Question about Refrigerators
There's power to the fridge but it's not on
  • 4 more comments
  • Bilker
    Bilker Nov 05, 2012
    The connection cable from outlet to the fridge may be damaged. Need to  check with a test light to see where the circualation broken. Have you done this or have somebody to do this tests?
  • Paul Gough Nov 05, 2012
    Hi yes I've tested this and there's power right up to the plug .
  • Bilker
    Bilker Nov 05, 2012
    Have done internal test also, opening the back and goin on to the point where the circulation is broken.like surgery(!)
  • Bilker
    Bilker Nov 05, 2012
    I mean you need to go further to the inside of the fridge. There must be somewhere break.
    Hiya, I haven't one surgery yet but there is power going to the light area also.ive removed the bulb and Id sy it needs changing but that wouldn't stop the fridge working I doubt?
  • Bilker
    Bilker Nov 06, 2012
    No of course do what Boyet says check if you know thermal protector. But be careful this is not a game electricity kills.
    Sergeant:
  • 293 Answers
Check the thermal protector (relay) on the compressor. It may already be defective.
Posted on Nov 06, 2012
Norcold 3163 Fridge
There is a 3 amp.fuse in the wiring behind the control panel or somewhere between the control panel and the terminal block. If the fuse is blown do not replace with any higher amperage rating more than 3 amps. Here is a Norcold 3163 Service Manual On page 10 of the service manual shows all of the components that the ac power goes through. Let me know what you find and I will be here to answer any questions you may have, Thanks Sea Breeze
May 08, 2013 | Refrigerators
Recieved a product that is not working
Try contacting the manufacturer most new appliances come with a 1 year warranty.
Sep 30, 2012 | Refrigerators
After defrosting, the freezer will not start. - Whirlpool fridge.
I presume that you still have got electricity power and the fuse has not 'blown' - if not you could try putting in a new fuse in the plug, sometimes two problems can occur simultaneously.
Otherwise I would leave the door shut to keep the stuff as cold as possible, some may refreeze, or ask a neighbour, friend, or relative to let me have some space in their freezer.
Aug 28, 2012 | Whirlpool Refrigerators
Firdge not working
Is it just a fridge or fridge/freezer? If just a fridge it may be the thermostat, if it's a fridge/freezer it depends if you have 2 compressors or 1. Check & come back.
Brendan
Jun 06, 2012 | AEG Refrigerators
Whirlpool 6wmv43ns/02 Fridge Too Cold & Freezing Food
I would first try replacing the control in the fridge. If that doesn't remedy the situation, I would try replacing the thermostat next.
May 14, 2012 | Whirlpool Refrigerators
Hello, my dometic camper fridge runs great on gas but just clicks when i switch it to electric...??? any advice thanks Stephanie
The mains heater has a different thermostat. Check power to the heater, and the back coil is getting warm
Apr 27, 2012 | Dometic RM2652 Refrigerator
Fridge too cold!
don't forget that just turning down your fridge temp dose not mean your problem might be over yet. the freezer setting may also be too high & that will affect your fridge temp as well. i set both my control settings to around 50% of what is on the scale & that works perfect for my 7 yr old fridge. also, very important, is make sure the freezer portion is going through it's full defrost cycles, or it will freeze the upper portion inside the fridge. you should not have any frost build up in your fridge, nor should you have any in your freezer. that's why they call them FROST FREE. try the slow temp decrease over a period of a few days & hopefully that will work for you. good luck.
Dec 01, 2011 | Refrigerators
Need to know if I can run my fridge on small generator if there is power outage. Generator is 1600/1650 Watts; Amana fridge model TC18HG nameplate says 6.5 Amps. But I'm unsure about the starting...
Hello Bob,
There should be absoluty no problem on that 1600 watt generator..at max when compressor just starts its drawing about 750 watts, that is the max usage when running its about 500 and on defrost its like 850 ..so on 1600 watt generator no problem
Aug 25, 2011 | Amana Refrigerators
Model # (P) 55662 serial # (S) 10149733GT Freezer is at 41' and fridge is at 49' and both are climbing. they were at 38' & 48' respectively this morning. * hours ago we tried: ...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 01, 2011 | Kenmore Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
