Question about Coffee Makers & Espresso Machines
No water going to coffee part of vitale s machine
  • martin downey Nov 08, 2012
    found the problem, i had turned the grinding knob too tight, just had to turn it anti clockwise ten rotations.
  • Coffee Maker... Master
  • 1,238 Answers
Faulty pump
Posted on Nov 06, 2012
Water light not going out, even when full. Not able to make coffee
the water tank has a float inside, the float has a magnet. the machine senses the position of the magnet and indicates water ok/not. sometimes the magnet rusts inside the plastic casing, renders it less magnetic so it wont work. or the float is missing- fell out while you were cleaning the tank. you will need a new magnetic float to fix the problem.
Feb 11, 2014 | Saeco Incanto Classic Espresso Machine
No water flow
The hot water works, but when I run coffee, the water only goes into the used BIN, NOT the spouts. I can't get the water to go through to brew the coffee..
HELP
Feb 04, 2014 | Krups Orchestro 889 Espresso Machine
Vitale S coffee machine
Looks like you need to descale your machine. A good cleaner is CLR. Follow the instructions on the bottle. If you don't want to purchase that, use white vinegar. Fill up the reservoir and run a brew cycle after letting sit for 20 mins. Make sure u run clean water threw at least 3 cycles once done
Apr 28, 2013 | Coffee Makers & Espresso Machines
Leaking coffee grounds and water
HI
There should be a small amount of coffee residue and about an oz. of water going into the drip tray. This is the pressure relief process, when the machine finishes the coffee making. If it didn't release the pressure thhis way you could have an explosion of coffee when it cycles back.
Jan 04, 2010 | Saeco Vienna Espresso Machine
Overflow of carafe
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine nor too course. (See instruction manual and/or do an Internet search for tips.)
3. Do not overfill with water. Use the carafe to pour water into the reservoir, and the lines on the side of the indicator window as your guide. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz. Therefore, a 12-cup machine may make as few as nine 8 oz mugs of coffee.
4. Make sure the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve feature, if applicable, isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. It is vitally important to clean your machine with vinegar or as instructed by your user manual at least three times per year and monthly if under heavy use in a hard-water area. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket as the water runs through the grinds.
9. Ensure that the coffee machine is sitting level on the counter.
Dec 03, 2009 | Waring Pro WC1000 Coffee Maker
Low water light stays on
If water light and heating lights go on and off, Try this: Fill water, turn water nozzle on, let water flow out. Water light should go off. Shut off water.
If coffee lights are solid, turn off the machine, let it cool off and try the above again.
Jul 07, 2009 | Gaggia Syncrony Compact Coffee...
No coffee
Make sure the water pipe not is broken.
If you take out the brewing unit and look at the chassis on the machine, you can see a hole, there should be a little plastic pipe comming from the machine down to the hole. If this is broken then the water will go to the driptray.
/Mirran
Aug 14, 2008 | Saeco Vienna De Luxe Espresso Machine
Gaggia cffee machine will not pump water through th coffee
my gaggia coffee machine, will not pump water trough the coffee. I see the water going back in the reservoir. I used the cleaner cafiza, but no help. Please help.
Thank you
Jul 06, 2008 | Gaggia Classic Brushed Stainless Steel...
Coffee Makers & Espresso Machines Logo
37 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
