Question about Roper RES7646KQ Electric Dryer
Roper electric dryer wii not start - Roper RES7646KQ Electric Dryer
  • 1 more comment
  • joelsemling Feb 23, 2009
    my roper dryer will not start. Changed the heat sensor last month. Made sure that the exhaust duct is not kinked. Power to the dryer is good, no popped c/b. What next to look at?
  • Anonymous Mar 01, 2009
    My roper dryer won't start, it is only 2 years old, power to dryer is good, but won't start.
  • brusgang May 11, 2010
    Did you check to make sure your circuit breaker did nto trip. Go check it. Do you have power at the wall outlet. (check it with a ohm meter)? Do you have power at the dryer check it. If all these are good now we can start on the dryer.
  • Roper Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Posted on Dec 05, 2010
Roper dryer will not start
How to Troubleshoot a Roper Dryer That Will Not Start ' Home Guides ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Jul 14, 2016 | Roper Dryers
I push button to turn on it starts to turn that fan with a loud noise then sometimes starts then shuts off after a few minutes..please help me..its a roper 5 cycle electric
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 14, 2011 | Roper REX4634KQ Electric Dryer
Push start button and nothing happens on roper dryer how to check button to see if working
A dryer can not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 06, 2010 | Roper RES7646KQ Electric Dryer
Roper electric dryer replaced timer
check the door switch if that is bad it will not start if that is ok there is a white fuse on the blower houseing in the back check it with an ohms meter
Mar 16, 2009 | Roper REX4634KQ Electric Dryer
Dryer won't start
IT SOUNDS TO ME AS IF YOU HAVE A BAD DOOR SWITCH. YOU CAN TRY JUMPING THE SWITCH OUT TEMPORARILY JUST TO SEE IF THE UNIT RUNS.
Mar 07, 2009 | Roper REX4634KQ Electric Dryer
No start
Hi thanks for your question. the most probable caues , Is the thermal fuse. Its located on the air duct at the back of the dryer.. remove the back. Look for a small plastic piece on the air duct. 2 blue wires to thi thermal fuse. replace this part. It wii fix the problem. The appliance doc
Jan 06, 2009 | Roper RGX4634KQ Gas Dryer
Roper dryer will not start it is electric
The thermal fuse is probably open again, This condition is caused by restricted air flow out the vent system. Replace thermal fuse again and clean the vent hose and vent hood outside
Jan 05, 2009 | Roper REX4634KQ Electric Dryer
Roper Dryer
Hi thanks for your question. When a dryer growles at you like that. Its a sign of a bad motor. To repair the dryer replace the motor
Oct 28, 2008 | Roper REX3614KW Electric Dryer
Roper RES7646KQ Electric Dryer Logo
165 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
