Question about Haier TN201AUV 20" TV
Cannot get DTV stations on my Haier TN201auv 20" TV
Have purchased a converter box, hooked up and still cannot get picture, I am using outside antenna and in some cases rabbit ears. Any recommendations. KJG
  • Anonymous Jan 13, 2009
    Cannot pick up DTV stations on my Haier HL19E 19 inch. Have a HD box connect and still cannot pick up any stations.
Benimur
  • 6966 Answers
SOURCE: need code for "20" Haier tv model tn201auv for rca guide plus+gem
Hi again,
It would seem that you posted multiple times.
For the manual of an RCA CRK76TA1 remote control, pls click here. It is a pdf file and would require Adobe Acrobat reader.
Offhandamnot sure if an RCA remote would work with a Haier television. Youcouldof course still try: 140 191 0000 10748 0001 002 003 004 005 006085 086223 323 2000.
Just a start, do postback how thingsturned up or should you need additional information. Good luck andThank you for using FixYa.
Posted on Dec 04, 2008
SOURCE: Haier TN201AUV 20"
The GE Universal Remote will do the job. I have on and it works for my Haier TN201AUV TV. You can also find a replacement Haier remote on Remote Hound's web site.
On the other side of this I have a Dish Network remote that WILL NOT work. The Dish Network remote does not list any codes for Haier. Dish Network Tech Support could offer no help.
In an attempt to solve the problem myself, I looked on-line at GE's site listing all of the manufacturers' for their remotes and found the identical code that worked for my Haier TV also listed under APEX TV's. The Dish Remote lists (11) APEX TV codes. Ironically, NONE OF THEM WORK!
I'm stuck with using both remotes... and that's BULL$H!T
Posted on Jan 25, 2009
ansilgregory
  • 4 Answers
SOURCE: My analog color TV,Sony 20S10, 14 years old, has
are there screw terminals that it connects too? if not but the wire is exposed like you said splice into it add in one of the transformers that has the rf end on the end of it. i would recomend some strain relief
ed
Posted on Mar 12, 2009
  • 30 Answers
SOURCE: Digital Converter connection with old Rabbit Ears TV
First, make sure your connections are right. The rabbit ears need to be disconnected from the TV and reconnected to the converter box. Then the output cable from the converter box connects to the TV. Then try turning the rabbit ears or re-locating them near a window if the wire is long enough. You should be able to get some signal. A newer indoor antenna may help you pull in some of the weaker stations.
Posted on Jun 15, 2009
SOURCE: Indoor antenna problem with Magnavox LCD TV Model 15MF605T/17
I have found most of these indoor antennae to be ineffective and a waste of money, however, I do not know anything about this particular antennae. I to have a Dish DTVpal, which I love! It's ugly and probably won't fit in your kitchen, but the best solution is to make your own "bow-tie" antennae, mount it indoors or on the roof and run a cable to the kitchen. Directions can be found on You-Tube. I live in SE Idaho (Pocatello) and can get 13 channels, most without having to adjust the antennae.
Posted on Feb 26, 2010
How do I reset the screen size on the Haier TN201AUV?
To reset the TV to its original factory settings, you have to enter its service mode. If you wish to get more, check this link. http://electronicshelponline.blogspot.com/ Pull up previous posts, either by entering the brand name to your device in the search box of the display window, or view it in Mosaic / Flipcard / Timeslide option.
Aug 20, 2013 | Haier TN201AUV 20" TV
Haier tn201auv have picture but no sound
Check the interconnection cables for firmness. Check the audio inter connection cable for internal conductor break. Check with a new cable.
Jun 09, 2012 | Haier TN201AUV 20" TV
Toshiba 20AF42 is the tuner Digital or Analog? Chassis M3K62
This tv is a Analoge tv.Only can be able to used with CABLE,SATALITES or some other pay tv services to able to get a picture.Can't used the alone trying to recieving the DTV free AIR signal,will not work.Only way to get free AIR DTV to work for this tv is.This tv must have a Digital Coverter box hook up.The free AIR broadcasting signal must go through the tv Digital Converter box to be able to watch Free AIR DTV channels broadcasting.
Sep 04, 2011 | Toshiba 20a43 20" TV
Is this model, RCCA 20f512t, a digital model?
No,This tv is a CRT tv-(Tv Tube).All small tvs with CRTS design are analoge tvs.Tv must have a Converter box to convert for analoge tv to DTV signals to recieve for free broadcasting DTV tv stations signal.Must have pay signals like satalite Dishes,Cables or Telecoms signals.This tv can be use without a Converter box.
Jul 02, 2011 | RCA 20F512T 20" TV
I want to play a vido with the digital converter box and can't seen to get it to work what are the directions to make it work with TV converter box and viedo tape?
Hook up the DTV converter box to the channel 3 on the tv for the free air DTV broadcasting.The VCR use the AV component cable Y,R,W hook up to the VCR to the converter box to play VHS tapes.
Oct 20, 2010 | Philips Magnavox 20MT133S 20" TV
Digital tv not picking up digital signal??
According to the manufacturer, the EWL20D6 Television is not digital ready. If that is the case then you will have to use a converter box in order to receive the digital channels.
Dec 20, 2008 | Emerson EWL20D6 Television
Need code for "20" Haier tv model tn201auv for rca guide plus+gem
Hi again,
Dec 04, 2008 | Haier TN201AUV 20" TV
Haier tv code?
I found a code for it on auto search 226
Apr 01, 2008 | Haier TN201AUV 20" TV
Haier TN201AUV 20"
Dec 01, 2007 | Haier HTF20R21 20" TV
Haier TN201AUV 20" TV Logo
Top Haier Televison & Video Experts
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
