Question about HP Computers & Internet
How to Replace the DVD RW on my PC /HP Pavillion a6130n /
I want to replace the lightscribe DVD player with a new one, is there a video to show how this is done?
  • HP Master
  • 5,660 Answers
Better
There is Me
HP Support > Pavilion a6130n Desktop PC > Main Support page,
http://h10025.www1.hp.com/ewfrf/wc/product?product=3436817&lc=en&cc=us&dlc=en&lang=en&cc=us
How to > Adding / Replacing hardware > Opening the PC Case,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00968217&tmp_task=useCategory&cc=us&dlc=en&lang=en&lc=en&product=3436817
Back page; Adding / Replacing hardware > Removing the Front Cover,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00968624&tmp_task=useCategory&cc=us&dlc=en&lang=en&lc=en&product=3436817
Back page; Adding / Replacing hardware > Adding or Replacing a CD or DVD Drive,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00981303&tmp_task=useCategory&cc=us&dlc=en&lang=en&lc=en&product=3436817
This is an example of a SATA data cable,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
Note the L-shape inside the cable's connector.
It also shows a SATA connector for the motherboard.
Note the L-shape on the connector. The optical drive (CD/DVD drive) also has this L-shape on it's connector.
(SATA connectors on the motherboard come in various colors. Color signifies what SATA connector it may be. SATA0, or SATA1, or SATA2, etc.)
Between a SATA data cable's connector, and a SATA power cable's connector, the SATA power cable connector is the larger of the two.
SATA data cable connector has 7-pins. (Contact pins)
SATA power cable has 15-pins. (Contact pins)
Example of a SATA power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
A SATA data cable connector, and a SATA power cable connector, may have a small 'bump' on them, that you depress with your thumb, when installing the cable, or removing. The 'bump' is a Lock.
Usually the cable end going to a harddrive, or an optical drive; will be a 90 degree Elbow.
The straight end connector plugs into the motherboard.
A Top View look at the motherboard in your computer,
HP Support main page > Product information > Product specifications > Motherboard specifications, MCP61PM-HM (Nettle2),
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01077676&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3436817
View shown has NO hardware on the motherboard.
(Processor, Ram Memory, etc)
The long Blue, and Black slots, with the White Lock 'ears', are Ram Memory slots.
The SATA connectors on the motherboard, are to the bottom/right corner, of the Number 3 and Number 4 ram memory slots. (Blue)
Yellow, Blue, White, and Black.
Scroll down, and click on the + sign to the left of the blue -
Motherboard layout
Using this illustration you can see;
Yellow SATA connector is SATA4 <-
Blue SATA connector is SATA3
White SATA connector is SATA2
Black SATA connector is SATA1
Due to standards set by JEDEC, and generally followed by all; the harddrive is plugged into SATA1.
HOWEVER, you can plug your optical drive, or drives, or harddrive, or harddrives; into ANY SATA connector on the motherboard that you want to.
The beauty of SATA is that BIOS will find the drive, NO matter what SATA connector on the motherboard you plug into.
Harddrive, or optical drive.
For clarification on anything I have stated above, or for additional questions; please post in a Comment.
Regards,
joecoolvette
Posted on Nov 06, 2012
5 Suggested Answers
  • 3940 Answers
SOURCE: hp pavillion dv6835nr dvd player
Try this, put a DVD movie in the drive, then open windows explorer (Right click the start button, click explore) then see if you can read the DVD files on the DVD.
If you cannot browse the DVD then the DVD optics of the drive have failed and you will need to replace the drive.
Posted on May 17, 2008
Hollyecho
  • 313 Answers
SOURCE: hoow to install a dv2000 hp pavilion dvd rw drive (internal)
Remove the Phillips PM2.5x7.0 screw (1) that secures the optical drive to the computer
Insert a thin tool, such as a paper clip, into the media tray release hole (2). (The optical drive media tray release from the optical drive)
Use the media tray frame to slide the optical drive (3) to the left.
