Bosch 22052 washer dryer error code E01 - Washing Machines
  • 3 Answers
SOURCE: Bosch Nexxt 500 Plus Elect Dryer Error E01
Absolutely those dryer sheets are the root of all evil....I would also recommend a good vent brush to clean your dryer vent.
Follow these steps, it worked for me:
1. use a shop vacuum to clean out the dry vent or a vent brush.
2. Clean your lint filter with windex, hot water and and soft bristle brush.
If this doesnt work try running the until disconnected from the vent for a cycle to isolate the vent as your issue.
Cheers!
Posted on Dec 01, 2009
  • 1382 Answers
SOURCE: bosch washer dryer WVT2850GB error code E06
Remove the rectangular fascia at the bottom front of the machine - on my model you only need a coin to turn the two plastic screws. Unclip the black rubber drain pipe, remove the plug from the end and drain the water into a bowl (or several bowls).
Then undo the round plug at the bottom left of the machine (more water will come out) which will give you access to the extractor pump. Check that there are no obstructions in there and that the small propeller in there can turn freely.
If there is no obstruction there then we move onto the next steps.
If you can figure out how to remove the front of the machine then you will find this part easier
First, TURN OFF THE POWER. Then, on the front of the machine, on the bottom left, undo the screws that fasten the extractor pump onto the front of the machine. Then pull the machine out from the wall so that you can get to the back of it. Remove the back of the machine by taking out the ten or so screws.
Looking in from the back: At the bottom-front-right of the machine you will see the extractor pump. It will have two hoses attached to it - a fat one and a slightly thinner one. Reach into the bottom of the machine and remove the power plug from the back of the extractor pump. Then, using a pair of pliers (or something similar) to open the spring clip, remove the thinner of the two hoses (the drain hose) from the pump unit. This can be fiddly - especially if you're doing it from the back of the machine.
Pull the hose out of the machine and check it for obstructions. If there are no obstructions in there then move onto the next step.
Reach back into the machine and, again using the pliers, remove the fatter tube from the pump. Remove the pump from the machine and check it for obstructions in the entry and exit holes, and also make sure that the propeller isn't obstructed. Then shake and squeeze the fatter tube to see if there is an obstruction in there
Best of luck.
Posted on Mar 30, 2010
  • 414 Answers
SOURCE: Bosch 500 washer won't finish rinse cycle. Flashing error code13
Timed out on drain cycle, basically you either have an outlet blockage or something is trapped in the pump, you can check the pump by opening the bottom right flap on the front panel,manually emptying the w/m and checking the pump filter for coins etc. Also, check the outlet isn't blocked.
Good Luck.
Posted on Jul 12, 2010
SOURCE: Bosch Error Code 13 Washer won't drain
First, unplug your washer. After that find the little round plate below your drum opening on the exterior of the washer. It should have a small hole in it. Use something to gently push trough this hole and twist the cover off, Inside there you will find the drain access. Be careful, if there is water in your drum this will make a mess when you unscrew the drain access. Take the usual precautions and unscrew the drain access slowly until it is off. Remove any obstructions and replace access door and cover. Clean up any mess and plug back in your washer and try again. takes about thirty minutes to an hour depending on how much water is in the drum.
Posted on Sep 21, 2010
Macmarkus
  • 2605 Answers
SOURCE: I have a Bosch Vision 500 with a few error codes.
Hello, welcome to FixYa.
Based on your post I understand you have a Bosch WFVC5400 "Vision" series washer. Hopefully the info below will supply you with the assistance you require.
I will start by letting you know though the E27 & E95 error codes are not common nor are they listed in the service manuals, they are known to be associated with door lock and communication errors. These can be due to the door lock mechanism failing and/or is overheating. It is recommended that you unplug the appliance for 30 minutes and try again.
The E01 error indicates a door lock error directly. Though again this can manifest from an improper draining and not necessarily a lock problem.(drain time exceeded).
If the unplugging the uit fails to rectify the errors, you will need to first check the pump/drain lines and if all else fails replace the lock assembly unfortunately....but that's getting ahead of ourselves.
Try this first...
The next step is as follows,
Following this ( or in reverse order it's your call if you think there may be substantial water still present ) I'd do this step first...checking the pump filter. It may be a good plan to have towels close by, or a wet-dry shop vacuum.
