Question about Mitsubishi Televison & Video
I have white spots on the screen of my Mitsubishi 1080p hdtv
Need help getting the spots to disappear
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
This is common--a few spots and then more over time can happen--damage to the optical light engine display----Major part and major labor.
Posted on Nov 06, 2012
Luvlee
  • 59 Answers
SOURCE: Purple and Blue Spots on Screen on Mitsubishi WD52527 52 Inch HDTV
It could be only dust building up and it needs a good cleaning or it could be the DMD board is going bad and needs to be replaced.
Posted on Mar 23, 2008
  • 146 Answers
SOURCE: Mitsubishi 1080p 73'' DLP HDTV - Color distortion
You need to replace the "light engine". This is very very difficult. You need to take it to a repair shop. But this will be very expensive. Around $1,000.00
Posted on Nov 20, 2008
marketex
  • 371 Answers
SOURCE: Blue spots on the screen.
Assuming that an alignment tool is not your problem, if the blue spots are regularly arranged in rows and
columns, I would have to say that the blue filter of your three tube (red blue green) array needs service.
Posted on Apr 14, 2009
  • 1779 Answers
SOURCE: my mitsubishi 60 inch projector
Replacing the Light Engine is the only remedy. Cost is usually in the area of $900-1100 dollars.
Posted on Apr 26, 2011
SD Tech
  • 14553 Answers
SOURCE: White spots on screen Need DMD
This is something of an urban myth....The "DMD chip" is actually the LCD display IC for the set; yes I have seen some listed on EBAY---still a myth----they are replaced (when a light engine is rebuilt in a space age lab or environment) under exacting conditions----if positioned a micron off in any direction picture will be tilted in some way---this is also not like changing spark plugs in a car, if you have a optical engine issue like spots etc, either get a rebuilt engine from Mitsubishi or buy a new set.
They usually require some parts for old engine (mounting brackets etc) be installed on new or rebuilt engine.
I did see the "chip" for another model listed on ebay today.(100.00 PLUS)
I understand the engine is expensive, I replaced a lot of them when the sets were in warranty---more Mitsubishi than any other brand with Samsung a distant second.
I am sure Mitsubishi does not offer the part for sale--they want to sell a tested rebuilt engine only.
I wish you luck but have little hope you will find a "part" other than the whole engine.
SD TECH
Posted on May 14, 2011
Fix a lot of white spots on mit65dlp serial wd65737
The white spots are pixels that are burned out. They will just gradually get worse. You will need a new screen or just replace the whole TV. Probably buy a new one for what it will cost to get a new screen put in it.
Nov 29, 2014 | Mitsubishi WD65737 65 inch DLP 1080p HDTV
I need a 73' tv screen for a mitsubishi model wd=73638
Contact the authorized service center for Mitssubishi. It can't be purchased from open electronic spare part market.
Electro help
Jul 20, 2014 | Mitsubishi WD-73638 73 inch DLP 1080p...
Mitsubishi DLP TV wd-73734 HAS WHITE SPOTS
Bad optical light engine, most expensive part in set
Dec 09, 2012 | Mitsubishi WD-65733 65" HDTV
Mitsubishi wd60735 white spots apperaing
Thats a very coomon problem which is caused by a failed DLP chip. The mirrors get stuck and thats what causes the white spots they will keep multiplying untill the entire screen is filled. You will need to replace the DLP chip. You can get the replacement DLP chip and illustrated instructions on how to do the repair from www.tvrepairworld.com
Oct 29, 2012 | Mitsubishi WD-65833 65" HDTV
How to clean the chamber of a Mitshubishi tv
white spots is not likely to be a cleaning issue==more likely if tiny spots a bad optical light engine.
May 15, 2012 | Mitsubishi WD-65733 65" HDTV
Just paid to replace the lamp 2 weeks ago in our mitsubishi 73 dlp 1080p tv purchased a 5 year in home contract with Tweeter Sevice net 1/2008 lamp fixed and picture is once again great but now the 73...
Mitsubishi that the one,who u should contact.Talk to them make some kind of deal with them to help u to do a repairing or replace the tv Light Engine Projection Block.That the tv problems,this problems a design flaw on the tv Light Projection Egine Block the IC they put in that causes of this white spots are showing up will continue showing up more and more white dots.It will not stops.
Sep 03, 2011 | Mitsubishi WD-73833 73" HDTV
I have white spots and black spots on right side of Mitsubishi WD-C657. I've done research online, and have heard its the dlp chip. Is that true, and if so, is it something that I can replace myself,...
This tv is it the DLP projection light engine block main board itself is the problems,not easily to go into the tv itself and replacing the IC chip itself.Must take out many mechanical parts to get u the Light engine block it self.U can replaced IC but somethime the IC chip it replaced,will not solved the problems,because the tv problems now the it is spreading and going on beyond the IC chip itself.If want to keep this tv very exspensive repair,i would reconmend hire a bound qualify tv tech replaced the whole Light projection block itself,but first call Mitsubishi for some kind of deal,they might help with the repair amount cost.
May 13, 2011 | Mitsubishi WD-C657 65" HDTV
White Spots Streaks on DLP Screen
If you bought the set new you might just want to contact the manufacturer - if they are decent, they might just try to help you out with your dilemma.
Apr 02, 2017 | Mitsubishi WD-65833 65" HDTV
Mitsubishi WD-62525 Input 480i
it is just saying what input you have it on and what level of hd your getting (480i 480p 720i 780p 1080i 1080p)
Apr 02, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
64 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
