Dismounting upper panel of washing machine
I don't know how to dismount the upper panel of this washing machine. I've unscrewed two screws from the back side and I can get it up a few centimeters, but I can't find how it is attached in the front part. Any idea? Thanks in advance.
  • Bilker
    Bilker Nov 05, 2012
    tell me the model of the washign machine
  • Phelinux Nov 07, 2012
    Thank everyone for your help. You rock, guys. The problem is already solved. There were two long screws from the back to the front that I didn't think were related with the opening of the upper panel. Now that I have got access to the inner, my problem is another one. I'll post it in a new thread.
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the make and model number of your unit?
Posted on Nov 06, 2012
SOURCE: Fridgidaire FTF2140ES0 Front Load Washing Machine Vibration
Try going to GVIINC.net - there product definately works.
Posted on Jan 14, 2009
SOURCE: error on Westinghouse mastermind 708 front loader washing machine
This happend to me once, and it was in relation to a blocked intake filter.
- Check that the intake houses are not cloged and the small filter under neath is clean (Use an old tooth brash)
- Also check the opening on the front bottom left of the machine. (Open with a flat head screw driver)
. My one had coins in it. Note: drain with the small pipe into a backet so when you open it you don't have watter everywere.
Posted on Feb 06, 2009
  • 7 Answers
SOURCE: how to take off the front panel?
hI.. yOU NEED TOTAKE OUT THE SOAP DRAWER.... UNDO THE SCREWS HOLDING THE FRONT PANEL ON... TAKE THE LID OFF... UNDO THE TWO SCREWS ON TOP O THE FRONT PANEL.. UNDO THE DOOR RUBBER AND FOLD IN MACHINE... UNSCREW DOOR INTERLOCK.. AND REMOVE NOTING TERMINAL CONNECTIONS... UNSCREW THE TWO SCREWS AT BOTTOM OF PANEL, AND HEY PRESTO... IT IS OFF....!!!
BEFORE YOU START MAKE SURE THE APPLIANCE IS SWITCHED OFF AND UNPLUGGED - THIS IS VERY IMPORTANT..
Posted on Mar 31, 2009
  • 7 Answers
SOURCE: how do i get the front panel off?
Remove the top of the machine by unscrewing the two screws on the upper back of the machine. Once you do this, you will see the electrical wires for the control panel. DON'T UNDO ANYTHING. It will appear you might have to in order to take off the front panel, but you won't.
2. Next, take the two-by-four or some paint cans and place them under the front of the machine to help prop it up so you can unscrew the four bottom screws from the front panel. It's not going to come off just by doing that, so you have to take out the detergent tray, where you'll then see two screws inside the tray crevice and you'll have to take them out. Set those two aside elsewhere--they are longer than the other screws and you'll want to make sure you put them back in the right place. On the top front edge of the washer's control panel there should be two screws on either side securing the plastic control panel to the front of the washer. Unscrew those. You should now see the remaining screws holding the front panel on. Unscrew those as well.
3. Next, open the front door of the washer and you'll see a little grey set of plugs that look sort of like USB ports on the right-hand side. There are two screws holding it on--undo those. You should now be able to pull the front panel out just enough to reach that screw-clamp in the front to unscrew it. Once you do, go ahead and replace all the screws and parts of the front and top you've undone. You'll want to do that before you proceed to taking out the pump and cleaning it, so that you can remember how to do it more easily.
The front panel will not completely remove due to the gasket around the window, but it WILL allow you to get into the front assembly area more easily.
Posted on Apr 03, 2009
  • 410 Answers
SOURCE: how to remove the front panel for a GE upright
See the excellent washer repair video on utube.
Posted on Nov 14, 2009
My washer makes grinding sound when washing, how do I fix this?
Guess it's a bearing in the drum, though just my appreciation. If you are not a tech in washing machines, you should call a reapir service to get it dismounted and replaced
Watch some videos about issue. Take note that you are not specifying your make an model and procedure might be somwhat different for your particular washing machine.
How to change drum bearings on washing machine
How to Replace Washing Machine Bearings
How to replace washing machine bearings on Bosch Neff Siemens and some...
How to replace washing machine bearings on Candy Hoover Otsein Zerowatt
Aug 12, 2015 | Washing Machines
What causes this machine to squeal while running?
I had a similar issue, had a bad bearing. A quite frequent failure int this device. Only way to diagnose is dismounting it
These are not properly your model but see some videos how to do it:; might help to understand the job
Repair HE3 Washing Machine Bearing Noise
ApplianceRepairVBlog 2 Replacing the rear bearing on Whirlpool Duet...
Duet Whirlpool Sport Changing Bearings
Aug 02, 2015 | Whirlpool Calypso GVW9959K Top Load Washer
2005 gmc yukon blower motor keeps running after ignition is turned off
This problem is caused by a defective blower motor speed control module aka blower motor resistor.
The blower motor resistor is right under the passenger side glove box, next to the blower. You need to unscrew two box screws to dismount the right hand insulation panel, then you will see the resistor pad - little bit inside up. Unscrew two box screws then the pad will come off, unplug the power from blower motor and the seven pin plug from resistor pad. Installation reverse way
Oct 29, 2012 | 2003 GMC Envoy
Have a honda accord. 98. power locks not working. or key locks all doors from outside. windows work but only from the door that its on. drivers door will not operate others. but the window lock dose work.?...
Yes, the driver´s door has the master switch for everything. No need to dismount the door panel. Look inside the door grab rail ( which is part of the window switch subpanel)and there is a tiny black plastic cover that hides a single phillips screw. Lift the cosmetic screw cover with a tiny flat screwdriver, there is a slot to insert the screwdriver, to lift it. PARTIALLY, just enough to see the screw.Unscrew it, and the whole subpanel comes out, pulling upwards. The screw plastic cover is very frail, and has a slave strip that attaches it to the bottom, when unscrewing, be very careful not to break it. The subpanel itself has 2 or 3 connectors to handle window / window lock and remote mirror duties. Check that all connectors are plugged in firmly. If they all were attached to begin with, check that the contacts have not rusted.
Jul 26, 2011 | 1998 Honda Accord
How do you get access to the washer bottle on a 2005 peugeot 307 hatchback?
it is mounted behind the front wing side panel on driver side. Either you can dismount the front driver side wheel plastic wheel arch flap to access it or complete dismount of front wing panel to see it in light.
Mar 28, 2010 | 2005 Peugeot 405
Dismount door panel VW Golf
To remove the external door handle is not nessecery to dismount the door panel. Just follow my instruction: Open the door. Above the latch you will find small round plastic cover 1 inch of diameter.Remove it.There is screw T35 or T40 head/judish star/.Unscrew.Than slide the handle to the right about 1cm.Carefully pul out left side.That is it.
Jan 14, 2010 | 2001 Volkswagen Golf
Coleman 5640 cooler
The cover on the inside just pulls off. Inside/Outside fans pull off. 2 screws to dismount motor. Unscrew leads to terminal. Most truckstops carry the motor, otherwise search for Colman 5640.
Jun 27, 2008 | Refrigerators
Washing Machines Logo
Top Washing Machines Experts
