Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Replacing a Williamson (White Rogers) Termostat
I just moved to a new home and want to replace the original mercury thermostat with a programmable one.
The original thermostat is a Williamson made by White Rogers, Type 1F36-307. (No manuals to be found) It has 5 terminals with the following color of wires connected. Y - Yellow, R - Red, W - White, G - Green, 4 - Blue.
The new programmable thermostat is a Honeywell - RTH230B with the following terminals. Rh, Rc, W, Y, G.
Are the Y, W and G terminals the same on both thermostats? And does R=Rh and the 4=Rc?
  • moconfed Jun 02, 2009
    Works great! Thanks for the help!!
  • 82 Answers
Rh is power for cooling terminal and rh is power for heating terminal connect red wire to rc or rh and there should be a jumper between rc and rh if not install one all other wires are color coded correctly. now the blue wire is not used.
Posted on Jan 05, 2009
  • carl carpenter
    carl carpenter Jan 05, 2009
    rh is power for cooling terminal and rh is power for heating terminal connect red wire to rc or rh and there should be a jumper between rc and rh if not install one all other wires are color coded correctly. now the blue wire is not used.
Wiring instruction for a White Rodgers 1F78 non-programable thermostat.
The White-Rogers 1F78 thermostat is a single stage 5/2 day programmable thermostat. Home Depot has the manuals for one model of this thermostat, 1F78-151, on the product page: https://www.homedepot.com/p/White-Rodgers-Single-Stage-Digital-5-2-Day-Programmable-Thermostat-1F78-151/202771121 . The wiring diagrams are in the Installation manual. The direct link to this manual is https://www.homedepot.com/catalog/pdfimages/f9/f955280d-67a2-4502-bb94-4975cd857c0b.pdf . Emerson Climate also has the wiring diagram here: http://www.emersonclimate.com/Documents/White-Rodgers/instruction_sheets/0037-6615.pdf .
If you have a different White-Rodgers 1F78 thermostat, check for the manual at Emerson Climate by starting at http://climate.emerson.com/en-us/products/thermostats/thermostat-manuals . Click on the Enter Model Number button and start typing in the model in the search box. I found a number of models with 1F78 listed. After selecting a specific model, I found a link to the installation guide on the left side of the page, below the search box. (Note: the manual link was above the Suggested Replacement header for the models that I checked.)
I hope this helps.
Dec 15, 2017 | White Rodgers Home Security
How can I control this thermostat manually
That thing is antique. I had same one when I bought my house in 1995. Get it replaced with a newer digital. Honywell or White Rogers. At home depot for $25.00 to $40. Get one that's for heating and cooling, but not programmable. Easy to install, smaller and doesn't even have to be level since they don't use a mercury tube inside, like the old ones. Either way, here is a link to the full owner/operator's manual for your old old thermostat. --- .https://www.manualslib.com/manual/194597/White-Rodgers-1f95-71.html#manual . copy and paste it in your address box.
Dec 11, 2017 | Heating & Cooling
Connecting 2 wire thermostats to white-rogers type 1311 3 wire zone valves
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. Make sure to connect a thermostat that will power open and powered closed the zone valve. I pretty sure that the two wire thermostat that your going to connect will not be compatible. To better assist you with this further contact us directly at 18002842925.
Oct 15, 2012 | Heating & Cooling
White Rogers digital thermostat displayed "lo".
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. After replacing the battery you need to do the reset operation. If you need further assistance please contact us at 1800-284-2925.
Sep 24, 2012 | Heating & Cooling
Hi! We have a really old williamson thermostat (not sure about the model but it says t87fi89i 2 8047 [dont know if it's i or 1 either]). We want to replace it with a honeywell t87n east-to-see thermostat....
On most applications for heating the red and white wires are used,however I would check what wires are connected to terminals on old thermostat. These connectons should be labled with initial of wire color,such as R,W,G,Y or Rc. If your green wire is hooked to R or whatever just hook new thermostat up like the old one and you should be ok. Hope this helps. Thanks.
Nov 12, 2010 | Honeywell Electronic Programmable...
OLDER WHITE ROGERS PROGRAMMABLE THERMOSTAT. BATTERY INDICATOR WILL NOT GO OUT AFTER REPLACING BATTERIES. CANNOT SET UP PROGRAM. BATTERY INDICATOR REMAINS ON.PUT IN THREE SETS OF BATTERIES, STILL THE SAME.
Try removing the battery and disconnecting the "R" wire for approx 10 minutes, then reconnect and reinstall good battery........sort of like restarting a computer.......we're hoping this will reset something. If you continue to have problems and are certain without a doubt that the battery is good, then the problem is in your thermostat.
Apr 02, 2010 | Honeywell Electronic Programmable...
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
THERMOSTAT INSTALLATION
I am trying change from a Honeywell ct701A1001 to Hunter 44110 the old one has 7 wire and new one 5wires
Nov 01, 2008 | Hunter Fan Company 5/1/1 Programmable...
Replacing thermostat
What is the blue hooked up to now?
Jun 07, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
709 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
