratches are making the optical eye worn-out easily.
Jan 28, 2008 | Tascam CD-A500 CD Player
try to listen to sound inside if the any motor is working through the disc tray. then try to open it (if you want though) then observe it.
after that if the motors are ok, try to adjust your optical lens variable risistor.
note if the optical lens is not emitting a red light your optical lens is the problem, changing it is the only solution.
Dec 24, 2007 | Tascam CD-A500 CD Player
CD stuck in CD-A500 drive
take off the cd tray and take the cover off.
is it for laptop or pc?
if for laptop you'll find the bolt inside the hard drive or at the ddr memory.
be careful, not to damage the optical lens.
Nov 14, 2006 | Tascam CD-A500 CD Player
Tascam CD-A500 CD Player Logo
99 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
