Question about Kenmore 24042 Top Load Washer
Is a kenmre 90 plus series belt drivin - Kenmore 24042 Top Load Washer
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
Could you please describe the problem you are having a little better?
Posted on Nov 06, 2012
2002 isuzu rodeo cylinder head torque lbs. for 2.2
Print
Removal & Installation
2.2L Engine
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Drain the cooling system.
  3. Relieve the fuel system pressure.
  4. Remove or disconnect the following: Negative battery cableIntake Air Temperature (IAT) sensor connectorPositive Crankcase Ventilation (PCV) valve and hoseAir intake assemblyUpper radiator hoseAccessory drive beltExhaust front pipeAlternator and bracketsCrankshaft Position (CKP) sensor connectorKnock sensor connectorHeater hosesWater bypass hoseFuel linesEvaporative Emissions (EVAP) valve connectorCanister hoseIntake manifoldEngine wiring harness connectors at left rear of the engine compartmentPower steering pump pressure switch connectorFront coverSpark plugs and wiresCamshaft Position (CMP) sensorValve coverTiming belt. Refer to the Timing Belt unit repair section.Timing belt idler pulleysTiming belt rear coverOil pressure switch connectorCamshaftsCylinder head. Remove the bolts in reverse of the tightening sequence.
    Negative battery cable Intake Air Temperature (IAT) sensor connector Positive Crankcase Ventilation (PCV) valve and hose Air intake assembly Upper radiator hose Accessory drive belt Exhaust front pipe Alternator and brackets Crankshaft Position (CKP) sensor connector Knock sensor connector Heater hoses Water bypass hose Fuel lines Evaporative Emissions (EVAP) valve connector Canister hose Intake manifold Engine wiring harness connectors at left rear of the engine compartment Power steering pump pressure switch connector Front cover Spark plugs and wires Camshaft Position (CMP) sensor Valve cover Timing belt. Refer to the Timing Belt unit repair section. Timing belt idler pulleys Timing belt rear cover Oil pressure switch connector Camshafts Cylinder head. Remove the bolts in reverse of the tightening sequence.
To install:
Fig. Cylinder head torque sequence-2.2L (VIN D) engine
NOTE Use new cylinder head bolts for assembly.
  1. Install the cylinder head with a new gasket. Tighten the bolts in sequence as follows: Step 1: 18 ft. lbs. (25 Nm)Step 2: Plus 90 degreesStep 3: Plus 90 degreesStep 4: Plus 90 degrees
    1. Step 1: 18 ft. lbs. (25 Nm)
    2. Step 2: Plus 90 degrees
    3. Step 3: Plus 90 degrees
    4. Step 4: Plus 90 degrees
  2. Install or connect the following: CamshaftsOil pressure switch connectorTiming belt rear coverTiming belt idler pulleys. Tighten the bolts to 18 ft. lbs. (25 Nm).Timing beltValve coverCMP sensorSpark plugs and wiresFront coverPower steering pump pressure switch connectorEngine wiring harness connectors at left rear of the engine compartmentIntake manifoldCanister hoseEVAP valve connectorFuel linesWater bypass hoseHeater hosesKnock sensor connectorCKP sensor connectorAlternator and bracketsExhaust front pipeAccessory drive beltUpper radiator hoseAir intake assemblyPCV valve and hoseIAT sensor connectorNegative battery cable
    Camshafts Oil pressure switch connector Timing belt rear cover Timing belt idler pulleys. Tighten the bolts to 18 ft. lbs. (25 Nm). Timing belt Valve cover CMP sensor Spark plugs and wires Front cover Power steering pump pressure switch connector Engine wiring harness connectors at left rear of the engine compartment Intake manifold Canister hose EVAP valve connector Fuel lines Water bypass hose Heater hoses Knock sensor connector CKP sensor connector Alternator and brackets Exhaust front pipe Accessory drive belt Upper radiator hose Air intake assembly PCV valve and hose IAT sensor connector Negative battery cable
  3. Fill the cooling system.
  4. Start the engine and check for leaks.
  1. Before servicing the vehicle, refer to the Precautions Section.
    Negative battery cable Intake Air Temperature (IAT) sensor connector Positive Crankcase Ventilation (PCV) valve and hose Air intake assembly Upper radiator hose Accessory drive belt Exhaust front pipe Alternator and brackets Crankshaft Position (CKP) sensor connector Knock sensor connector Heater hoses Water bypass hose Fuel lines Evaporative Emissions (EVAP) valve connector Canister hose Intake manifold Engine wiring harness connectors at left rear of the engine compartment Power steering pump pressure switch connector Front cover Spark plugs and wires Camshaft Position (CMP) sensor Valve cover Timing belt. Refer to the Timing Belt procedure. Timing belt idler pulleys Timing belt rear cover Oil pressure switch connector Camshafts Cylinder head. Remove the bolts in reverse of the tightening sequence.
To install:
May 26, 2012 | Isuzu Rodeo Cars & Trucks
Kenmore 90 Plus Series washer washer takes forever
is the cold water all the way on?
if so, the first thing to do would be to check the screens in the cold water fill hose and the screen in the cold side of the water valve on the back of the machine. if that is not the problem then replace the water valve.
(turn the water off before taking the hose loose)
Jun 16, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I HAVE A KENMORE 90 PLUS SERIES DRYER. IT DOES
check the door switch and also check the belt,if the belt breaks there is a switch inside that turns the dryer off
Mar 19, 2010 | Kenmore Dryers
My Kenmore 90 Plus Series dryer runs (you can hear it when you turn it on) but the drum does not spin. What could this be?
broken belt,remove the bottom panel and get down there with a flash light and see if you can see or feel the belt-mike
Mar 01, 2010 | Kenmore Dryers
Error codes
Kenmre HE2 Plus front loader has a F 28 error. Whats the problem and how do I fix it?
Jan 19, 2010 | Kenmore HE2 Plus Front Load Washer
There is a clicking sound when you press start.
If you heat a click when you push the button,but the drum doesnt turn your belt is broken. About $15 and simple to install.
Oct 20, 2008 | Kenmore 63942 Dryer
Kenmore 90 plus series dryer won't work
Sounds like the belt has broken. You could probably also use new drum support rollers. Check out this site which shows how to change a dryer belt:
http://repair2000.com/wpoolbelt.htm
It's not a difficult job if you're comfortable working with hand tools.
Oct 17, 2008 | Kenmore 62872 Electric Dryer
Kenmore series 90 soft heat extra capacity plus
hi you could have a broken belt or a faulty thermal fuse
Aug 23, 2008 | Kenmore 62602 Electric Dryer
Kenmore 24042 Top Load Washer Logo
15 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
