Question about Hotpoint Wma32p Wma34p Wma36p Washing Machine Door Lock Interlock Switch
Washing machine keeps saying door not locked
My washing machine keeps saying the door is not locked when it is i have had a look at the door look and it seems fine to me but the handle has to prongs things on it and one of them is broken, should that matter or not.
    Problem Solver:
  • 21 Answers
A svitch from the door may be damaged ,, chek replace it..
Posted on Nov 05, 2012
SOURCE: faulty door which keeps beeping
I had a similar problem which was resolved by replacing the door interlock switch (cost about £10.00).
To get to it you need to disconnect the mains then remove the top lid. You can then see it by looking down the inside to the right. Remove the 2 screws inside the door opening and you can then lift it out after disconnecting the wiring plug.
Replacement is the reverse of the above, a 5 minute job.
Posted on Dec 29, 2007
Malcg
  • 32 Answers
SOURCE: WF860 Door stuck in closed position.
FIRST switch off and unplug.
Pull machine out and remove lid by undoing self tapping screws at the top back. May have to slide lid back a bit to lift off.
Internal catch mechanism will be reachable from top for manual release. You may need someone to push door inwards while you release catch.
Good luck
Posted on Apr 13, 2008
gittos73
  • 244 Answers
SOURCE: Broken door handle for a Thor washing machine
there r 2 ways to get the door open 1)use a normal knife and place in front of the door handle push it in and it should open 2)pull the plug out take the lid off now place your hand down to where the catch goes into the washer using your fingers u should be able to pop it open with a bit off fiddling
Posted on Dec 16, 2008
  • 566 Answers
SOURCE: door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
Posted on Feb 16, 2009
SOURCE: broken machine door handle :(
Unplug at the mains, remove lid and door catch can be released from inside the machine.
Posted on Sep 19, 2009
Washing machine keeps tripping electric when the door locks
Washing machine tripping or fusing electrics
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 26, 2013 - A Washing machine tripping or fusing electrics is a fault you can't really deal with unless ... If washer has tripped the RCD or fused the plug but now won't work properly. ... Here's an article on Washing Machine Door Will Not Open ... If youkeep resetting it without fixing the cause of the tripping it can blow ...
6 common washing machine problems and how to solve them
www.appliancesonlineblog.com.au/.../6-common-washing-machine-prob...
Feb 10, 2014 - As mentioned earlier, front loader doors lock during the cycle to prevent the water from ... The washing machine keeps tripping the power!
Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and ...
? 7:00
https://www.youtube.com/watch?v=dx2vCzO8828
Jun 13, 2013 - Uploaded by ApplianceVideo.com
Yeah, keep it ... Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and will not always run - .... TROUBLESHOOTING Top Loading Washing Machines in ... Maytag Neptune Door Locked but No Spin - R11 is not burnt ...
Washing Machine keeps tripping the electrics -
Dec 29, 2015 | Washing Machines
Keeps saying LE. Wont run. NEC Topload washing machine
Hi from retired Englishman in SW France, Frid afternoon, 14:24,
As you do not mention the model, I am going to guess it stands for 'Lock Error'. Either the lock itself is malfunctioning or the door lock sensor is, meaning that service is required. Sorry ;-0(
Good luck,
John C
Mar 04, 2011 | Washing Machines
Washing machine says door is open and stops
I would make sure the door latch and door lock are both clean and free of debris as this will cause the machine to fault out from the latch not hitting the switch properly. If cleaning it thourghly doesn't do the trick you may need a new door latch/lock mechanism.
Jan 30, 2010 | Washing Machines
Door lock
Switch off. Try some WD40 on the machine lock (not on door) and open & close door many times, to ease out the lock.
Jan 28, 2009 | Hotpoint WMA54 Front Load Washer
Washing machine not working
I Put A Set Of New Brushes In motor And It started
Jan 17, 2009 | Hotpoint First Edition FEW12 Front Load...
Theres a load stuck in my washing machine. the washer will not start. it keeps saying "dL" and "f". the owners manual does not say anything about "dL" what do i do?
Hi xstar57x
This suggest problems with the door lock/unlock mechanism
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Replace failed component
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Note: The door lock/switch assembly can be manually unlocked.
To Manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the lower toe panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about 1/4 inch or until a click is heard.
6. The door may now be opened.
Regards
Nov 16, 2008 | Whirlpool Washing Machines
Washing machine
bottom right corner behind the little door
Sep 27, 2008 | Whirlpool AWM5125/1 Front Load Washer
Hotpoint Wma32p Wma34p Wma36p Washing Machine Door Lock Interlock Switch Logo
62 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
