Question about Kenmore HE2 Plus Front Load Washer
How to clean drain hose? - Kenmore HE2 Plus Front Load Washer
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 06, 2012
Drain hose very rarely plug up. you can remove the hose and check it but I would bet the relay that opens the drain on the washer is not working correctly. If you have have a bit of tool skills they are relatively easy to replace but check the hose first.
Apr 09, 2014 | Daewoo DWD-WD1353WC 4.5 Cu. Ft Capacity...
E 20 is flashing on machine
"E20" is indicates a drain problem.
- Set towels under the hoses in the rear of the washer and disconnect the drain hose. Clean the drain hose screen and look for debris where the hose connects to the washer. Clean as necessary.
- Remove the front access panel from the washing machine and locate the drain pump. Remove the screw clamp and clean out any debris that may be causing an obstruction.
- Clean the sump hose that is connected to the trap cup and reassemble. Close the front access panel.
- Restore power and press "Drain/Spin" to remove any remaining water from the tub.
Hope helps (remember to rate this answer).
Sep 09, 2011 | Frigidaire ATF6000ES Front Load Washer
Diswasher will not drain
Clean the drain hose screen and look for debris where the hose connects to the washer. Clean as necessary. Remove the front access panel from the washing machine and locate the drain pump. Remove the screw clamp and clean out any debris that may be causing an obstruction.
Hope helps.
Sep 09, 2011 | GE Dishwashers
It won't drain away water.
take drain hose put in pail at ground level if it drains trouble with pump
if no drain try
put a hose in drain pipe hose force water back into machine then see if it drains the plumbing of machine has to cleaned spin tub shall have to be remove to clean
Jun 12, 2011 | Washing Machines
I have the Kenmore Elite HE3t and the control panel lets me change the settings but the door stays locked and the drain pump (off the filter) keeps going but there is no water to drain...cleaned drain out...
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Please check this video for cleaning:
Hope this helps... Please post back if you need more information.
Daniel
Mar 31, 2011 | Kenmore Elite 45986 Front Load Washer
My lg washer and dryer wm3431hs isn't draining. I took of the hoses in the back, cleaned the filters and still nothing please help!
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps...
Daniel
Jan 10, 2011 | LG WM3431H Washer and Dryer
How to remove waste hose from machine?
1 Turn off the circuit breaker that controls the dishwasher.
2 Open the dishwasher door. Locate the two small screws holding the bottom valance trim piece. Remove the screws and the valance, revealing the lower pump assembly and drain-hose connection.
3 Remove the hose clamp. Disconnect the drain line by pulling the hose.
4 Find the other end of the drain line under the sink; it is connected to the drain tail piece or the garbage disposal. Remove the hose clamp and disconnect the drain line. The dishwasher drain hose is now disconnected at both ends.
5 Pull the dishwasher drain hose into the sink base through the hole between the dishwasher and the sink base.
6 Take the dishwasher drain hose outside or to a wash sink. Run hot water through the line to clean and unclog it. When you see water running freely through the hose, then it is clean. If the hose cannot be cleaned, replace it with a new drain hose of the same size and length.
7 Feed the clean dishwasher drain hose back to its original configuration. Reconnect both hose clamps. Reinstall the valance, turn on the circuit breaker and test-run the dishwasher.
Nov 29, 2010 | Smeg CSU2001 Built-in Dishwasher
MY GE DISHWASHER IS CONNECTED AND RUNNING, UNIT HA...
hi just try this Is the door open or unlatched?
Make sure the door is completely closed and latched.
Was the selected cycle interrupted before completing?
The Clean light will come on when the cycle is complete. Wait until the Clean light comes on before trying to manually drain dishwasher. Press Cancel/Drain to try and drain the standing water.
Is the water level just covering the pump module?
This is normal. A small amount of water will be seen in the bottom of the sump area at the base of the pump. This is to ensure that the pump seal does not dry out.
Is the dishwasher drain hose connected to a garbage disposal?
For many dishwashers, the drain hose is connected to the disposal and the knockout plug must be removed from the disposer inlet.
Is the drain system blocked?
Run the disposer to clear the drain system.
Do you have an air gap at your sink?
Check to see if the air gap is blocked by foreign material. To clean the drain air gap, follow the cleaning instructions provided by the manufacturer. With most types, you lift off the chrome cover, unscrew the plastic cap, and then check for any soil buildup. Clean if necessary.
Is there a loop in the drain hose less than 20" (50.8 cm) above the floor?
Make sure the drain hose is looped up so that it touches the underside of the counter before connecting to the sink drain or disposer.
Is there a kink in the drain hose?
Replace a kinked drain hose.
Did you reuse an existing drain hose?
Make sure to use the new drain hose that came with the dishwasher.
Is the sink drain clogged?
If the sink is not draining well, a plumber may need to be contacted. Most dishwashers connect to the sink drain. If the sink drain is clogged, the dishwasher can't pump out water.
Is the drain hose too long?
If the supplied drain hose was replaced with a longer one it must be shorter than 12' (3.7m).
May 17, 2010 | Dishwashers
Kenmore 44072 Front Load Washer Drain Hose Cleaning
Try this link for step-by-step instructions. More than likely you will have to clean the drain pump as well.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If you are having trouble draining the water from the wash tub, and cannot get it to drain with a shop vac, you can drain it directly from the tub. If you don't own a shop vac, you may have to bail. If your drain pump does not have a clean out trap, remove the inlet and outlet hoses to access the inside of the drain pump. Inspect the pump impeller for obstructions and/or damage. If the water will not drain when you try to pull a vacuum on the drain line, you may have to disconnect the drain hose from the bottom of the wash tub. In some front loaders, there is a ball valve in the drain hose from the bottom of the wash tub to the drain pump. This ball can act as a collection pint from lint and debris. You will need to remove the hoses from the bottom of the wash tub to clean this area. I would recommend doing this as a LAST resort. Often, it can be difficult to reconnect this hose to the tub and get it to seal correctly. I hope this helps you. Please post back if you need further assistance.
May 28, 2008 | Kenmore 44072 Front Load Washer
My direct drain doesn't work anymore
I fixed the same problem, finally. At first it was sufficient to clean the outside hose (it was filled with a **** builtup). Then it stopped working again. I decided to open the unit and see how easy it is to clean the inside drain hose. It is very easy. Once you unscrew the back panel (8 screws total if i remember correctly) you can access the back and you see the drain hose that connects to the drain outlet. To remove it and clean it, you will have to unfasten the big capacitor (3 screws). Then, remove the hose and clean it (mine was full of that same **** stuff). Reinstall - you will need a tie wrap to connect the hose at the top, as it is from the factory. Very easy operation and now the dehumidifier is draining again.
Aug 21, 2007 | Danby DDR583R Dehumidifier
Kenmore HE2 Plus Front Load Washer Logo
14 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
