Question about Dryers
Hunter 23547 - light no longer works. Tried 3 new bulbs and still just get a
  • Trish Nov 07, 2012
    When I turn on light there is a click but no light. Fan works fine. Trying to find a new ballast VIVA VEB83130.
  • Paul Haskitt
    Paul Haskitt Feb 15, 2015
    Trish-I have this problem- did you find a replacement ballast?
2 Suggested Answers
  • 1527 Answers
SOURCE: Sony wega 70 in new bulb lasted 8 hours now
hello.+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Posted on Oct 21, 2009
Hunter fan 2 yrs old-light won't work.fan discontinued was told need switch G234686000 but no longer stock it! fan not used long enough to replace bulb & now have to trash it. what to do?
Been There, there is a small remote box inside the case,, if you buy Harbor Breeze 3 speed fan switch with dimer light they come together,,, but Heck,,, it's $60.00 US !!!
Nov 07, 2017 | Hunter (25417) Ceiling Fan
Newly installed Hunter remote will work light and fan if only 2 of the 3 bulbs are installed.
Did you install the correct wattage? If you put in 2-60 watt try 3-40 watt instead .
Dec 30, 2012 | Hunter 52" Ceiling Fan With Light And...
Fan works fine, lights don't. Could it be the remote?
Had this happen to me and it was a hunter fan. Similar problem. Fan worked,lights went out. Took light bulbs out, lowered the light fixture. Tested power coming from the ceiling to the quick connect pins for lights. The power was good. So the Problem's in the light kit. Turns out the government requires all new fans to have certain wattage to lights, set at 190. So 3 60w bulbs or 4 40w. Inside the light kit is a limitor hooked to the black power wire coming from the quick connect,It is smaller wire and mine was pink into limitor and white coming out. Not very big. This went bad so i called Hunter, sending new light kit, but I just wired straight black to black wire bypassed that limitor and lights work fine
Aug 29, 2012 | Hampton Bay 24750 Huntington III Ceiling...
I have a hunter ceiling fan model 23898 which has a dimmer switch built in one day a light bulb blew out on it and now we cannot turn off the lights with the switch the only way is to loosen the bulbs in...
Has anyone found a solution for this problem? I have tried a bulb in each light socket and attempted to use the pull/dimmer switch that is on the fan itself. The lights no longer dim nor turn off. I have unscrewed all of the bulbs and tried each bulb in each socket one at a time and still nothing. I have also taken the pull switch out of a different hunter fan to put into this one, hoping that atleast the lights would turn on and off. Still the lights won't turn off using the pull switch. I am out of ideas.
Sep 11, 2011 | Hunter Ceiling Fans Individual...
All of a sudden the light on our hunter celing fan is flashing like a strobe light
Three possibility for the strobe problem:
1. Loose wire connection. Shut down the circuit breaker, pull down the switch, open the ceiling fan cover and check for any loose wiring connected to the main bulb, If there isnt any, remove the bulb and spray WD-40 or contact cleaner to the receptacle. Replace the bulb.
2. Replace the bulb with a new one. Preferably incandescent or a warm white energy saver.
3. There maybe ghosts fooling around. (I'm kidding)
Hope this helps,
levibit
Dec 18, 2010 | Hunter (25417) Ceiling Fan
I can still control the Fan function with remote, but can no longer turn the light on. I installed a new bulb and even new battery in the remote. The light still doesn't turn on. Also cleaned remote as...
Howdy,
Is it possible this fan also has a pull chain switch for control of the light? If not, it sounds like the light board in the receiver has burned out, which is a fairly common issue. If the above does not work, call Hunter at 1-901-745-9222, a direct line to tech support. Be sure to have your fan model # ready as they will need it to get your correct receiver. If it's under a year old they should give you a replacement provided you can provide proof of purchase.
Sep 22, 2010 | Hunter 52" Ceiling Fan With Light And...
I have a Hunter model 21241 ceiling fan with circline fluorescent light. The light module is a VEB82122 (ballast "A"). This is part of switch housing assembly part number 93563-09-000. I get a dim...
The ballast is still available on the internet, just Google "veb82122." They want $37 plus shipping. You can also but a 22W Circiline ballast at Home Depot that will work for about $18. (Lowes does not carry them). The original ballast is a solid state design, light weight and instant on. The Home Depot ballast is the heavy transformer kind and a real pain to modify the bracket to make it fit. I have 8 of these Hunter fans and I have installed the Home Depot ballast on two if them so far, but I think that I will order the solid state version as a spare for the next time.
Aug 13, 2009 | Hunter 20531 Vista Brushed Nickel Ceiling...
Fan works, light doesn't on Hunter ceiling fan
I would begin by testing each bulb in a different socket somewhere in the house.
Apr 06, 2009 | Hunter 27187 Remote Control
Dryers Logo
628 people viewed this question
Top Dryers Experts
