Question about Miele 23 in. Novotronic G841 Built-In Dishwasher
Intake/Drain Error In the middle of a cycle the Intake/Drain indicator is lit and the unit stops. I checked the non-return valve and the pump propeller (has no obstructions). Pump seems working as I hear the sound of draining water. When I open the door after failure I see water in the unit (sometimes more sometimes less). Any help is appreciated.
  • 3 more comments
  • olafbirk Nov 15, 2007
    exact same problem with same symptoms, and no real apparent problem with anything on the dishwasher. Huge party coming up, would love to hear from someone with any ideas.
  • mark56 Nov 24, 2007
    Seems I have the same problem. About 3 minutes into any cycle the intake/drain light starts flashing and the cycle progresses no more. The intake is clear (machine fills with water) and the drain is clear (when I turn the machine off and restart it, it drains fine).
  • dmkasaa Nov 30, 2007
    My dishwasher has also been doing this except tonight it has stopped
    working. The motor keeps running as if it is trying to drain water, but
    it is doing this even in the stop position. The only thing that I can
    do is turn the power off. If I try to reset and then push start nothing
    happens. Up until tonight, to solve the intake/drain flashing light
    problem, I would just turn the dial back to stop and start over again.
    After a few times, it would finally work and then continue the wash
    just fine. I would really appreciate any help!
  • Anonymous Dec 09, 2007
    I have the same problem with this Miele Novotronic 841 SC Plus.
    How to fix the intake/drain error problem?
    It stop in the middle of the cycle, and water in the dishwasher is not drained out. I check the drain area, it is clean.
    I check the the water intake filter, it is clean.
    Any solution?
  • LisaGK Sep 30, 2008
    The intake/drain light would go red and then the dishwasher would stop... for several days I've been able to get things going again by switching the dial to "stop," and then starting everything over again. But today, even before I start the dishwasher, I've noticed that the pan underneath has filled with water... it was dry when I unloaded, so the water must have come from some kind of inner tray or the door tray or something. We don't have an easy way to pull out the dishwasher and unplug the water hose so I'm going to have to call for a repair. I'll keep you posted.
There is water collected in the inner tray of your unit. Pull out the Miele and take off the drain hose and unplug the unit. Then tilt the dishwasher back 60* and let it drain out all the water. There will be a couple of cups on the floor, but nothing too big that a couple of towles can't handle. Then reconnect everything and start up the unit. It WILL work! It just happened to me and my Miele incognito is now working like a champ again!!
Posted on Dec 02, 2007
  • 3 Answers
I cleaned out the drain pump and non-return valve on my Miele G658/858 and that fixed the problem. The G841 may have similar parts. It's easy to do. In order: 1. Turn off washer. 2. Remove the triple filter (the basket on the bottom of washer with the little handle. Turn the handle and remove) rinse out and set-aside. 3. Remove the standing water. I used a wet vac to remove the standing water from the bottom of the machine, but you can scoop it out also. 4. Tilt the locking clamp (tilt left) to the side. (this is a metal wire covering the white plastic valve. This valve is to the right of the triple filter basket.) 5. Pull out the non-return valve and rise will under running water. You may have to wiggle the valve a little. Pull straight up and out. 6. The drain pump is beneath the non-return valve. (it has a little plastic propeller, like a paddle wheel, inside) 7. Spin the propeller several times in both directions to make sure it's clear. ( I used the shop vac with a small hose attachment to clear the drain above the propeller compartment) 8. Carefully refit the non-return valve and secure it with the locking clamp. 9. Refit and lock the filter in place.
I haven't had a problem since and my dished are much cleaner- The problem must have been coming on for a long time.
Hope this helps,
Posted on Oct 08, 2008
    New Friend:
Machine: Miele G658
Problem: Dishwasher makes a few clicking sounds and then the intake/drain LED starts flashing.
Cause: Water in the tray underneath the dishwasher. There's a sensor (metal pin, 0.5cm diameter, 2cm long) underneath the filter (in the labyrinth) that got pushed out. This way the water ran down a collection tray underneath the dishwasher. An overflow sensor noticed this and generated this error.
Solution: take out the water, put the pin back in, and wash dishes ;)
Posted on Sep 08, 2013
We had same problem. Ended up having to replace the whole control board for $1000...yikes!
Posted on Aug 15, 2008
We followed each of these solutions (all very helpful, but not the issue). Turns out my wife had put one of those pot scrubbing tools that has a built in dishwashing (liquid...like Dawn) resevoir on it in the dishwasher. During the wash cycle the liquid soap came out and suds up; causing the Miele to believe it was going to overflow...and shut-down. So, besides the moral of this story you should also look for suds and be weary.
Posted on Jan 11, 2008
Dishwasher is not working. The red 'Inlet/Outlet' light is flashing. Any advice please Thank you
There are a few things you can check. First set the washer cycle to Stop and turn off the unit. Next make sure that the stopcock on the inlet valve is fully open. Then close the stopcock/valve and disconnect the inlet hose. Remove the seal and then the filter (use pliers). Clean this inlet filter with running water. Replace the filter and seal and reconnect the hose to your inlet valve. Reopen the valve (check for leaks from threading problems). Make sure the valve is fully open when you try to restart the dishwasher. Check your incoming water pressure at this valve as well - low water pressure will also trigger the inlet error. Make sure the hose is not kinked.
