Sharp QT-CD44 CD player it doesn't work. What would be the solution, change or clean the laser lens?
When I push play, it start to read the CD but it doesn't sound because it does a tic-tic-tic repeatly.
  • Bilker
    Bilker Nov 05, 2012
    It doesnt read Any CD or certain CDs?
  • Jose Nov 06, 2012
    Thank you for your comments. It doesn't read any CD, original or copy. But I don't want to throw it away. I know it's fault of planned obsolescence so I am trying to fight against it, as everybody here, I think so.
techman
  • 3130 Answers
SOURCE: Malata DVP-500p plays CD's but not DVD's
Could be But most of the time when a tech says a laser assy is bad Its not. It could be a simple grating adj on the pickup assy that alot of techs dont have a clue what it is. This alighnment requires speacial tools and is not advised if you dont know how to do it. What it does is adj. the laser postion onto the prism inside the pickup assy. Or youer problem could be a tracking/focus Gain or offsetr alighnment. This has to be dont looking at the rf waveform from the pickup assy drive circuit via an oscilliscope. These are not unfortantly a consumer adjustment as well. If its an inexpensive player, such as more then a year or so old or under 75 bucks , it probably wont pay to have someone look at it. My friend , this is the times of the throwaway world!! Good Luck
Posted on Jun 20, 2006
Shuttle83
  • 1139 Answers
SOURCE: phillips dvd player
OK lets start off by getting rid of the CD lens cleaner (CD cleaners do more damage then good). Now first we need to clean that lens with a DVD lens clearner (finer cleaning surface). Try to run the DVD cleaning disk twicw (no more) and try to play a DVD. If this does not work. You may have to test the laser power. get a schematic for the DVD that you have, and use it to let you know the specific power measurement of the power, This is done by using a laser power meter, you may not have one, so this becomes a moot point, but on the off chance that you do, use the laser power meter to measure the laser energy and make sure it is to specs as seen on the schematic. If you do not have a laser power meter., well I hate to tell you this but you may have to get a new unit. See the problem is the process of fixing this problem is simple if you have the right equipment, but if you don't you are at a disadvantage.
Posted on Sep 11, 2007
  • 4 Answers
SOURCE: philips DVP642 DVD Player "No disc" problem
if its still under warranty, do that.
if it's not, try taking it back to the store and asking for a replacement. don't let the floor salesman tell you no. insist on speaking to the manager. my strategy is to: "be polite, appear slightly stupid, and dont take no for an answer" it works 80-90% of the time.
if you cant get anywhere (or dont want to try that route), then you have nothing to lose. open the case and try to clean the mechanism and lens
two screws on either side of the unit, and i think another 4 screws on the back side. this will allow you to pull the top cover off the unit.
clean the mechanism, and clean the lens. you can buy cleaner if you want, but i just use a soft cloth and some "no-streak" type window/glass cleaner (windex)
clean your disks as well. this DVD player seems to be sensitive to scuffs and dust more than some other players. you just have to be persistent.
or you could buy another DVD player. at $60, its really a pretty good deal anyhow.
good luck
Posted on Mar 09, 2008
  • 22 Answers
SOURCE: DVP642/ 37 DVD player says "NO DISK" with any disk.
Usually if there is a NO DISC error, and the lens is verified clean, there is either dust in the laser assembly (use a can of compressed air to clean it out) or a loose laser assembly cable. Also check to make sure the lens can bob (wiggle around), and that it can slide back and forth.
The emergency eject is underneath, its a small slot. Insert a toothpick at one end and slide to the other end to open the tray.
Posted on Aug 30, 2008
seabelow
  • 95 Answers
SOURCE: My dvd player dvp615 doesn´t play dvd discs. only music cd´s
The unit has two lasers one for the cd and one for the dvd, the one for the dvd is bad and the whole laser assembly needs replaced. Cheaper to buy a new player.... sorry
Posted on Jun 12, 2009
Dvd wont read it says there is no disc
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Nov 25, 2011 | Toshiba Televison & Video
Won't read d d keeps saying bad disk
Hello, welcome to Fixya!
Was this player playing previously? And how long have you been using this player? I suspect the lens of the player. Once the lens of the player becomes weak, it won't play discs any longer.
The first thing my mind goes to, is the lens. The lens id responsible for reading/loading data on discs. So if the lens is unable to read the disc, there is no way the player is going to play the disc.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or probably, a mechanism problem.
Good luck.
Oct 05, 2011 | Curtis DVD1041 Player
Marantz cd44-minimal sound when playing cd. Amplifier (rx163) works with tuner. I have tried cleaning head but with no sound improvement. Any suggestions?
I can't find any pictures or reference to a CD44 but if it's a CD player there would be no point in cleaning the laser lens if ity makes ANY sound at all. The bits don't get louder. Ones and zeros don't change. Look for an output control. Many players had fixed and variable outputs.
Jun 15, 2011 | Marantz Audio Players & Recorders
My player will not read a disc. what could be wrong?
Good luck.
Jun 07, 2011 | JVC Televison & Video
When i try to play dvds it reads dic problom
Yours sincerely.
Elect_Comp.
May 15, 2011 | RCA DRC8005 DVD Recorder
It doesnt play dvd only music cd
Regards.
May 02, 2011 | Televison & Video
The dvd is not loading and will not play. the cds are working fine.
Regards.
Apr 20, 2011 | Blaupunkt DVD-ME2 Car DVD Player
Wont read disk
Good luck.
Apr 17, 2011 | Lite On LVC-9015G
DVD player purchased 8/4/10 will not read disc. Model SD7300. Have used the cleaner disc.
Regards.
Apr 14, 2011 | Toshiba Televison & Video
It will read CD disk but will not read DVD disk have tried several different ones
Good luck.
Apr 14, 2011 | Phoenix Gold Phoenix Digital (PD-2122T)...
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
Electro Med Services...
