Question about Whirlpool GH7208XR Convection / Microwave Oven
New unit used 3 days. Microwave beeps and screen goes to menu, or set time screen. Sometimes changes the date all by itself. Does this in the middle of the night all night long.
Microwave worked fine for 1 day. Then suddenly we started hearing beeps when we weren't even using the microwave. We discovered when it beeps, the screen goes to another menu such as choose cook method, but most often to set date and time. Date was set on November 5, 2012. It beeped and changed the date to Nov 23 all by itself, changed the year to 2006, then beeped again and went back to Nov 5. Sometimes it goes back to time and date display but is getting worse. It has stopped operating sometimes. You can sometimes make it operate between beeps. Beeps and changes in menu happening more often, every few minutes. Had to unplug unit. Whirlpool support is nonexistant.
    Problem Solver:
  • 49 Answers
I advice you to contact service if it has guarantee. This seems to be a psychological problem about your oven(!). Technical person need to do an electronic research surgery on its board to see if there is any wrong thing.
Posted on Nov 05, 2012
MicrowaveSvc
  • 9047 Answers
SOURCE: Whirlpool RMC275PD microwave won't start
I would first suggest unplugging the oven for a few minutes to give it a reset. On Whirlpool brand microwaves, you will hear a series of beeps when you hit START if one of the following is true: - the control panel is not programmed correctly - the door is not shut - there is a problem with the door latch system - there is a problem with the control panel If you do not have your owner's manual, you can download it here: http://www.whirlpool.com/custserv/literature_search_results.jsp?searchTerm=RMC275PD#literror It doesn't sound like the control panel is locked. When the control panel lock is activated, you will see "Loc" and a lock symbol in the display and only the clock, timer, and oven light will operate. If that does not solve the problem, then you have oneof the other problems as listed above. If you need further help, please reply / add a comment here.
Posted on Nov 18, 2006
MicrowaveSvc
  • 9047 Answers
SOURCE: Whirlpool Microwave MH6130XEB
If it's the cooling fan inside the main body of the microwave, I would suspect an open thermistor / temperature sensor. If it's the vent fan (for the grille across the top) then I would suspect the hood thermostat is shorted. The oven should have a "mini-manual" (tech sheet) inside, usually in the control panel frame behind the door open button. It shows these parts and how to test them. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Posted on Jun 26, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Timed Power Loss
It sounds like your magnetron is failing, but generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 02, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Whirlpool microwave cook light goes on but oven does not work
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Having had to wiggle the door to make it work is the giveaway.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Your model number (since it's a Whirlpool) will be something like MH1150xxx#m, GH6177XXX#, etc.
The model number will be located on a tag either in the cavity or around the door frame if it's an over the range model, or on the back if it's a counter top model.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If yours is a counter top model, you will need to remove the outer cover.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Feb 16, 2009
  • 1416 Answers
SOURCE: I have a Whirlpool MH7130XEQ-1 microwave.
hello,
what this means is partial contact problem from the internal wire from the power supply.
however, what you need to do tofix up your oven back to live i to unscrew your your oven from the luck key (stroll) and then trace down the wire to the element i.e heat provider and the fan to see which wire has gone wrong .
please before you can carry out this function you will have to disconnect any form of power supply on the oven.
thank you and thanks for using fixya.
Posted on Jun 01, 2010
My frigidaire model # ffmv164lsa microwave oven keypad does not seem to work. Some times it goes on by itself. Or if you unplug it 05 will go on. Cant set the clock. or if touch anything nothing happe
The answer you seek is to replace the keypad. Your unit is Stainless for you would have to replace the console as one piece part number 5304477377 I this helps. Good Luck
Apr 19, 2014 | Microwave Ovens
The keypad is acting crazy sometimes it will just beep for a long time. When it is done cooking the signal goes on and on and when you try to use it the keys don't always work or they beep for a prolonged...
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes then try again.
Aug 11, 2013 | Emerson Microwave Ovens
My microwave beeps for no reason even when not in
There is a reason. Try to reprogram the unit. Start w/menu: date, time simple stuff. This should take care of it.
Nov 05, 2009 | Microwave Ovens
Display shows 6's across screen & beeps
HI. the touch pad board is malfunctioning at this time. you will need to replace this damaged touch pad device asap. this will fix your issue.
Sep 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
POSSESSED MICROWAVE!
wow.......... an exorcism may be in order.......Sadly your microwave circuitry is malfunctioning which is a costly repair. I would seriously consider trashing that possessed unit and purchasing a new one. the new ones are greener too, use quite a bit less electricity
Jul 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
LG Microwave Beeps 3 times, display shows F3 and keypad dead.
Since it's less than one year old, it would be fully covered under warranty.
I'd suggest returning it to the dealer or contacting the manufacturer to get it fixed free.
For more Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here. You can get warranty info & find a local authorized servicer.
Jun 03, 2009 | Microwave Ovens
Beeping at night
if it beeps you might as well just unplug it
Dec 08, 2008 | Panasonic NN-C994S Convection/Microwave...
I have a danby designer microwave oven modle # DMW753W SIN # 170705120067 the timer keeps beeping and won't keep time.When you try and use it it will not shut off. we got this as a gift for christmas...
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again. If that doesn't work, leave it unplugged for maybe an hour.
If you still have trouble, contact Danby Customer Service US / Canada.
Nov 05, 2008 | Danby Microwave Ovens
MY MICROWAVE WILL NOT DO ANYTHING
I couldn't find those exact trouble codes, but a common problem is when the controller gets damp, either from steam rising from the cooktop or someone spraying cleaner directly on the keypad. Cleaners should always be sprayed on a soft cloth, then wipe the keypad with the cloth. Also, GE / Samsung codes of F1, F2 and F3 may be the same since Samsung makes GE microwaves. Those would mean trouble with the temperature sensor, keypad, or control panel. Assuming your control panel is clean and dry, it may be time to call for service.
Apr 04, 2007 | Samsung MW1080STA Microwave Oven
Whirlpool GH7208XR Convection / Microwave Oven Logo
472 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
