My Dell keyboard is typing french how do i get it back to english on a windows vista system
  • casamac
    casamac Nov 06, 2012
    There is no Details in the Langusge tab in my control panel
  • Jose Diaz
    Jose Diaz Nov 06, 2012
    Click Start, and then type Change display language in the Start Search box. Click Change display language. In the drop-down list that appears, select the language that you want, and then click OK.
  • 2,878 Answers
Ctrl + Alt then Shift and test. Remove other languages. Go to Control Panel > Regional and Language Options. In Languages tab, click details. Remove extra / other Installed service.
Posted on Nov 06, 2012
SOURCE: Bilingual keyboard
video/audio driver
Posted on Mar 28, 2008
  • 17 Answers
SOURCE: keyboard and mouse won't work after start up
Pls check that the press button on the top of touchpad, most probably its disabled by being accidently pressed.
Posted on Dec 11, 2008
  • 60 Answers
SOURCE: My keyboard is respounding in the French version
Go to your Control Panel, Regional and Language Options, Languages, Details, and check that the default input language, and keyboard are English. This is assuming you're running Windows XP.
Posted on Mar 23, 2009
Crankstart
  • 696 Answers
There is a small green Fn button near the start button you will have to use this with shift to use the green keys if you are in multi lingual mode, if you only use the laptop for french you can also change the regional settings for the keyboard to Just French and then they will work just by using shift.
Hope this helps FixYa,
Chris
Posted on May 19, 2009
  • 76 Answers
SOURCE: Acer Aspire 7530, keyboard language switches
go to control panel
Then regional language option
then set english united states. then apply and ok.
If you not ablwe to read french then just set english it is upperr from current selection 5 or 6 check it.
Posted on Aug 20, 2009
How to fix french dell keybnoard model SK-8115 converted into english & question mark don't work
If you are using a FRENCH keyboad on an ENGLISH configuration, take it ganted that it won't woks. You should define your keyboard as French . If you are using Windows, you should go to control Panel - Regional and Language confiuration
Press TAB Language
Press button DETAILS
Now select Language as French
Press ADD and select Language French and Keyboard French
Accept.
Select this configuration as default.
Accept and exit Control Panel
Now your French keyboard should use french language distribution
May 06, 2015 | Dell Computers & Internet
My pound sign comes up as # and my @ as "
Windows 7 or Windows Vista
  1. Click Start Collapse this imageExpand this imagevistastartbutton.jpg, type intl.cpl in the Start Search box, and then press ENTER.
  2. On the Keyboards and Language tab, click Change keyboards.
  3. Click Add.
  4. Expand the language that you want. For example, expand French (Canada).
  5. Expand Keyboard list, click to select the English(United States) check box, and then click OK.
  6. In the options, click View Layout to compare the layout with the actual keyboard.
  7. In the Default input language list, click English(United States) - English(United States), and then click OK two times.
  8. In the Regional and Language Options dialog box, click OK. Note The Language bar appears on the taskbar. When you rest the mouse pointer over this bar, a tooltip appears that describes the active keyboard layout.
  9. Click the Language bar, and then click English(United States).
Windows XP
  1. Click Start , type intl.cpl in the Run box, and then press ENTER.
  2. On the Languages tab, click Details.
  3. Under Installed services, click Add.
  4. In the Input language list, select the language that you want. For example, select French (Canada) .
  5. In the Keyboard layout/IME list, click English(United States), and then click OK .
  6. In the Select one of the installed input languages to use when you start your computer list, click English(United States) - English(United States), and then click OK.
  7. In the Regional and Language Options dialog box, click OK. Note The Language bar appears on the taskbar. When you rest the mouse pointer over this bar, a tooltip appears that describes the active keyboard layout.
  8. Click the Language bar, and then click English(United States).
How to make sure that the selected layout matches the keyboard Windows 7 or Windows Vista
  1. Click Start, type osk in the Start Search box, and then press ENTER.
  2. Match the keyboard on the screen with the physical keyboard to make sure that the layout matches.
  3. To check the uppercase characters, click the shift key on the keyboard or on the screen, and match the characters printed on the keyboard.
Windows XP
  1. Click Start, type osk in the Run box, and then press ENTER.
Jan 07, 2011 | Dell Computers & Internet
How change french keyboard back to english keyboard (Vista)
Ok heres where you need to go
Start Button (Circular Button With Microsoft 4 Coloured Square Logo)
Control Panel
Regional & Language Options
Keyboards and Languages (3rd Tab Along from Dialog Popup Window)
Then click the Change Keyboards Button
Under General Tab under installed services Click Add on right hand side.
