Kenmore elite washer wont come on - Washing Machines
  • 8 more comments
  • app_3rp18977 Nov 07, 2012
    it is 110 22066102, we have found that the EMI filter is bad. Can we buy a new one?
  • Richard Roth
    Richard Roth Nov 07, 2012
    Do you have the part number off the EMI filter?
    what we were able to find was 08msw6 on one line and the next was 8528338
    also read that we may be able to bypass that part?
  • Richard Roth
    I don't have any info on that model number. Is it a top load or a front load model?
    top loader. it's the calypso
  • Richard Roth
    OK, check that model number again. It should begin with something like GVWxxxx. I have service manuals for the machine.
  • Richard Roth
    Do you get power to the control panel?
  • app_3rp18977 Nov 13, 2012
    we replaced the EMI filter and till no power even though the board shows that it is getting no power
  • Richard Roth
    Richard Roth Nov 13, 2012
    Test the control panel ribbon cable across P11-1 & P12-5, when start is pressed, these should go from infinity to a readable level. Post back the results for me. If you should need to contact me immediately, please go tohttp://appliancecafe.com and use the contact form link from the top of the page. This will alert me instantly to your request.
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 06, 2012
jgwhomeequip
  • 1902 Answers
SOURCE: Iget a f-11 trouble code on my kenmore elite he4t washer.
REplace your MCU. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem. Go onto kenmore.com and find your right washing machine and replace the part yourself. First try and take the wiring harness off and then reconnect it and see if the error code goes away if it doesnt then replace the part. Please Rate. Thank you
Posted on Feb 12, 2009
bschilz
  • 2049 Answers
SOURCE: FDL fault code on kenmore elite washer
F DL
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Posted on Nov 08, 2009
Testimonial: "Very quick answer.......even better was it solved the problem. Thanks"
  • 1382 Answers
SOURCE: Kenmore elite he washer lock light. cannot open
You can manually Unlock the door Lock System
1. Unplug washer or disconnect power.
2. Remove the lower kick panel.
3. Reach up along the inside of the front and locate the bottom of the door switch/lock unit.
4. Located on the bottom of the door switch/lock unit is a tear-drop shaped tab.
5. Gently pull the tab down about a ¼" or until a click is heard.
6. The door may be opened.
Thank you !!
Posted on May 31, 2010
  • 662 Answers
SOURCE: f20 message on washer kenmore elite HE5t
http://www.fixya.com/support/r3608632-f20_error_code
Posted on Jun 04, 2010
blueextc3221
  • 15935 Answers
SOURCE: MY KENMORE ELITE WASHER WON'T DRAIN.
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
44921300 elite kenmore owner manuals
http://downloadfreemanuals.com/kenmore-washer-manual/
Apr 25, 2013 | Kenmore Elite 45986 Front Load Washer
Washer wont spin
Here is a tip that will help you with the not spinning or agitating problems....
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
May 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite he5t washer wont start or light up
Take the top cover off with the 3 torque screws. need to check if there is power going to the interface board. If there is then the interface board needs to be replaced
Nov 04, 2009 | Kenmore Elite HE5t Washer
Kenmore elite 3t the front light to select wash blinks but when s
Press 'drain' & 'spin' together for 3 seconds to see if it clears. This is your control panel lock.
If not cleared unplug the washer & wait for 30 minutes for the CCU (computer) to reset.
If helped you can rate.
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore front load He3 washer: door wont unlock
happened to me once - I just unplugged the machine - waited a minute and plugged it back - it - then used cancel button
Feb 27, 2009 | Kenmore Elite 45986 Front Load Washer
My kenmore elite oasis runs fine but wont go through spin cycle
Try replacing the motor coupler between the motor and pump three small pieces about 18.00 dollars at sears parts store.
Jan 13, 2009 | Kenmore 23822 Top Load Washer
Kenmore Elite Washer top load Wont spin
Sounds to me like the belt is broken or has slipped off. Try taking the back off (6-8 screws) and you will immediately see if that is the problem.
Dec 23, 2008 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite washing machine and the spin cycle will not work.it both fills up and drains water but it wont spin.
I have a kenmore elite washer. whwn on spin cycle it does not spin and als o will no agitate. There is a loud noise wen on spin cycle. Please help
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
