Question about JBL GT150 Car Subwoofer
My amp was bad so i replaced it now my sub does not work i checked the wiring that goes from the amp to the speaker and everything seem to be ok then i put another speaker thinking it might be the sub and it still doesnt work does anyone have any suggestion
  • jazmin062604 Jan 06, 2009
    I want to thank dantechcom I took my stereo out and went through all my wiring and the remote wire was lose the one that connect to the stereo i guess who ever connected it didnt do a very good job
    thanks again
    President:
  • 846 Answers
It doesn't sound like the wiring from amp to sub is your problem.
Is your amp getting a power light ?
Are you sure your remote wire is hooked up properly ?
Check both ends of your RCA cables
Posted on Jan 05, 2009
I have 2 amps instalkled in my car one is sony 1200w 2 channel amp for speakers and one is solid audio f2500d for 3 subs my sound and every thing was good but suddenly from yesterday im having trouble when...
First disconnect the CD head unit from the sub amp and see if the other amp works. If yes, the problem is the wires to the amp, the amp itself, or the subs/sub wiring. If no, the problem is the head unit--probably an internal short.
If the other amp works with the sub amp disconnected, reconnect the sub amp to the head unit, but disconnect the sub wires from the amp. Try the CD player. If the amp goes to protect with no speaker wires attached, the amp is bad. If the amp is OK, the problem is the subs or sub wires. Hook the wires up to the amp again, but disconnect them from the speakers. Try the player again. If the amp goes to protect, the problem is the amp wiring. If not, the problem is the subs. Check the impedance of each sub using an ohmmeter to determine which amp is out of spec.
Please let me know if you have questions, and thanks for using Fixya.
Jun 11, 2011 | Solid Audio F2500D 1-Channel Amplifier Car...
Got a problem with my car amp.Everything was working fine until 2day.Amp goes in to protection mode.Jumps from power to protection indicator every i would say 3 seconds and each time it goes in to...
Ok check the remote wire running from the headunit to the amp should be giving v12 feed whiles headunit is on.
check or change grounding position.
take cover off the amp as the circuit may be over heating.
Sep 22, 2010 | Car Audio & Video
No sound from subwoofer Solo Baric L7
check the resistance of the sub with a digital multi meter, make sure you dissconect the sub from everything before you check the resistance, if your sub is supposed to be 4 ohms than it should be between 3-5 ohms, if it is under 1 that the sub is blown, while the sub is dissconected from the amp, turn the system on, does it still go into protection?
Jan 17, 2010 | Kicker Solo-Baric L7 10'' Car Speaker
Hi ive just bought a 2nd hand sub n amp,wired them up and i can only get the amp 2 work,my other subs work plugged into the same amp just to check but the xplod wont,im not getting anything wot so ever,i...
Hello empsglen,
If the sub voice coil is open, you will get exactly no sound. No crackling, nothing.
Use a multimeter to check the sub voice coil. If the meter reads infinity, the coil is open and to the amp, it's as if there's no sub connected, and you will need to replace it.
Hope this helps.
Jul 15, 2009 | Sony Xplode P5 Turbo Subwoofers Car...
Wiring issues
ok here is how it goes power wire from the battery all the way to amp..then ground wire from amp to a good ground on car then the remote wire which you have to run from the amp to the back of your stereo which in most cases is blue then hook subs from the sub box to the amp
May 30, 2009 | Legacy 2 Channel 1600 Watt Bridgeable...
Subwoofer buldging out problem
When speakers are wired in the wrong way the will do the "pushing out" you're describing. Basically the polarities have been reversed and if kept like this over a period of time will blow the speaker. Best thing to do is to disconnect the power by the negative on the amp and take out the fuse from the power supply. Check the wires running from the amp to the subs, negative to negative and positive to positive. I know it sounds basic but many people do mix it up! I would also check to see what channels the subs have been wired into?
Best way is to have one sub from channel 1 and the other sub from channel 2 for example. Or if its a bridged 4 channel amp, have 1 sub running from channel 1&2, and the second sub running from channel 3&4 still making sure of the polarities. Again this all depending what kind of amp and sub you have.
For example;
A 4 channel (bridged) 1000W amp. 250W max per channel or 500W per 2 channels! So if you have 2 500W subs, by connecting one to a single channel will decrease subs ability due to the lack of power supplied. However by combining 2 channels you optimize the output!
Once you know all your wiring from your amp to subs are ok/good connections/good wires etc you shouldnt have to "wiggle the wires" to get it to work as this is just a bad connection. Also ensure that no 2 wires are touching. Make sure that the master volume on the amp is turned down. You dont need this to be on loud at all, in fact far from it or you'll risk damaging both the amp and subs!
Hope this helps!
May 27, 2009 | Car Audio & Video
Amp doesn't come on
Hello rheabarb,
You did not say whether or not you checked the wiring going to your subs. Many times, a shorted or grounded speaker wire will cause an amp to fail. And if the amp powers up OK with the subs disconnected, I'd suspect one or more of the wires.
Hope this helps.
May 19, 2009 | Clarion APX1300 Subwoofer Mono Amp - 300W...
Subwoofer/speakers are hooked up to my amp but making bad noise
it sounds like you have some wires crossed or a bad ground
Hope this helps
Jan 25, 2009 | Kicker CVR12 Car Subwoofer
Could a ground stop your woofer from working?
First check the speaker wire from the amp to the sub, see if it's connected right. Second check the rca cables that goes from your amp to the back of the deck. I f both wires are still connected fine try to replace the rca cables. If it still doesn't work the rear out put at the back of your deck, where the rca's are connected are bad. FYI deck is bad.
Nov 29, 2008 | Jl Audio 12W3 Car Subwoofer
Ok this problem is killing me...
maybe the speaker is bad
First try one thing, switch the rca jacks around and see if the other speaker stops working this time.
If so the problem is in the rca jack or head unit.
If the same speaker is still not working, the problem will be the speaker, you will have no other options left since you changed amplifiers and checked all wiring.
Let me know if this helps you
Jun 18, 2008 | Visonik Dual Bass Box with Amplifier Car...
JBL GT150 Car Subwoofer Logo
126 people viewed this question
Top JBL Car Audio & Video Experts
hoyzee1
Rob Beech
Mark Skinner
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