Remove the optical drive.
ce642a5.jpg You can download the complete manual here:
http://h10032.www1.hp.com/ctg/Manual/c01035657.pdf
Posted on Jul 22, 2008
SOURCE: hp pavillion dv9000- cd/dvd rw drive not working
you have to send it back to hp to get it fixed, this is the second time mine had the same problem
Posted on May 27, 2009
  • 4 Answers
SOURCE: Unlock the region on HP Pavillion dv6-2111TcX with bluray
Go to control panel /system / hardware tab , then click on device manager then find your dvd/cd drive right click on that and select properties. there should be several tabs the one you want will be named dvd region or something like that.
some drives will only let you change the region a couple of times
Posted on Jul 25, 2010
Can I play store bought dvds on my new memorex slim external cd/dvd writer? The box says yes but when I install, it just shows the movie name and won't do anything
If it is just a writer then no but I have never heard of just a writer and mostly they are designated a reader/writer when they should be able to read whatever they are capable of writing - if the computer has the right software installed that is.
It could be you need to instal a suitable media player or dvd player software.
Sep 05, 2016 | Memorex 32020019660 8X DVDRW External Slim...
Tip
LightScribe Disc Burning
How to burn a LightScribe Disc.
You need to download The Light scribe Template Labeler.
You can get it here. http://www.lightscribe.com/products/index.aspx?id=105
Pick your Platform. ie Windows,Mac,Linux
you can get Designs from here.
http://www.lightscribe.com/ideas/index.aspx?id=2564
Install the Template Labeler
You now need to insert a LightScribe Dsic Into the drive (Lable side down)
Now go to start and left click on the LightScribe Template Labeler Program.
On the first window you'll get an option to do not show again.(your choice)click ok
You are now in the labeler program.
pick a Template
You can download more Templates from a link centered near the top of the screen.
click next at the bottom of the screen.
The next screen you can edit your slected image.click Preview and Print when your done editing.
The next screen you can slect your color of choice and the drive as well as print options.
On the bottom right your estimated burn time will be displayed.
click print near bottom right.
Hope this helped.
on Jun 03, 2010 | HP DVD 740VI 16X16 Dual Layer LightScribe...
How do use lightscribe?
Below is a link for the instructions to use Lightscribe. One thing people do not think about on this, do you have an actuall Lightscribe disk? These are the only disks that will allow you to create a lable in the Lightscribe drive.
http://www.lightscribe.com/gettingstarted/index.aspx?id=276
Jun 27, 2012 | Xerox 1 To 11 Target DVD Duplicator with...
Please give me activation code for cyberlink dvd installation. Cannot play my lightscribe dvd. The system continues to ask for dvd encoder.
The program isn't the problem- it's your dvd players software. Try VLC Player- a free player that plays anything. VLC player has the DVD encoder hot-wired into the program so you don't have to download one.
Dec 15, 2010 | HP LightScribe dvd640i (DVD640I)...
I've had this Hp dvd 1070 with lightscribe for about a year now and MOST of the burned discs 'glitch-up' after half to three quarters of an hour on, basically, all other players. Could you, at least, give...
Hello
Thank you for using FixYa for your problem
So any program you use to burn DVD's fails, sounds like the burner or a driver isure. What OS and are the updates done, is there a update for lightscribe
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 22, 2009 | HP DVD1070i 20X SATA Multiformat DVD...
Can i add lightscribe to a new laptop? just ordered it and realized it does not come with lightscribe.
The LightScribe-enabled CD/DVD disc drive contains a special laser that pumps light into this label to create whatever designs you have created. The light from the laser causes a chemical change in the dye coating that shows up as a visible point on the disc.
The best way to add this to your new computer is to buy a Lightscribe external drive that connects via a USB port.
Oct 03, 2009 | Computers & Internet
LightScribe installed properly, but not seen by other software.
Software problem with NERO and Surething LightScribe. Didn't see the "LightScribe' option in thier software.
Droppix Lightscribe software worked fine.
Dec 28, 2008 | HP LightScribe dvd640i (DVD640I)...
Dvd writer w/lightscribe
See http://www.lightscribe.com/ for explanation.
Apr 01, 2008 | Lite On LVW-5115GHC+ DVD Recorder
Computers & Internet Logo
157 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
