Question about Craftsman 4 Cycle Blower/Vac
Got a craftsman leaf blower cranks up and runs fine for about 5 mins then starts losing rpms
Craftsman leaf blower 4cycle cranks but after 5 mins starts losing rpms and dies out
  • 430 Answers
ITs hard to diagnose these things over the internet, it could be so many things.
Is this a gradual loss of power? If so; Im sorry to say; that it sounds like its losing compression as it warms up. It is not cost effective to repair the unit.
If the loss of power is more sudden it could be a failing ignition module. Ive even seen spark plugs that quit working when they get hot.
To test this you will need a proper spark tester, laying the spark plug against the head will not provide an accurate assesment, and a can of carb cleaner. Run the unit with the air box cover and filter removed till it fails and immediately give a shot of carb cleaner in the carb and restart. If it starts right up it could be fuel related. IF it doesnt start right up then quickly test for spark. If no spark then its likely the ignition module. If it wont run on the extra fuel and it has spark then it has probably lost compression.
Posted on Nov 12, 2012
Managemylife com sears
Check for spark if u have pour a small amount of gas in carb it should start also check air filter if runs then stops carb problem . Spray some carb cleaner then re try
Jul 20, 2014 | Craftsman 29cc 4Cycle Straight Shaft...
Stay running
The carburetor needs to be adjusted very slightly, with a special tool. If still under warranty bring it to the Sears repair center quickly before you damage the engine.
Jul 07, 2013 | Craftsman 29cc 4Cycle Straight Shaft...
My 29cc 4 cycle craftsman gas trimmer loses power when I increase the throttle
While Holding the Engine at Full Throttle, Adjust the High Air Mixture Screw In Until the Engine Revs Properly.
Jul 01, 2011 | Craftsman 29cc 4Cycle Straight Shaft...
Handheld 4cycle blower stops after 5-10 min- hard to start then- starts ok when cold-oil a little low & grey
Address the oil situation immediately. Oil should never look "grey" in color. Get the proper weight of oil for the machine. I recommend synthetic always be used. Advance Auto Parts sells synthetic under their store brand, comparable in cost to name brand conventional oil. Keep a close eye on the color and level of the engine oil. Synthetic will clean the engine real well, so be prepared to change it again.The machine is probably stopping because it is getting hot from poor lubrication.
Jun 08, 2011 | Troy-Bilt 32cc 4Cycle Backpack Blower
Leaf blower starts and runns ok for few mins then
Target your inspection towards the 'spark arrestor screen' in the outlet of the muffler.
Overfuel or 'rich' condition
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check Air filter for fuel saturation
4) Allow engine to run for 5 minutes to excess fuel from muffler
5) Fuel mixture ratio: Make sure the oil mix is per your manufactures recommendations
6) If after the above the engine is still smoking and blubbering:
Adjust carb mixture screws to a 'less rich' setting
*NOTE: only move mixture screws 1/8 of a turn at a time,
and try operation before any more adjustment
Nov 13, 2009 | Craftsman Garden
My craftsman 205mph leaf blower starts and runs for 4 min stalls
Replace the fuel filter that is inside the fuel tank. Purchase a can of Seafoam Motor Treatment. Ask for it at most auto parts stores and WalMart. Pour in the correct amount as listed in the instructions, and fill the tank with fuel. Start the blower and run it wide open. If your problem is a fuel system problem this may very well solve the problem. This is one of the best fuel system cleaners you can buy.
Nov 07, 2009 | Garden
Hi. My craftsmal leaf blower runs OK for 3-5 then dies????
Could be a blocked vent on your fuel tank - is there a vacuum in the fuel tank immediately after it stalls?
Oct 25, 2009 | Craftsman Garden
Leaf blower problems
You may have a dirty fuel filter, or carb needs cleaned.
Mar 19, 2009 | Craftsman Garden
Craftsman 4 Cycle Blower/Vac Logo
452 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