Find English UK or English US whichever you prefer and then
once you have added that one change your default to the English one
then you will be able to remove the french one if needed.
I hope you find this post useful,
Thanks
Pete McDowell
Geek2Door Ltd
www.geek2door.com
Feb 14, 2010 | Microsoft Windows Vista Business Edition...
My Dell keyboard is typing french symbols,how do I change it back to english
if you have windows XP follow these steps :-right click on Taskbar-Toolsbar-here check the language bar(should apear in your case french) -right click on the Fr(that apear)-settings -here you will see French keyboard-click Add and select EN-english -than OK and your keyboard should type english letters/
Dec 09, 2009 | Dell 0Y3740 Keyboard
My keyboard is typing an è instead of an apostrophy
Microsoft Windows has support for "foreign" keyboards, e.g., French, Swedish.
You've managed to hit left-ALT-SHIFT to switch the "input language" from English to French.
Use "Regional Settings" within "Control Panel" to set it back to English.
Oct 21, 2009 | Microsoft Windows XP Home Edition
Dell E521 had it reconfigured from Vista to XP now back on Vista keyboard language has come up in french AZERTY also same for searched results Boot up is Vista english
Okay... Start > Control Pannel > Regional Options > Keyboard Layout > Select English US or English UK reboot.
If it does not solve it tell me.
-Tom.
Jul 13, 2009 | Dell Computers & Internet
When typing question marks & puctuation...French comes up
In Control Panel, double click "Regional and Language Options". Click the Languages Tab and then the Details button. Make sure that English is selected as the Default Input Language. If French is listed as an available keyboard layout and you don't need it there, you can remove it to make sure it doesn't switch itself again.
I hope this helps. Good Luck.
Jun 24, 2009 | Dell Spacesaver USB Keyboard J4624 SK-8115...
KEYBOARD PROPLEM
Hi Sam,
Sorry your problem got left in the que for a while, but Lee apparently wasn't familiar with that keyboard. You do have an extra key near the start button that activates the Tags and other coloured symbols while in french or multi language mode. Simply use it like a shift key.
If you're not using the HP to type in french and don't require the accents you can change the setting in windows to tell the computer that your keyboard is a US english keyboard which will reassign all the keycodes to the "normal" locations by english speaking standards.
To do so, open your control panel, click on the classic mode link if it's not already in classic mode(20+ icons). Then click on the regional settings icon. Depending on wether you have Vista or XP the panel varies slightly XP has a keyboards tab, Vista has a Input Devices tab. Either way go to that tab and click the button to adjust input devices, on the page that pops up you will see a list of available, installed keyboards. If US english isn't listed click the ADD button find it in the list and add it.
If you only type in english, remove all other keyboards. If you use french as well, remove all but the canadian french/canadian multilingual depending which you have(if you don't know follow instructions below to find out). Then OK out of the window. OK the regional settings window and close the control panel. If you only select US english you're done, if you left French as an option you will see a small blue icon to the left of the clock, you can click on it at any time to switch between your installed keyboard modes.
Hope this Helps FixYa!
Chris
Model info for your product can be found at www.hp.com click Support & Drivers, then select the Knowledgebase button on the next screen and type in your full model number or allow the automated link to check your model online. When it launches your product page select Product Specifications from the long list in the middle and if it brings up a second list select the same.
You can now scroll down the specs and your keyboard will be listed as either Canadian English/French/Multiligual, all three have some variation of the keys you described.
Apr 11, 2009 | HP Computers & Internet
HOW TO SET UP MY WINDOW VISTA IN FRENCH
Unless you have Vista Ultimate or Enterprise, you'd have to
purchase and install an French version of Vista. MUI (Multilingual
User Interface) packs are only available in Windows Vista Ultimate and
Windows Vista Enterprise.
International keyboard (Windows Vista)
  1. Open your Control Panel
  2. If in Classic View, click Control Panel Home in upper-left corner
  3. Under Clock, Language, and Region, click Change keyboards or other input methods
  4. Click Change keyboards
  5. Click Add
  6. Scroll down to English (United States)
  7. If you don't see a list including United States-international, click + to expand
  8. Choose United States-International
  9. Click OK in each dialog window.
  10. Read Using the international keyboard (above) and, if necessary, Troubleshooting the international keyboard (below).
See this info on this link:
http://french.about.com/library/bl_faq_accents.htm
Joyeux Noel!
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 25, 2008 | HP Computers & Internet
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
