Question about Estate TEDS840JQ Electric Dryer
How can you tell if the thermal fuse is defective
    Top Expert:
  • Estate Master
  • 9,472 Answers
You can check it for continuity. But if the dryer won't run and you have power to it, that is also a sign that the fuse is bad.
Posted on Nov 06, 2012
My whirlpool duet dryer has no heat but turns on and spins with cold air. I cleaned vent and removed toe plate. If it is thermal fuse problem will the igniter glow still? I found a penny lodged on the fuse...
see this causes and fix it. I am supposing the dryer is gas because you are telling the igniter?
God bless you
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Sep 28, 2012 | Dryers
Dryer will not heat gas
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse.
1. Gas valve coils
2. Thermal fuse
3. Igniter
Oct 28, 2009 | Whirlpool GGQ8831L Gas Dryer
Workes fine no heat
the temperature thermostats and or heater are bad, on electricdryers, you can ohm out to see what is defective.
There's no heat dot_lineone.gif 1. Gas valve coils
2. Thermal fuse
3. Igniter
electric dryer
1 Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
2 Thermal fuse
Oct 27, 2009 | Candy CDC266 Dryer
Not heating up
1. Gas valve coils igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
2. Thermal fuse Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
3. igniter igniter may burn out or break. Replace the igniter if found defective.
4. Flame sensor (or radiant heat sensor) Replace the sensor (located near the igniter) if found defective.
Sep 24, 2009 | Roper RGX4634KQ Gas Dryer
Not heating
1. Gas valve coils
2. Thermal fuse
3. Igniter
Sep 10, 2009 | Kenmore 73952 Gas Dryer
Won't dry clothes
1. Gas valve coils
2. Thermal fuse
3. Igniter
Aug 16, 2009 | Whirlpool LGB6300 Gas Dryer
IGNITOR GLOWS BUT THERES NO FLAME
1. Gas valve coils
2. Thermal fuse
3. Igniter
Aug 04, 2009 | Dryers
Doesn't heat
1. Gas valve coils
2. Thermal fuse
3. Igniter
Aug 01, 2009 | LG DLG5932W Gas Dryer
My gas maytag dryer won't heat?
1. Gas valve coils
2. Thermal fuse
3. igniter
Jul 10, 2009 | Maytag Dryers
Estate TEDS840JQ Electric Dryer Logo
344 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
