Question about LG WM1814CW Front Load Washer
Washer won't drain. How do I get to the pump
I have taken the filter out and see nothing blocking in this area. I want to take the pump off. How do I get to it.
    Problem Solver:
  • 21 Answers
First chec in the pump ,, a coin may obturate..
Posted on Nov 05, 2012
onthejob5130
  • 640 Answers
SOURCE: LG front load washer has blocked drain line which is located in
take top off remove three srcews in back ..remove 4 screws hold control console ,,dont remove connection just flip console on top of drum,,make sure unit is unpluged..your looking at 4 screws across to panel remove them open door remove spring wire clip around the out sid bellows where almost there..now careful down in the filter acess panel remove the frist screw the filter cover comes off after the cover is out remove the pump filter housing screw..and last remove thebottom panel screw,,remov panel,,pump on left is drain pump..pump on right is recrulation pump
Posted on Dec 25, 2008
agitateme
  • 88 Answers
SOURCE: LG front load washer does not drain after cycle.
Check for 120 volts to the pump motor while in drain mode, if the pump does not run, or just hums, replace the pump motor. Some LG's have both a recirculating and drain motor on the pump casing, so be sure to replace the correct motor.
Posted on Dec 30, 2009
  • 489 Answers
SOURCE: Drain Cycle Noise
The only way to get into the drain pump is to have the top panel, the control panel and the front panel removed.  You will have to move the washer out of the closet to get the 2 screws holding the top in place.
Posted on Jul 23, 2008
heatman101
  • 43501 Answers
SOURCE: I have an LG washer front load WM2032HW. It won't
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Aug 26, 2011
  • 6277 Answers
SOURCE: How do I check the drain pump on LG washer? Water
Follow these notes through!
Here are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Oct 21, 2011
Kenmore heavy duty 60 series model 110 91566210 won't drain- what now?
Not draining could be blocked or faulty pump, If you could hear the pump, probably blocked check filters, check pipe work, including the external drain hose. If you cannot hear a pump run, could be faulty pump, or could be totally blocked with something, jamming the impellar, would need the pump taken out or pipes disconnected from it to clear
Mar 05, 2013 | Washing Machines
Duets washer won't drain
Probably a blocked filter, outlet pipe or pump.
Take the drain hose and lay it flat and lower then the level of the drum and this will drain the machine providing the blockage is not solid. When machine is empty check filter , pipes and pump and remove any blockage found.
Replace drain hose and you should then be able to carry on with your wash or spin the clothes.
Dec 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My indesit iwc6105 washing machine is not draining at all.
see this causes: and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out
Oct 11, 2012 | Washing Machines
Won't drain and won't spin ,makes a clicking sound
sound as though the drain pump has something hitting the impeller making the clicking noise,and the filter basket next to the pump is blocked by debris and not letting it drain
Sep 01, 2012 | Maytag MAH6700AWW Neptune Front-Load...
Washer doesn't spin out sometimes
you say it drain, but sometimes it won't spin,this could be your filter if it is blocked these new machines can sence it and won't let the machine spin easyest thing check your filter,you never know might be that simple
May 07, 2012 | Washing Machines
GE WSXH208V1WW
Usually when you have a washer that will not drain, first check if the drain hose is kinked or too high above the washer (8 ft is the limit of the washer pump). Next check if there is a blockage in your drain (often a stand pipe) or if the air can't get into the stand pipe. The final thing to check is for foreign objects in the pump to drain hose area that block the drain. (This requires getting into the pump and disconnecting the hose. Keep a bucket ready to catch the water that will pour out of the washer.)
GE has the manuals for many of their appliances on their support site: http://www.geappliances.com/service_and_support/literature/ . Enter the model number and click submit. The direct link to the manual for the WSXH208V1WW is http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90256.pdf .
I hope this helps.
(at least my washer won't spin if the water can't pump out. On a few washers (non-high efficiency) the solenoid has failed to open for the pump to drain the water.)
Nov 22, 2011 | Washing Machines
Washer washes but won't drain and won't proceed through the rest of the cycles. It just humms.
hi it sounds like your pump is blocked have you tried cleaning your filter these pumps are magnetic and will sit and hum if blocked
Nov 15, 2011 | Washing Machines
Washer Flashing Error Code ND; door won't open after turning washer off
The ND error code means NO DRAIN. ,
The usually reason the door remains locked once the cycle is over is because the filter screen on the drain pump is blocked so not all the water could drain out...the door lock is tied into the pump and until the pump tells the control board that the wate r is out the door will not unlock. This tip i wrote will show ya how to take apart the washer to clean the filter on the pump.
http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Sep 23, 2011 | Maytag MAH8700A Front Load Washer
My washer did fill, but won't spin or drain now and the door won't open
Hi tragz,
If it can't drain, it won't spin. There may be something preventing the pump from draining in the Pump filter. You will need to clean it.
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
Front loading washer, kenmore 417.42052100 won't completely drain and leaves a tub full of water. Has been getting worse over the last week and now won't drain at all. Took off front panel to try...
The drain filter/coin trap is blocked or the pump is no longer working. The filter/trap is located inside the big black hose that runs from the bottom of the tub to the pump and hence the name tub-to-pump hose. Clean the filter and inspect the pump impeller for damage or restriction.
Disconnect power then remove the screws attaching the bottom front panel to the cabinet then pull the panel down and off. Once the panel is off, you can now loosen the clamps securing the tub-to-pump hose to the bottom of the tub and the pump's inlet then take the hose out and clean the filter/trap.
You should find foreign objects such as coins, toothpicks, hairpins and the likes blocking the filter. Clear the filter from the foreign objects and inspect the pump impeller by turning it with your finger. The impeller may be restricted or damaged resulting in the water not being pumped out properly or none at all. Replace the pump if the impeller is broken or restricted and doesn't turn freely or if the pump is no longer operational. You can tell the pump is no longer operational if all are clean and the impeller is in good shape and turning freely. Reassemble the machine by following the steps above in reverse order.
When installing the filter in the coin trap, the top ring of the filter MUST be seated in the 3rd convolution from the bottom.
Jun 20, 2011 | Washing Machines
LG WM1814CW Front Load Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
