Question about IBM ThinkPad T30 2366 Notebook
T43 screen dims and laptop will not shut down
Ibm thinkpad t43 26684du screen dims after a while but when i try ti shut it down ,it will not unless i remove the battery. win 7 ultimate all updates.
  • IBM Master
  • 7,627 Answers
The screen will dim on battery power to save energy. The power settings, found when you right click the power icon in taskbar notification area and go to power options, can be changed to your personal preferences. The shut down issue may be what is running, I can't say what is running, but look at the Start up process in MSCONFIG and shut down what is not necessary at Start UP. Look at tutorials on Faster Start up and Shut down. There may be many items you can shut down/disable to speed up these events. QUESTION: Is this a upgrade to WIN 7 Ultimate, If so your computer me be a bit short on specs, in other words you have reached the computers hardware limits. How much RAM, CPU speed...etc.
Posted on Nov 06, 2012
SOURCE: how toremove ibm thinkpad t43 password
HI,
KINDLY SEND THE STEPS FOR REMOVE THE BIOS PASSWORD
REGARDS,
RAAJAA,
Posted on Dec 28, 2008
  • 60 Answers
SOURCE: Trying to upgrade H/D on IBM T43 laptop, get 2010 error on
Error code 2010 is definitely hard drive problem.
Did you get the firmware from the site below?
Link to hardware maintenance manual for reference:
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles_pdf/39t2393.pdf
Here's the fix straight from the maintenance manual:
If in the primary bay the customer is using a non-IBM or non-Lenovo hard disk drive (HDD), or an old generation IBM HDD which is not supported by this system, with the risk in mind, the customer can still use it by pressing ESC. If in the primary drive bay the customer is using a supported IBM/Lenovo HDD with an old firmware, the customer needs to update its firmware to the latest. The latest version is available at http://www.lenovo.com/think/ support
Posted on Apr 07, 2009
Geekman
  • 32281 Answers
SOURCE: ibm thinkpad t43 backlight inverter issue
Did you say the the video output flickers on and off when you connect an external monitor to the video output. If the inverter is faulty this would not affect the video output and the external monitor would not flicker but if the external monitor flickers it would point to a video card problem.
Posted on Jun 14, 2009
ariyoso
  • 145 Answers
SOURCE: ibm thinkpad t41 does not boot up...just black screen...fan works
hehe...I used to have some problems
and then came up with the solution to install other OS such as linux, lindows or anything else
and then reinstal it with windows booting...and then it works, u can try it
Posted on Jun 21, 2009
bobfreengel
  • 37 Answers
SOURCE: IBM THINKPAD T43. I can find the switch for my ibm thinkpad T43
Are you sure you have a wire card installed? If so, then try this:
  1. Right-click the My Computer icon and select Properties.
  2. Click the Hardware tab and press the Device Manager button. The network card should appear under Network Adapters.
    Note: If the card has a exclamation mark over a yellow background, then this is an indication that the card is experiencing a problem. Go to Driver download step 5.
  1. Verify that the radio is enabled.
    It is possible to disable the transmitter of the wireless card without Device Manager showing any problems.
    Note: Follow the instructions provided to enable wireless card.
    • Most wireless cards will put an icon in the system tray (the line of icons in the lower right corner of your screen). Right click this icon and it may have a menu option to enable/turn on the wireless radio.
    • Some systems come with a Wireless Radio switch to disable the wireless radios. The wireless radio switch is usually located on the front side of the machine. If you are having difficulties with wireless connections, make sure the Wireless Radio switch is set in the On position.
  2. Check for association to an Access Point.
    If you double-click the previously mentioned system tray icon, the configuration utility of the wireless card will appear. This utility will be able to show the status of the wireless card, showing what channel the card is using and what signal strength is being received. It may be difficult to maintain a connection if signal strength is low due to either interference or distance. For example, interference can be caused by 2.4GHz cordless phones, other Access Points in the area, and physical structures such as load bearing walls or metal partitions.
    Note:
    The utility can be used to configure the wireless card settings, but if using Windows XP Zero Configuration or Access Connections, you will need to use those programs to actually configure the wireless card as they will overwrite the setting of the utility.
Posted on Oct 12, 2009
My thinkpad t43 26684du screen goes very dim after use (half hour). when i reboot it won't shut down until i remove battery. restarts fine for a while. irun win 7 ultimate all updated.
There is two problem possible for these symptoms:
1st one is due to inverter
2nd one is due to screen backlight lamp (CCFL)
You need technical support. We may need some components to be changed. If you think you can do it on your own, see http://www.laptoprepair101.com/laptop/2007/09/05/troubleshooting-laptop-with-backlight-failure/
Nov 05, 2012 | Computers & Internet
Can't see my onscreen display after turning on F7 IBM T43 ThinkPad
set it to clone. it should give you identical displays. then try setting it to extended display. But make sure that your laptop display is primary display. That is why your external screen is displaying because it set on primary.
Jul 21, 2012 | IBM ThinkPad T43 Notebook
Dim light on lcd screen
Either you have a power setting on that has the screen dimmed, or it's dimmed manually, or your laptop inverter is in the process of failing.
Sep 24, 2011 | IBM ThinkPad T43 Notebook
I need Infared Driver for IBM Thinkpad T43 notebook...
The same model ThinkPad can have different types of network, video and audio drivers and unless you know exactly which one is installed in your ThinkPad, you need to download all the drivers and install each driver until you find the right driver.
When you download the drivers, write down the device driver and it
Sep 21, 2010 | IBM ThinkPad T43 Notebook
Ask for Ibm Thinkpad T43 battery Price?
go to : Canada battery on-line shop,sell Laptop battery, Digital Camera Battery (DC ...... Welcome to buy ThinkPad T42, replacement laptop battery for IBM ThinkPad ...
https://www.linkme.com.au/groups/public
Jul 20, 2010 | IBM ThinkPad T42 Notebook
Dim screen on ibm thinkpad t43
did you check the power option,
Jun 05, 2009 | IBM ThinkPad T43 Notebook
My ibm thinkpad t43 displayed a message "hard error D0014" on a small blue screen. when i shut it down by pressing the power button for a few seconds, it restarted. but the programs won't work.
This could be a problem, not sure if its a software related or if the hard drive is bad. If you can find a windows xp cd. Try and wipe out the hard drive and install windows xp on it. If it goes thru then you'll just need the drivers. If it errors out on you then you know its a problem with the hard drive and you'll need to replace it. If you get windows xp installed on it, let me know and I'll help you with the drivers.
Jun 04, 2009 | IBM ThinkPad T43 Notebook
MY IBM T43 fails to boot
Take out the hard drive and see if the laptop still shuts down. If it doesn't then your hard drive might be the issue. You can also try reseating your memory.
Dec 26, 2007 | IBM ThinkPad T43 Notebook
IBM ThinkPad T30 2366 Notebook Logo
134 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
