Question about Honda Ems4000, Em4000, Ems4500, Eb4000 Generator Parts Catalog
I have a Honda ems4000 generator bought back in the late 70s. I lost the power cord that goes from the generator to the house. I just can't find the right one. Can anyone tell me a part number of
  • 1 more comment
  • Richard M.
    Richard M. Nov 05, 2012
    Does It Look Like This?
  • Charlie Theall Nov 05, 2012
    Look like what I don't see a picture?
  • Richard M.
    Richard M. Nov 06, 2012
    The picture is below
    New Friend:
  • 155 Answers
Try this again
I have a Honda ems4000 generator bought back in th - 11_6_2012_1_57_20_am.jpg
Posted on Nov 06, 2012
4 Suggested Answers
SOURCE: Honda EU30001 generator causes erratic pellet stove operation.
Ok Motors and the like generally DO NOT really go all that well from a generator, what load does the Stove use?, You must add up the cumlitive "Wattages" of ALL things connected, see your generator is about 3000 Watts, 3KW, How much "headroom" is there between the two? Whats supplied versus whats being used? Purely inductive loads, like Motors etc, are less responsive than electronic loads. I suspect that your generator is NOT providing enough current to the Stove, especially when "Other" things are connected. also. Look, if the, any, generator is 3000 Watts really you should only load it up to a couple of KW's, 2.5KW being about maximum. To do what you are doing would require, IMHO, at least, 5KW, to get the "Headroom" of current drawn over current able to be delivered by the generator. Also inductive loads loose heaps of power and actually cause a higher draw. So that your answer, you must use it well, inside it's rating, not right up to the limit.
Posted on Feb 26, 2010
  • 185 Answers
SOURCE: HAVE A TRANSFER SWITCH IN
Hello, what you are not telling us is the size of the wires in the 4' cord and the 80' cord. However, you are correct in your thinking that the longer cord is cutting back on the available power that you have. Yes, if you extend the length, then the wire size in the cord has to be increased as well. To give you a size we will need to know the generator size. Having said that, an 80' cord is going to be a BIG amount of money. You might want to tell yourself how much money you are saving pulling the generator around. If you have to use the generator a lot, you might consider installing a cable to run the generator with.
joe
Posted on Feb 22, 2011
Mr BrokRench
  • 1623 Answers
SOURCE: Our Honda EB 3500 generator
It's either not getting enough fuel, or the govenor is not working. When the engine is running, watch the throttle linkage between the carburetor and engine, looks like a bent wire. When you throw a load on it, it should move to give the engine more power, if it dont, try moving it by hand.
If that appears to be working ok, check the fuel line from the tank to the carb for good gas flow.
You can also remove the float bowl on the bottom of the carb, it's a round bowl on the bottom of the carb with a bolt in the middle of it...clean it out and check the float. The float looks like a little catamaran, make sure it is moving freely up and down. That is about all you can do without removing and cleaning the jets in the carb.
Good luck, & i hope this helps.
Posted on Aug 27, 2011
Troybilt 5500 generator pull cord locks up...just had it for one year...cord was very easy to pull @ first...but lately it locks up when I try to start it...any suggestions?
your cord is too long is why its binding up ,,,on the tee hand where you put your hand on to pull,,,,take a screw driver and push up the tied knot out and away from the tee handle,,,,take and make another knot about 8 inches and pull the cord back into the tee handle then try it again. Most have a long rope, cord etc for maximum pull,,sometimes they go overboard on the length and it binds up on the rewind of the recoil system
Dec 08, 2011 | Briggs & Stratton Power Products 5,550...
Honda eu1000 lacking correct ac power output
hi wizman sorry not answered your reply to me about a week ago ,just too lazy and lost a lot of interest in this site since it was changed ,trying to find the new questions as they come in ,and the odd 4 dollar ones which goes towards my phone bill and this new lay out and questions filling my inbox ,anyway now to answer this one i suppose and i think here i would need more info as to how it was before it was rebuilt .But i would have a play and strip and clean the carb first .right now to see what else i have been sent as star trek is on TV in 20 mins .
Nov 10, 2011 | I Power In Box Honda Eu1000i Power...
Have a Honda EU6500is generator with 410 hours. I live off grid and run the gen 2-3 hours daily. The generator rpm surges under load on eco throttle and surges under load AND without load when the eco is...
i have the same problem with a new one ,take a peace of paper and cover the battery cover air inlet when it's running ,if your problem stops-it's the seal around the cover,a honda rep let the cat out of the bag,---jk
Sep 08, 2011 | Honda Electrical Supplies
HAVE A TRANSFER SWITCH IN MY HOME TO PLUG A PORTABLE GENERATOR TO. PROBLEM IS WORKED GREAT BUT WAS ON OTHER SIDE OF HOUSE. I HAD A 4' CORD BUT BOUGHT A 80' CORD TO PLUG INTO THE TRANSFER SWITCH NOW WHEN...
joe
Feb 22, 2011 | Honda Electrical Supplies
Just bought a honda f400 tiller would like to no what hp it is please
hi, i think you'll find its a g 35 engine, 3.5 h.p. 144cc. dates from late 70s early 80s.i'm not clever, i've got an engine in the shed! running last year blackrodd@hotmail.co.uk
Apr 23, 2010 | Honda Garden
Honda 2000i generator need to replace power pull cord
take of cover where cord goes in watch direction and replace cord. wind up spring in right direction, test and replace cover.
Dec 09, 2009 | Electrical Supplies
Open Questions:
Honda EMS 4000 No Spark. Hi all, I just got a Honda EMS 4000 Generator last night on CL. It was not running when I got it but it had spark last night so I cleaned the tank, sediment bowl to the tanks on off valve and the float on the carburetor. I got it running and it ran fine in Auto and Manual RPM mode. I plugged an electric tool into it to make sure I was getting 120v and the tool worked just fine as the engine auto reved the RPM's w/a load. This was all done on the back of my Trucks Tail Gate . I took it off the tail gate last night by my self. Darn thing ways a ton and while doing so I had to lean it on it's back side a bit to keep from killing me and dropping the generator. So any way today I got to start it up and nothing. No spark at all. I purchased new plugs and it's still not getting a spark. I am wondering if there is some kind of sensor that can get clogged up w/oil or some thing that would cause this generator to not get a spark? The Oil switch is moved upward into the on position. The accessory remote switch if moved down to the off position and nothing is plugged into it. I'm stumped as to why it all of a sudden the next day it does not get a spark. Note: I don't have the keys and am using a flat head screwdriver to move the key into the run and start postions. Is there a way to test the coil off the motor or is there some kind of magneto or electrical mechanism in the motor that may have oil on it from when I leaned it over causing it to not get a spark? Could it be the Key switch? I'm lost and need some expert advice. Please help, Thank you, Tony
Sep 01, 2012 | Honda Ems4000, Em4000, Ems4500, Eb4000...
Honda Ems4000, Em4000, Ems4500, Eb4000 Generator Parts Catalog Logo
173 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
