Philips Lamp For Hitachi Models 60v500 60v500a 60vx500 Logo
Posted on Nov 05, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to reseat timer lamp
Serial number v5b027152
Anonymous
Level 3:
Top Expert:
  • Philips Master 14,553 Answers
  • Posted on Nov 06, 2012
Anonymous
Philips Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2715255
Points
48227
I don't think the 50 or 60V500 has a reset--give Hitachi customer service a call.
Status light blinks seven times
the lamp timer is failing
lamp timer chip is on the lamp housing,is a little chip
you need to reset the timer chip by using a Programmer
select a date of 0 hour..
Our company supply this chip with 0 hours USD15
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
1helpful
Message on screen says lamp needs to be replaced then timer reset. Need lamp and instructions to reset timer
The lamp time reset will be or should be in the owner manual---Google the model number with keywords "lamp install" with the model number and the "manual" with the model number---Google can be a great help.
How do i reset lamp timer on Barco iQ G350
Here is the instruction set: From the manual
How to reset the lamp runtime in the iQ/iD ?
1. Press MENU to activate the Tool bar
2. Press → to select the Lamp item
3. Press ↓ to Pull down the Lamp menu
4. Use ↑ or ↓ to select Reset runtime
5. Press → to pull down the menu
6. Use ↑ or ↓ to select the lamp to be reset (image 10-10)
7. Press ENTER
A dialog box is displayed (image 10-11)
8. Use ←or →, the numeric keys on the remote, or the keypad to change the serial number of the lamp (serial number 0000000 will
not be accepted).
Image 10-10
R5976491 IQ
I have a Panisonic PT-52LCX15 I replaced the lamp and now I'm trying to reset the LCD meter, I have tried holding the vol button and the split button and the red lamp light still is on, maybe you could let...
The lamp light should NOT be RED.
The lamp light should be yellow for the lamp timer warning.
There are two ways of retting the lamp timer=
1) on the TV use the vol - button. push until vol goes to zero, then keep holding it down
on the REMOTE push the "split" button
the yellow light should go out indicating that the lamp timer has been reset
if this fails to work,
on the REMOTE, use the "PLAY" button, instead of "split".
you may have to try this a few times to get it to "take". you'll know when the YELLOW lamp light goes out.
However, a RED LAMP light means you lamp is not working or missing.
reseat your new lamp into the TV...and be certain the LAMP DOOR is securely CLOSED.
How do you reset the lamp timer on a Sim2 Domino 60.
I would need to know the serial number of the unit.
You need to press 2 buttons on the remote then enter a five digit number to enter the service menu to reset the lamp counter.
3helpful
2answers
I have an Compaq MP1400 projector not working
Hello :
1:Remove the lamp from the projector. Ensure that it has no cracks, discoloration or "smoky" appearance.
2:Try removing and reseating the lamp, or to try another lamp.
3:Reset your lamp timer. Most projectors have no way of knowing if you physically have replaced your lamp or moved it out . They rely on the user resetting the lamp timer
4:Pull the lamp back out of the unit, give is a brisk shake and reseat the lamp. Occasionally there is some buildup on the lamp contacts or filament during manufacturing.
5:Are the input and output vents blocked or obstructed in any way? That could cause overheating problem and what you see with your projector is one of it's symptoms .
6:Are the filters dirty or clogged? Most manufacturers will recommend filter cleaning on a monthly basis depending on usage .After cleaning the filter always remember to reset your projector .
7:Remove any extension cords, power strips and/or surge suppressors. Many current model projectors will not even try to ignite the lamp if they detect drops or fluctuation in voltage supplied to the unit. This is a safety feature to reduce stress on the lamp.
PLEASE RATE !
2helpful
Fan running but the lamp is not on, I have
Hello :
Please check on of these solutions :
3:Reset your lamp timer. Most projectors have no way of knowing if you physically have replaced your lamp. They rely on the user resetting the lamp timer
PLEASE DON'T FORGET TO RATE !
6helpful
Eiki lc-nb3s projector... fan comes on but no lamp then fan shuts down after about 5 seconds. Green "Ready" light and Red "Lamp" light are on... Have tried the reset button and cleaning the filter... no...
1helpful
Lamp timer
From the Vivitek RP51 manual:
To Reset Lamp Timer please follow these steps:
1.) Press "MENU" and "VOL ADJ >" buttons on the right hand side of the RPTV for three (3) seconds while the RPTV is on.
2.) "Lamp Timer Reset" should appear on screen.
3.) Press "OK" to reset the lamp timer.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
