Wht kind of current comes out? - Computers & Internet
  • Fernando Gomes
    Fernando Gomes Nov 08, 2012
    Thank you for you help, but what I am trying to know is which wires are going to give me 12 volts.
  • Computers & ... Master
  • 5,660 Answers
Voltage;
Input voltage into the Power Supply of the computer is AC Voltage.
100, or 120, or 220, or 240 Volts; depending on what country you are in.
Output voltage coming out of the Power Supply is divided, into three main power rails;
A) 3.3 Volt
B) 5 Volt
C) 12 Volt
ALL are DC Voltage.
In comparison two D cell batteries store 3 Volts DC.
The Power Supply in your computer converts dangerous high AC Voltage, into three low DC voltages.
AC voltage is rectified into DC voltage.
The dangerous voltages are contained in the metal case, of the Power Supply.
Current = Amperage.
Current is measured in Amperage.
http://en.wikipedia.org/wiki/Amperage
To know the rated current of each Voltage power rail, look at the chart on the Power Supply's case.
Across the top usually are listed the voltage power rails.
Look down from 3.3V+, 5V+, and 12V+
Forget about the Negative values; 3.3V-, 5V-, and 12V-
If more than one 12 Volt power rail is listed, ADD all 12 Volt power rail Amperage together.
Example;
12V1 - 20A
12V2 - 22A
42 Amp's on the 12 Volt power rail.
Add all power rails amperage together, (3.3V+, 5V+, 12V+), and multiply times the input voltage, to come up with the actual rated maximum Wattage.
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Nov 06, 2012
  • joecoolvette
    joecoolvette Nov 08, 2012
    Then you weren't asking about Current, or Amperage; you were asking about Voltage, and color coding of the wires. Orange is 3.3 Volts DC. Red is 5 Volts DC. Yellow is 12 Volts DC. ALL Black wires are Ground wires. ALL Black wires are NEGATIVE wires. The computer uses a DC circuit. With a DC circuit there is a Positive, and a Negative. ALL power wires, (3.3 Volts, 5 Volts, and 12 Volts), are Positive wires. 1)http://en.wikipedia.org/wiki/Computer_po... 2)http://www.playtool.com/pages/psuconnect...
  • joecoolvette
    Crude example; Using a garden hose and water. Voltage is the size of the opening of the garden hose. What size stream comes out, you might say. Amperage, or Current, is how many gallons per minute come out of the garden hose. Voltage times Amperage = Watts.
  • 32,281 Answers
The computer's switch mode power supply produces DC (direct current) electricity.
  • Chris Hingee
    Chris Hingee Nov 09, 2012
    On the power connector that has 4 wires, Yellow wire is +12 volts and the black is the 0 volts (ground) Red wire is +5 volts and the black is the 0 volts (ground).
Upon starting the machine, this message is coming up. Kindly advise what is the problem and how to solve it. The processor is film processor by Agfa an online avantra30 processor
i think u should clean box container of the solution from time to time
try to remove the existent solution now and clean everything and then make new solution and send me back wht happen
Feb 17, 2013 | Photography
Wht version of BIOS is currently being used used on a toshiba satellite C655-S5132
@hursey_micha
The current version of the BIOS for the Toshiba C655-S5132 is v1.60. You can find more information at https://support.toshiba.com or just click here.
Cheers,
Sep 06, 2011 | Toshiba Satellite Laptop / Intel Celeron...
My moto rocker E6 has not any sound coming from it.
please whether your speakers are serviceable. if are able to hear when u are in a call then probably only ur loud speaker got unserviceable
Feb 23, 2010 | Motorola Mobility ROKR E8 Cellular Phone
I wired up the the Fridgedaire wall oven and it worked for two days and then just shut off. It has a green, white, black and red. The white and green are taped together coming out of the oven. The...
the unit is 240 volts not 120 volts/its ok to have the wht and green tied together so long as it comes directly from the house main panel/new law in some places require them to be separate/wht=Neutral/Green=safety grd to case...now how many watts does this unit draw? 2/12 wires sound awful small for the input current/sounds like you need to upgrade to atleast 2#6 wires for power/1#8 for neutral and atleast a #10 for safety ground
Sep 30, 2009 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
52in nassau indoor/outdoor fan 129-909 floor model no instr
white definately goes to white. however you configure the red, black and blues will only determine which switch on the wall controls the fan or light. as for the bare copper, the fans typically come from the factory with a green pigtail screwed into the top of the downrod
I’m happy to assist further over the phone at https://www.6ya.com/expert/jerry_612d8419f8984578
Aug 17, 2009 | Hampton Bay 24002 Ceiling Fan
My computer mother board model number is aad28751-402
come with more qwestions about wath kind of card or you want to now the driver for it i do need brand name for your motherboard
ben.pluijm@viveole.com
Jul 01, 2009 | Computers & Internet
New vr-3 going into used 2004 Status. Current wiring has black connector and grey connector, also one blk/yellow stripe wire. Have wire colors written down, need to know what existing wires are -new radio...
According to www.the12volt.com The color codes for your vehicle are:
RADIO 12V CONSTANT |orange/black
RADIO SWITCH (ACC)|white/black
RADIO ILLUMINATE|green/white
LF SPEAKER|wht/blu - blk/blu
RF SPEAKER|wht/red - blk/red
LR SPEAKER|yel/blu - gry/blu
RR SPEAKER|yel/red - gry/red
Feb 24, 2009 | Clarion VRX935VD Car DVD Player
Bench Test explorer 1998 rear wiper motor
power is wht/or & blk/blu. to make the wiper move both left and right across window, it alternates positive and negative polarity.
Jul 14, 2008 | 1998 Ford Explorer
Wire diagram
guynoir..with alpine your other set of speakers would most likely run through an amp ,which may connect up by the rca leads or a din plug , this is where your fader comes in to play.i was an agent for alpine
Feb 07, 2008 | Car Audio & Video
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
