Question about Canon MP140 PHOTO AIO All-In-One InkJet Printer
Before you can perform print-related tasks such as page setup or printing a document, you need to install a printer
How to setup the network settings of my lexmark e120n printer. I installed the printer. Printing tasks give a "not abble to print "message. I can give it an IP adress and print a document from...
Check the network cable that connects the printer and the router. Please print a network set up page to check if the status shows connected under tcp/ip. To print a network set up page please click the link http://bit.ly/qTSoRt, please make sure that the correct print driver is installed on the pc.
Please take note of the IP address and type it on your browser
Apr 30, 2011 | Lexmark E120n Laser Printer
Hummer sound and one page print an then stop printing
There could be a wide range of caused for the problem being seen, a few things worth trying are;
Try printing the HELP page on the printer, this is a menu page and will demonstrate if the printer can print ok, if the printer prints the HELP page correctly the problem is likely to be 'data related'
The help page gan be printed in the following way;
  1. Place the printer OFFLINE
  2. Press the MENU button
  3. Press the DOWN ARROW repeatedly until HELP is shown of the display
  4. Press ENTER
  5. The printer should then print out a menu page containing a number columns of settings.
If the printer prints the Help Page Correctly this strongly suggests the problem is data or settings related.
It may be worth trying printing from another system / application to see if the problem may be related to one document or system.
Some settings you may wish to check on the printer are;
Emulation -Ensure this is set to match the host system setup
Auto LF- You may need to turn Auto LF (auto line feed) on if the system is only outputting Carriage Return Commands and no Form Feed Commands
Bi-Dir - If the printer is connected via the Parallel Interface you may need to disable Bi-Directional communication for the parallel interface.
Further investigation may need to be carried out to identify the cause of the problem
If the printer is not able to print the help page, this indicates a hardware problem with the printer.
If the printer prints the help page but not the document, this indicates a Driver / Settings / Communication type problem which requires investigation.
Mar 29, 2011 | TallyGenicom 6306 Matrix Printer
Samsung ml-1710 printer does not always print
you need to reinstall printer with samsung printer driver specific for this model that can be downloaded from samsung website
Oct 04, 2009 | Samsung ML 1710 Laser Printer
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
3. Specify Staple Side.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
Aug 17, 2009 | Canon PIXMA MP610 InkJet Printer
Before you can perform print related tasks such as page setup or printing a document you need to instal a printer
hi... did you install your printer? if so, then you have to uninstall that.. go to menu/all programs/control panel/add or remove programs/... then reinstall that.. and pls you have to enable the twain driver of your printer...thank you very much..
Jul 10, 2009 | HP LaserJet 1500L Printer
Print spoole
has this been resolved?
Jan 10, 2008 | Dell A920 InkJet Printer
PRiNt SP00lER
1. Go to Start > Run and type in services.msc then press Enter. 2. In the window that opens find "Print Spooler" on the right 3. Right-click "Print Spooler" and select "Properties". 4. Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service". 5. Make sure the 2 text boxes underneath say "1" in them. 6. Click Ok until you are back at the Services window, close it and you're good to go. 7. Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
Jan 08, 2008 | Dell A960 All-In-One InkJet Printer
PRiNt SP00lER
Try this FixYa for Error 1068.
Let me know how it goes.
Jan 08, 2008 | Dell A920 InkJet Printer
Print spooler
HI ,
This is JISHKUMAR, U need to click on dependencies tab.this u will get it when u double click on print spooler.just look which are the services under dependencies..whatever services you will find just go to that services and start them and then start print spooler service. this will 101% solve your problem
Canon MP140 PHOTO AIO All-In-One InkJet Printer Logo
309 people viewed this question
old marine
old marine
