Question about LG WM-2277HW Front Load Washer
How to replace the drain hose in my LG WM2277
    Top Expert:
  • LG Master
  • 9,472 Answers
Remove the rear access panel.
Posted on Nov 06, 2012
3 Suggested Answers
BIKER T
  • 909 Answers
SOURCE: LG WM2277
OE(outlet error). Your drain pump is stuck. Remove it and check what the obstruction is. Reinstall and test.
Posted on Jul 19, 2010
pjhislay1
  • 822 Answers
SOURCE: Model - LG F1480FD. Need
underneath......
drag maching to outside door and let old hose hang outside
this will drain alot of water out of machine then upend it to replace old hose with new 1
cheers
Posted on Mar 27, 2011
What does oe stand for on a LG washer
Hello. OE on an LG washer is telling you it cannot drain. Start by opening the small panel on the bottom left of the washer and checking the drain screen/trap. If the washer is full of water you are going to need to removed the water from the tub by taking the small capped hose located in the same compartment, remove the hose cap and drain into a bucket. Afterwards remove the trap and check it for debris. If it is full of debris, clean it and install. If there is nothing in the trap, then you likely have either a jammed up pump ( bobby pins are notorious for this) or a failed pump that will need to be replaced.
Apr 28, 2014 | LG WM2277 XL Front Load Stackable Washing...
Lg wm2277 does not drain or spin
if it does not drain it will not spin humming noise is probably something jammed in the drain pump if youre machine has a clean out you can access the inlet to the pump and clean out the debris from there if not you will have to pull the hose off . if you bail as much water as you can from the tub and tilt the machine back at a good angle it will be possible to get to the pump without having to get a shop vac to clean up the water after words.
Apr 07, 2014 | LG WM Washing Machines
Looking for advice on how to clean drain hose on LG TROM 2277HS
You can download the manual for your model in the below link
Service manual
http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf
Owners manual
http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Owners_Manual.pdf
Mar 17, 2011 | Washing Machines
My LG washing machine is giving me a dE error
Drain error. It took longer than normal for the machine to drain. This is caused by the wrong detergent, too much detergent, drain hose way too high, slow drain, and my fave: frozen drain. I have your wm2277 deluxe polyunsaturated, 99 and 44/100th% real deal repair manual. Right ova HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 15, 2010 | LG WM-2277HW Front Load Washer
LG WM2277 "OE" ERROR. PLEASE HELP
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!
Jan 12, 2010 | LG WM-2277HW Front Load Washer
Le code and will not drain or spin
I read a post on another site, here is the link for the owners manual, see page 18 for the LE error code
I simply unplugged my machine for 30 seconds, plugged it back in and it worked like a champ.
Oct 13, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
BOTTOM DRAIN HOSE LEAK
http://136.166.4.200/contents/Laundry/WM2277.htm
Try that website and download the service manual..
Hope that helps...
Aug 07, 2008 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
190 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
