Question about Electrolux Washing Machines
Doesn`t dry clothes
The heater on the upper side does not produce heat. There is the same voltage (220 V) on all four connections of the heater. Possibly electronic?
    Top Expert:
  • Electrolux Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 06, 2012
  • g_vckov
    g_vckov Nov 06, 2012
    Electrolux EW 1289 W
  • Richard Roth
    Richard Roth Nov 06, 2012
    Look to see if there is a partial break on the coil.
5 Suggested Answers
  • 43 Answers
SOURCE: Hotpoint WD72 - error message heating or Heater
take off the lid on top you will find two round obects these are the thermostats one will have a green dot this part is the problem and is very common bye a thermostat kit from your local parts supplier this will be very easy ( some thermostats have a tiny reset switch in the centre if so press it and test your drying cycle )
Posted on Nov 12, 2008
  • 109 Answers
SOURCE: smeg wdf1 washer dryer not drying clothes
Hi, Take the top cover off and click the little red button on the thermostat/overload (small black box). Then try again. Sometimes these trip out as a safety precaution.
Posted on Jun 16, 2009
james klgr
  • 362 Answers
SOURCE: no heat
take off the back of the dryer you will see wires to the lint tube thats heating elements take the removeable plate off and see if its clogged with lint if so clean it out that should fix it if its not elements are probably bad. its also easy fix
Posted on Oct 18, 2009
  • 901 Answers
SOURCE: Dryer is not working
The air heater and the blower requires to be tested/checked.
Posted on Apr 06, 2010
I have a GE Profile DPVH880EJMG Dryer. It drys but shuts off before clothes are dry. It doesnt matter what sensory cycle it is on or time dry.
i SAY CHECK MOISTER SENSOR, CYCYLING THERMOSTATS? AND HI LIMIT THERMNOSTAT AS WELL AS THERMISTORS IF UR MODEL HAS THEM? UR REPAIR MAN SOUNDS LIKE A SHAM.
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or
overheating.
The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with avolt-ohm-multimeter (VOM)set to the RX1 scale. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12 ohms. If the reading is higher ohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
OR you may have a broken centrifugal switch in the motor because this switch activates the motor and the heater as well. supposed to be if the motor does not run , the heater should not heat in order not to create fire but if the motor is not running, and the heater is still heating, then there could be a problem with the motor centrifugal switch that is connected to this interlock switch that should trigger the heater.
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum 9 this is why in some cases the dryer will operate at lower cycles like gentle or low heat but not at higher settings?)
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :
http://www.ehow.com/info_12203962_check-dryer-thermistor.
GOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
How to Check Dryer Thermistor eHow
Dec 08, 2016 | GE Dryers
How do I set timing to dry clothes for 1 hour?
overheating.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!!
Mar 03, 2015 | Dryers
My crosley dryer is not drying my clothes
GOD IS STILL GOOD !!!!
overheating.
Sep 06, 2014 | Dryers
Why does dryer not produce heat when in use?
overheating.
GOD IS still GOOD !!!!
Sep 05, 2014 | Dryers
My kenmore elite dryer no longer produces heat
overheating.
OR you may have a broken centrifugal switch in the motor because this switch activates the motor and the heater as well. supposed to be if the motor does not run , the heater should not heat in order not to create fire but you said that even the motor is not running, the heater is still heating, then there could be a problem with the motor centrifugal switch that is connected to this interlock switch that should trigger the heater.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Aug 24, 2014 | Dryers
I have a Kenmore dryer model 417. I start to dry clothes and it kicks off after just a minute and lights flash and signal beeps and continues to do this every minute or so even when not trying to dry...
overheating.
Aug 11, 2014 | Dryers
No heat
You need to verify the unit has 220 volts supplying it, your heating element requires 220 voltage to function properly. Here a video on how to check it. If your not familiar on how to verify volt at the receptacle DO NOT ATTEMPT THIS - GET A QUALIFIED TECHNICIAN TO IT FOR YOU!
Feb 02, 2014 | Abbaka White Knight 38AW Electric Dryer
Dryer does not heat up/ dry clothes
sound like heater or stat call them out.
Sep 28, 2009 | LG DLE7177 Dryer
Dryer not drying
Locate the heater element ,disconnect one or both ends. ohm it out with an ohm meter. Zero reading means tha it is open and needs to be replaced. Maxium or full; scale reading on the right side means that it is shorted and needs to be replaced. Middle reading on the meter and I would look elsewhere,such as;  Voltage coming to the element if you are used to dealing with 220 volts, live.
Nov 24, 2008 | Maytag MDE2400AYW Neptune Electric Dryer
Kenmore Dryer 697267
Most dryers are 220 so they can produce the amount of heat required to properly dry clothes. I would Not recommend trying to convert the dryer to 110 voltage. This may cause you alot of unwanted problems. I would find a Qualified electrician to install a 220 outlet at the location of the dryer .
Apr 26, 2008 | Dryers
Washing Machines Logo
24 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
