Question about Alesis TransActive Drummer Electronic Drum Amplifier
Where can i get parts for alesis
The power switch wont turn over?do i replace the switch or is there a fuse somewhere?..also the glass bulb on the motherboard behind the actual sub cracked..where can i find replacement parts
    Problem Solver:
  • 17 Answers
Doubtful you can find replacement parts it, but a clever electronics guy can bypass the switch (or put on a new one) and make it so it powers up when you plug it in.
Posted on Oct 16, 2013
2 Suggested Answers
SOURCE: Alesis Multimix8 started smoking and now won't turn on. If it is a fuse or something how do i replace it?
A blown fuse will not produce smoke. A component failed and probably fried a resistor, which would smoke. That in turn would blow the fuse.Just replacing the fuse will not cure the problem. Your unit needs repair.
Posted on Dec 27, 2012
Alesis Quadraverb Q2. When I turn on Alesis Q2 the programs 1-100 preset are working but when I turn on programs 200-300 user It does not work. There is only "bad program" characters on display.
The Problem is a dead battery which is soldered to the circuit board inside the unit. It's a Panasonic BR-2325-1HC, but really you can replace it with any similar 3V battery.
Here's how I fixed mine.
http://andrewapeterson.com/2013/08/fix-alesis-q2-first-made-strange-sounds-then-bad-program-issue-quadraverb-2-battery/
Feb 07, 2013 | Music
Connected alesis sr16 with alesis 110v power supply.to 240v mains...........briefly powered up and then nothing. Have I "fried" the adapter or the sr16?
Look carefully at the adaptor and see if it takes any voltage besides 110 (it will say in very tiny print, you will need a magnifying glass). if it does NOT say 220V or 240V then you friend the adaptor. Get another adaptor - most are "dual" voltage meaning they run in the U.S. or overseas.
Also check for "polarity" (which part of your plug is + or - ).
Jan 24, 2013 | Alesis Sr 16 Stereo Drum Machine
Dec 27, 2012 | Alesis Multimix 8 USB 2.0 - 8 Channel...
I recently got a Marshall mg100hdfx head for free because it wont turn on, so I am investigating possible parts that may need replacing. The only description I got as to why it wont turn on anymore is...
You may find almost anything in this. I think the power amp is on a separate board so the connections to that might have been broken. Possibility include cracks in the circuit board. First thing is to do after visual check is to check power supply voltages to verify power switch/fuse/transformer/rectifier/capacitor/regulator health. Switches are sometimes damaged... and also wires can fall of or break.
May 02, 2011 | Marshall MG100HDFX 100-Watt Amplifier Head
MY ALESIS DM5 WAS PLUGGED TO 220V AND AFTER A WHILE STOP WORKING ( IT IS FOR 110 V ) IS ANY FUSE I CAN REPLACE?
Hi pcruzx,
Sometimes replacing the fuse alone with exact voltage and ampere ratings will cure the problem(you're lucky) but not all. Sometimes further damaged gone to other parts most especially the voltage regulator transistor/IC (mounted in heat sink) and the opened the fusible resistor in line with the supply(B+).
First check the fuse, for sure it was already blown. If you've replaced the fuse and immediately blew again after powering on the unit, this was an indication of shorted parts near the AC line. Click this LINK for more info.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
May 01, 2011 | Alesis Dm5 Drum Module 18 Bit
Hye. When i switch the on button, the power indicator didnt turn on. Is it because of the tubes or the transformer?
Most likely you blew a bus fuse. Can't say you should open it up and replace it though because there are lethal voltages inside of your amp that could hurt or kill you. You can find replacement bus fuses at radio shack. just make sure you get the same rated fuse. 500mA 125v or something like that in small writing on the metal part of the tiny glass cylinder.
Dec 11, 2010 | Orange Amps Orange Amplifiers TT15C Tiny...
Broken amp
Why did you replace the fuse? If it was blown then you need to take the amp in for servicing. Iffthe fuse is glass and it was silvery on the inside, that is a hard short and is likely a power supply problem. Probably a rectifier diode or filter cap. Pray that it isn't the power transformer. Diodes are cheap... few pennies... caps a few bucks at most. Power transformer... you DO NOT want to know.
Mar 13, 2010 | Fender Hot Rod Deluxe Guitar Combo...
The sr-16 powers up briefly then shuts off, I'm using a new AC adaptor ,music store repairman say it's unrepairable ,it's only 2 years old,what gives?
There has to be a component inside that is faulty. That causes the power supply to quit. If the repairman said it is not able to be repaired it means that the part can't be replaced due to unavailability or the cost. You could try taking it to another repairman at a music store that sells Alesis products if you aren't satisfied with his his answer. SR-16 s are pretty reliable and it takes a lot to damage them to the point where they can't be repaired. If you can't get it repaired locally and you think it can be repaired contact Alesis at http://www.alesis.com/content1024 to find out the closest place to ship it to and get it repaired.
Jul 09, 2009 | Alesis Sr 16 Stereo Drum Machine
Blown fuse and replaced it and burned the amp
BIG problem! You should NOT have replaced the fuse as additional damage has been done. I repaired a PMP5000 and I can tell you likely what you will find: The smoke and smell came from two power resistors that are part of the soft start circuit that now are toast. You will likely find several components in the main portion of the power supply that are toast. These will include transistors, resistors, diodes, and probably the small 8 pin switching regulator chip. There is a small power supply that comes on first which enables a relay that shorts out those soft start resistors AFTER the power amplifier BALANCES and normalizes.
The unit I repaired had severe damage due to arc-over at one power amp section. Three power transistors were destroyed there and board traces and charring had to be handled in that section.
The repaired unit had to be brought up with a light bulb in series with the line power cord to prevent further damage until all bad parts were discovered and repaired. You will need to take the unit to a shop that is expperienced with the product. The repair cost MAY be pretty high.
Mar 08, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Alesis TransActive Drummer Electronic Drum Amplifier Logo
118 people viewed this question
Top Alesis Music Experts
Michial Gueffroy
Bernie Scott
Level 1 Expert
Will Halftowaite
Are you an Alesis Music Expert? Answer questions, earn points and help others
