Color is blue on samsung lcd tv
Color will nor reset only good sound
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Try with a DVD connected to a rear input to see if same issue and or disconnect set and or box from power for a short time.
Posted on Nov 06, 2012
moto34
  • 155 Answers
SOURCE: Samsung LCD Tv
Try this:
Access menu service by press on your command, with your TV OFF:
INFO + MENU + MUTE + POWER ON
Then you should get access to Service Menu.
The last item says: RESET
This will do a reset to the TV.
Make no harm.
WARNING: If when on service menu you feel tempted to "screw" on anything FIRST take note on ALL you change! You can compromise the TV ...
Posted on May 03, 2008
ProMonkey
  • 59 Answers
SOURCE: colored vertical lines with sound no picture
im afraid to say that your display has gone the best thing you can do is call the supplyer of the tv if its under warranty or call samsung. the cost of a new display will be 400 - 500 pounds so you may have to buy a new set.
Posted on Mar 10, 2009
  • 41 Answers
SOURCE: sound problems
Sounds like there is a bad solder connection inside the set and needs to be looked at by a tech. The Flashing LED usually will be a code for the tech to send him in the right direction as to the problem. Try counting how many times it flashes and call them or manurfacture. hope this helps
Posted on Apr 01, 2009
SOURCE: have red blue vertical lines on samsung lcd tv
Oh ok
Posted on Feb 09, 2010
  • 11 Answers
SOURCE: samsung tv has no sound
Not that I'm aware of, but it is not that had to tear down the tv and replace them. Just 6 or 7 screw and and carefull pry the rear panel off. Then it is as simple as unplugging the speakers from the main pcb and replacing them.
Posted on Mar 08, 2010
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
Color problems vizio lcd hdtv
If your tv has a custom settings area, first turn all color down on set so picture looks black and white. Now in color settings look for red blue and green color bars. Use the bars until the picture looks as true to black and white as possible. Also, try changing color temp.
Dec 21, 2013 | Vizio VW37L 37 in. LCD HDTV
Samsung ln52a750
there are several things that can cause this, is the screen blue? white? Colored lines?
May 05, 2013 | Samsung LN52A750 52" HDTV LCD TV
Have samsung 40inch lcd colour no good on ext 1 and 2 but on hdmi via virgin fine want to play dvd but no good on ext 1 and 2 will new hdmi dvd be ok via hdmi cable instead of scarts
Correct you wiring, color stream uses red, blue, green and they have to be hooked up correctly. the problem is obviously not in your tv or the DVD player.
Nov 08, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
I recently had my tv repaired for diode problem,it is a samsung LNT4066FX/XAA flat screen.Now instead of clicking sound and not turning on the power bar at bottom stays blue and the picture has color...
Well the capacitor problem usually causes power up problems. If your tv comes on now it sounds like you dont have the same problem.Vertical lines are usually caused by bad flat panel or dirty ribbon cable contacts on flat panel connections.
Aug 19, 2010 | Samsung LNT4066F 40 in. LCD Television
How to reset tv. Have sound but black screen
LCD's use a colorful crystal see through display which only visible when light is shining through it. if you have sound and no picture it's always a faulty PSU. Very easy to change out actually.
Mar 27, 2010 | Vizio GV42L 42 in. LCD Television
There is green and pink on color on half of my lcd
I did some research and I found this link that will should you the schematic of the LCD technology,It sounds like one of you LCD color ships is not working properly,your TV has 3 ships (BLUE,GREEN,RED)
you can see how it work; http://www.oerlikon.com/ecomaXL/index.php?site=OPTICS_EN_lcd_projector .Whay happening is that due to the high density the lamp this ships tent to wear out and the three major color don't mix properly causing the color discoloration on your picture.You can find the parts you need at DM http://www.discount-merchant.com/?click=52978 (The correct diagnostic can only be made be a tech) I hope this info helps you please keep us posted .
Sep 25, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Yellowish picture everything else is good
That model had lots of problems, it sounds like your loosing blue. Try putting up a color bar chart and see if you have blue. Color bar is availible on most cable systems. ggod luck
Feb 28, 2009 | Samsung PCK520R TV
Blue tent while playing movie
what type cables are hooked to the dvd, check and make sure that the cables are seated properly or chang the cables , could be the dvd player also
Feb 16, 2008 | Samsung LN-T4671F 46 in. LCD Television
Color problem with Samsung 40 in LCD HDTV
Check your component cables. You have 3 colors coming in. Red,Green and Blue. Make sure the Red cable is good. You can do this by substituting the red cable only, or just change all 3 cables
Best regards
CircuitCity
Nov 25, 2007 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Televison & Video Logo
Top Televison & Video Experts