It's as follows...
Then the filter removal...
That should resolve the problem, As I also alluded to before, there is a possibility the lock itself is faulty, but not likely.
Thanks for choosing FixYa and good luck. Let me know if you need further assistance or if any of this is unclear.
**NOTE:too much "He" detergent or the use of non-He detergent can also cause too many suds which are opposition to proper operation of these machines and can and DO cause all kinds of error codes**
Once the issue is resolved I recommend running the unit through the hottest temperature possible on the longest cycle possible and add some product called "washer fresh" or "Affresh".
Both are designed to remove residule soap buildup inside the tub assembly and prevent errors associated with soap suds, which usually manifest in errors with the pump and lock.
Regards,
Macmarkus :)
Posted on Aug 28, 2011
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    My dryer keeps giving an E 14 error code. Even after resetting it, it runs for about two minutes & flashes the code again. How can I fix this?
    Bosch Washer Dryer ' Neff ' Siemens ' Integrated ' Error Codes
    www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3312-bosch-neff-s...
    Jan 16, 2012 - Bosch, Neff and Siemens integrated washer dryer error codes and ... The error codes in this article pertain to integrated washer dryers ... E14 ...
    how to mend it .com - error code E14?
    howtomendit.com > Household Appliances, Washing Machines
    Bosch washer/dryer wvti3240 stops wash and displays error code E14. Can anyone help please ? also a full list of the error codes applicable to this machine ..
    Nov 03, 2015 | Dryers
    E01 error
    The control board is seeing the door as open even though it may be closed. Here is how to repair:
    http://www.techanswerslive.com/appliances/bosch-nexxt-washer-error-code-er%3a01/1
    Jul 24, 2014 | Bosch Nexxt 500 WFMC3301 Front Load Washer
    Bosch vision error code E01 on washer
    error code e01 means the computer thinks the door is open even when it's closed you can repair this using this guide:
    Bosch Front Load Washer Error E01
    Aug 23, 2013 | Bosch WFVC5440UC Washer
    Bosch Nexxt Washer Error Code E01
    means that the computer is seeing the door as opened even though it may be closed, you can fix this by following this guide:
    Dec 01, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
    What does E:01 on the Bosch Nexxt Premium dryer mean?
    Hello Christie, welcome to FixYa.
    I'll start by saying your post indicates it is a Bosch dryer, correct ?
    Well the E01 error on these machines indicates an air flow problem...specifically (usually) the lint screen, but can be a build up of lint in the venting as well. Start by checking the lint screen.
    This from the horses mouth...errr Bosch ;o)
    Following this suggestion should get you back up and running normal. Let me how it goes. If the problem persist's after, I'll try to assist you going forward in any way I can. Good luck.
    If this indeed resolves your problem please take a moment after to rate the assistance I was able to provide. Tell your friends to look for "Macmarkus" on FixYa should they need asistance as well. Thank you for choosing FixYa.
    Regards,
    Macmarkus :)
    Sep 26, 2011 | Bosch Washing Machines
    Error code E:01
    Hi and welcome to Fixya, The E01 error for your bosch indicates a door lock problem has been detected at the control board. Insure the door is closed tight, turn your breaker off or unplug the washer for a couple of minutes and retry. Let me know what happens, ultimately it may be a faulty lock assembly, a loose wire harness etc. but we'll cross that bridge when we get there...if necessary. I'll watch for you to respond with the result's. Good luck. Macmarkus :)
    Jun 07, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
    Bosch dryer is beeping and showing error code, E01,after a few minutes of running then shuts off.
    Clean the Duct hose mine was doing the same thing and now it will run the full cycle no problems. Also if you are in a high humidity area it may be blocking up with condensation.
    Jun 05, 2010 | Bosch Dryers
    Our dryer reads E01. I can't locate our manual so what does that mean? Thanks
    E01 - lint filter dirty, exhaust air duct is blocked or too long, fault in program sequence or malfunction, the room/cabient is not adequately ventilated.
    Feb 13, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
    Cheers!
    Oct 28, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
    Washing Machines Logo
    75 people viewed this question
    Top Washing Machines Experts
