Question about Microwave Ovens
Can a Sharp R-209EK microwave be repaired? The timer is flashing and the clock cannot be reset.
MicrowaveSvc
  • 9098 Answers
SOURCE: Clock on Microwave
Normally on a Sharp, one of these key combinations will do it:
CLOCK > 1 > 2 > 3 > CLOCK
CLOCK > 1 > 2 > 3 > START
CLOCK > CLEAR > 1 > 2 > 3 > CLOCK
CLOCK > CLEAR > 1 > 2 > 3 > START
Let us know if this does not work.
Posted on Aug 10, 2008
  • 17 Answers
SOURCE: Hood range microwave not heating up
We had one that did the same thing. my brother got so mad at it he put a wrench in it and turned it on. It didn't do anything to it. No power surge nothing. It acted as if I put a plate of food. Lighted up turned and even beeped when done. The wrench wasn't even hot. Now I do recommend this myself. But we went and got antoher one.
There is something in there that magnifys the power inside the mircowave and it sounds like its out.
Posted on Dec 12, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: How to set the timer? No manual
One of the manuals on this page may help.
If not, select the customer care link to the left to order one.
Posted on Jan 29, 2009
rhozel2010
  • 269 Answers
SOURCE: My Sharp Model R-520LW microwave will not cook.
Hi! the problem you have mentioned indicates that your microwave magnetron is not working. check for busted fuses.
Posted on Sep 15, 2009
SOURCE: I have lost instruction book
May be a little late, but... 1. Press Power Level button for approx 5 seconds - you get the 12 hour clock 2. Press again for 24 hour clock 3. Set hours using the 10 min and 1 min buttons 4. Press Power level button 5. Set minutes using the 10 min and 1 min buttons 6. Press Power level button And you are done
Gert
Posted on Jul 27, 2010
How to reset time
To set the clock, press
"Clock"
once
or
"Timer/Clock"
twice
(depending
on your keypad)
The colon symbol (:) will flash.
Enter time of day.
The time appears
in the window; the colon continues
to flash.
Press
"Clock"
or
"Timer/Clock"
again - colon stops flashing; time of
day is set !
Nov 16, 2015 | Panasonic Microwave Ovens
I cannot reset clock
Touch Timer/Clock pad and number 2 pad.
Enter the correct time of day by touching the numbers in sequence.
Touch Timer/Clock pad again.
Aug 15, 2015 | Sharp Carousel R530EST Microwave Oven
What part do I need for clock/timer display for sharp carousel r1601?
You probably need the control board, and that is going to be an expensive repair.
May 22, 2015 | Sharp Microwave Ovens
On the r559y sharp microwave,how do i set the clockl
press,timer/clock ,colon will flash ,enter correct time{i.e. 12:34},press clock/timer again,,all set,if it doesnt work,return it to where you bought it,
Jan 01, 2015 | Sharp Microwave Ovens
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    Timer/clock touch button doesn't work anymore - worked this morning. can that be repaired? I unplugged the unit to reset now there is no clock display anymore and I can't set the clock either
    We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee.
    Feel free to contact me directly with your brand, full model number and symptoms.
    William E. Miller
    prototech@usa.net
    http://www.microwavedisplay.com
    May 25, 2010 | Sharp R-316FS Microwave Oven
    Sharp R-1460A Timer counts down very rapidily and no heat
    The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
    If that doesn't work, leave it unplugged for maybe an hour.
    Dec 12, 2009 | Sharp R-1480 Microwave Oven
    Microwave won't work
    The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
    Let us know if the hard reset doesn't fix it.
    We're happy to help you and we'd appreciate your thoughtful rating of our answer.
    Jul 22, 2008 | Sharp R-220BW Microwave Oven
    Keypad Problem?
    look on the back panel for any hole with a "RESET" label next to it. insert a small pin to reset your microwave
    May 25, 2007 | Emerson MW8168B Microwave Oven
    Microwave Ovens Logo
    112 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
