Question about Frigidaire GLTF2940ES Front Load Washer
Frigidaire front load washes.
What is the e20 code? Bad smell from drian hose?
Good morning, No error code is given. bad smell includes coming from the hose.
Posted on Jan 05, 2009
How do you fix e20 code
Hello John, thanks for your inquiry!
From my understanding your Frigidaire front load washer is displaying an error code of "E20" and you would like to know how to fix it. An "E20" code stands for water is not pumping out fast enough this could be a problem with your drain hose, pump, or control panel. I would suggest checking the drain line to make sure it is not restricted. If the line looks clear it could be a problem with your drain pump or control panel. I would recommend seeking assistance from a professional technician for proper repairs. I hope this information is helpful. -Matt
Apr 23, 2015 | Frigidaire GLTF2940ES Front Load Washer
E20 Error
Hello Diane Snow, thank you for your inquiry!
I understand that your Frigidaire washer is displaying "E20" error code. The "E20" error code means water is not pumping out fast enough. First, you want to check the hoses for restrictions.
If the hoses are not restricted it could be an issue with the drain pump or control board. I would suggest seeking assistance from a professional technician for proper repair. I hope this is helpful. -Matt
Oct 06, 2014 | Frigidaire Washing Machines
Frigidaire front load washer (ATF6000SF1) error E20
E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
1. Restriction in the drain pump
2. Failed pump
3. Water not pumping out fast enough (crimped drain hose)
4. Too many suds ( too much detergent or wrong kind)
5. Pressure switch (not communicating with control board)
6. Loose wire at pressure switch
7. Loose wire at pump or control board
8. Failed control board
Nov 29, 2012 | Frigidaire ATF6000ES Front Load Washer
What does the error message E20 on the frigidaire front load washer GLTF2940FS mean?
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Oct 15, 2012 | Frigidaire GLTF2940ES Front Load Washer
When washer turns on there is a horrible buzzing sound, e 20 error message was on before
This is a blocked drain error code (E20) which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums, buzzes or whirs.
Error Code E20 on Frigidaire Front Load Washing Machines
Aug 25, 2011 | Frigidaire Affinity ATF7000E Front Load...
I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
Aug 20, 2011 | Washing Machines
I have an E20 code on my front loading Frigidaire gallery series washing machine, what does this mean and how does my husband fix it. Also, has anyone had problems with the matching dryer destroying...
That E20 could be a bad pump or clogged pump screen. Remove and clean out the tub to pump hose. Look for object in pump. A clogged airline to the pressure switch can also give the E20 code. The switch thinks there is still water in the tub when in fact there is crud in the end of the hose.
Hope this helps!
Nov 20, 2010 | Washing Machines
I'm getting an error signal E20 when there is about 15 minutes left in the cycle. Ive tried clearing the hose, not sure what to do??
The most common cause of an E20 error code would be a clogged or damaged drain pump. Other possible issues would be a loose wire to you pressure switch, loose wire at your control board, loose wire at your drian pump, or failed control board. This is not a specific error but from my experience the most likely cause of this issue would be a bad drain pump. Something is clogging the pump or the motor is bad.
hope this helps _MJ_
Jan 31, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Front Load Washer (E20)
remove the bottom panel ,,the pump is in the front left hand corner...unplug frist,,,you will see to black 2 in hose ,,1 is the drain hose check all the way up the line,,,the other is the tub to pump hose it has a sump on bottom ..remove everything out but dont stick your finger in it,,turn it upside down,,in case of small sharp metal object. onthejob
Dec 29, 2008 | Frigidaire FTF530FS Front Load Washer
E20 Error
On the sheet, 2 beeps and error E20 says Water Doesn't Drain. Drain hose is kinked or household drain is clogged. Straighten hoses or unclog household drain.
Jun 06, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
82 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
