Question about Spe Clothes Washer Electronic Control Board - 201577P
Got candy gof462-80 washing machine 2 yrs old put it on spin or drain or any other cycle and it fills up and starts heating water done the norm as in check filter turn off for 10 mins and no joy.could it be control board?
Candy grand o go1682
you should clean the knob with alcohol careful there is spring and a small ball in it
Feb 09, 2014 | Washing Machines
Machine starts to spin out of control
Both problems could be related to a blocked drain, from what I can see in the manual. 3 Things to check -
1. Clean the filter - instructions can be found on age 24 of the manual.
2. Check the drain hose has no kinks/securely fitted.
3. Check the drain trap under the sink for blockages. Make sure waste water can drain away freely.
Keep a couple of old towels handy when checking the drain filter, if water is trapped in the machine, it will flow out of the filter housing when you remove it. Try a drain cycle for a minute or two before you remove the filter, then turn the machine off, and check it. That way you'll have drained as much water as it will allow.
The manual can be found here- http://service.candy-domestic.co.uk/manuals/pdfs/CNW156.pdf
Jan 07, 2014 | Candy CNW136 Front Load Washer/Dryer
Filling with water then does not finish cycle
There should be a sensor on the door that tells it the door is shut. Check that this is being pressed when the door is shut. You should see it where the doormeets the washer and can use something to press it. Put your washing in spin cycle and press it if it starts spinning there is your problem( make sure the washer is empty ). If it still doesn't work you will most likely need a repairman.
Apr 18, 2012 | Candy Washing Machines
My washing machine Candy CE10 does not spin and drain water
HI. firstly have you checked that all dirty water outlet pipe is clean and not blocked. or the cycle circuit could be broken.
Jan 13, 2012 | Candy Washing Machines
Washing machine candy grand'o 1400 has stuck, vanish stain light
Ok, turn the washing machine off and unplud. Open the flap at the bottom left of the machine. Put a bucket underneath it. Unscrew the cap. Water will pour out - lots of it and very quickly - so make sure you have a bucket underneath it and lots of towels round that.
Once the water has drained out, check there are no blockages in there. You may find that some coins or buttons flush out with the water. That will be your problem.
Once clear, screw the plug back in and turn on machine.
Dec 23, 2009 | Candy Washing Machines
I have a candy AQ 1200, it fills with water then drum turns and s
sounds like m/c is waiting to heat up water but heating element is not working or timer switch not going on to next cycle.
Aug 21, 2009 | Candy Washing Machines
GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
Apr 24, 2009 | GE Profile WPRE6100G Top Load Washer
Machine has power but not moving through cycle
Hi there. I have a candy cwb110 and the bearing on the motor went. I replaced this put it all back together and now when you set it to wash it wil only spin for 30secs and then it will end it's cycle and do no more!? wil drain it's water fine on that mode just wont run it's wash cycle. motor sounds healthy when it is spining.
Is there a reset on the computer side of things or something i may have done wrong?
Cheers
Wyn
Mar 10, 2008 | Candy AQ130 Front Load Washer
No spin
Your problem is that the carbon brushes on the motor have worn out and need replacing.. eaisly done
Dec 10, 2007 | Zanussi FJS1225W Front Load Washer
Spe Clothes Washer Electronic Control Board - 201577P Logo
59 people viewed this question
Top Spe Washing Machines Experts
Are you a Spe Washing Machine Expert? Answer questions, earn points and help others