If the washer did any parts of the wash cycle, then try cleaning the outlet side of the system.
Next clean the combination filter, drain pump and non-return valve. For the filter (near the lower spray arm), turn the handle counter-clockwise. Lift the filter out and remove all debris. Rinse under running water and use a nylon bristle brush to get stubborn stuff out. Pull back the yellow clip and open the filter flap. Clean the underside of the filter with running water again.
Remove the water from the cabinet with any container that works. Raise the locking clamp for the non-return valve. Lift up the valve and clean it under running water. Carefully check the drain pump (now visible with the non-return valve out) and remove any debris. Sharp objects may be present. Move the impellers and completely check the pump for foreign objects and remove them. Replace the non-return valve and secure it with the locking clamp. Replace the combination filter so that it lays flat and secure it with the handle. Make sure that the drain hose is not kinked.
If neither of these solve the problem, you need to call for service. The Waterproof safety system has been triggered and water got into the electrical system of the unit.
Many Miele appliance manuals are here: http://www.miele.co.uk/customer/OperatingInstructions.aspx . The manual for the Miele G641 is here: http://www.miele.co.uk/Resources/OperatingInstructions/G%20641%20and%20G%20841%20Plus.pdf . See this manual for pictures of the filters and drain pump area.
I hope this helps.
Sep 14, 2011 | Miele 24 in. Novotronic G641 Plus Built-In...
My Miele G2430 dishwasher stops right after draining in the first minute or so after starting, and the intake and drain light comes on. The solenoid at the end of the intake hose then clicks and the light...
Hi
Intake/Drain light flashing means an issue while draining. The dishwasher is not draining properly. Please check for air gap on the dishwasher is not clogged. It prevents dishwasher from draining properly and sometimes the drain flow is restricted due to gunk. Cleaning or bypassing the air gap will resolve the issue. If this doesn't resolve the issue then it is due to seized (or stuck) drain pump. Keep handy large bowls and towels to soak the water out. Disconnect the power to the dishwasher or turn off the breaker to the dishwasher. Tip machine on its back; remove screws that hold the bottom tray on. Remove the hoses to the main motor, remove electrical connections and switch it on. If the error still appears then turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs to cancel the error message. Switch the appliance off and then back on again. Hope this helps...please post back for further assistance.
Daniel
Feb 23, 2011 | Miele Optima G2430SCi Stainless Steel...
Stops in cycle and says f 02
F02 error is related to drain pump block.If the drain pump gets blocked or the drain hose is blocked the error comes up,this is indication of cleaning the drain pump and drain hose.If the drain pump and drain hose checked ok then its faulty drain pump,its not draining the water so the error f-02 is showing up. error F-02 is a slow drain problem. Remove the wide tapering pipe from the drum to the pump. Inside there is a non return ball valve. Clean this and see if that helps. Take the front bottom panel off and open the drain trap,and see if there is any thing got stuck up,like coins,nails,socks or any small cloth etc etc.--------------While removing the drain pump and drain hose for cleaning,please keep thick towel with you.As you disconnect the drain pump from its connection,lot of water will flow towards you,if your machine is filled with water.So keeping this towel with you will help to control this water flow towards you.This should help.Thanks.Helpmech.
Jan 19, 2011 | Washing Machines
Stops running in middle of cycle and displays an f on the screen
The error indicates that there is no water detected entering machine or Pressure switch trip not detected..If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
  • 3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation
Thank you !!
Jul 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Miele G 843 Vi won't cycle. Fills, can be drained, but no wash.
Most units have a recirculating pump, and an output (drain) pump.
If I were you, I would disconnect it, drag it outside and turn upside-down (remove everything internal first)
Take off the drain pump and check over, then check the main pump motor for free rotation first.
Also clean both those, and check condition of hoses/ carbon brushes on main motor while you're there.
Doing this full service now should give you a long run without problems.
My guess is the main motor seal may have leaked a very little, allowing the spindle to sieze. Freeing it and applying light oil with regular use should be ok.
Replace carbon brushes if worn to save hassle later - they're cheap.
May 02, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
I have an Miele Optima Series HG03 dishwasher. The dishwasher stops after a minute and the intkae/drain error flashes. I tried everything in the manaual but there is nothing blocking the drain or intake...
hi,
try checking the spigot under the sink as quite often the hole has not been opened up enough and there is a shoulder for food to jam up against causing a blockage. Remove the drain hose and have a look in the hole of the u bend.
If ok remove the filter in the base of the unit and remove the non return valve and make sure the drain pump can turn and there is not anything blocking it.
Dec 28, 2009 | Miele Optima G2470SCVi Built-in Dishwasher
My front loading Kenmore is stopping in the middle of its cycle.
"F21" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 29, 2009 | Kenmore Washing Machines
Miele Platinum dishwasher: Can't get past the intake/drain step
It could be that the drain pump or the non-return valve is clogged. Refer to the manual about how to check the non-return valve. It is under the "Maintanence" section. Here is a link to it:
https://www.miele.com/pmedia/ZGA/TX2070/9953540-000-02_9953540-02.pdf
Nov 03, 2017 | Miele 24 in. Touchtronic Platinum Built-in...
Kenmore Elite Oasis HE top loader has LD error code
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jun 16, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Miele 23 in. Novotronic G841 Built-In Dishwasher Logo
2,107 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
