Question about Acer Aspire 5315 Notebook
Turn on why can't i turn on my acer aspire 5315. i press the power button nothing happens but the power button light is lit. this laptop is new
  • 2 more comments
  • ritzie917 Jan 05, 2009
    its brand new. brought from the states by my aunt and was sent here to the philippines(actually my other aunt brought it here when she went home last week), when i tried to turn it on last night it wouldnt turn on. the power light is on.
  • jasonm74 Jan 06, 2009
    my problem is identical.....it will not turn on but it is lit up...the laptop is new also.....What the heck!!!!!!!
  • Adam Jones May 11, 2010
    Tell me exactly what happens when you turn it on..... any lights any sounds
    Has it ever worked? If so it may have had an error going to sleep. Try taking out the battery and make sure it is unplugged. Then reboot. Let me know what happens.
I have an acer aspire 5315 and the screen goes black I have tried to go into set up and I have taken out bateries etc but it's still not working . Any help is greatly appreciated thanks
Hello mariawint589,
The following instructions are from the Acer Aspire 5315 user's guide (page 35):
The computer's power management system automatically blanks the screen to save power. Press any key to turn the display back on, three hings might be the cause:
*The brightness level might be too low. Press <Fn>+<right-arrow key> (Increase) to adjust the brightness level.
*The display device might be set to an external monitor. Press the display toggle hotkey <Fn>+<F5> to toggle the display back to the computer
*If the sleep indicator is lit, the computer is in sleep mode. Press and release the power button to resume.
If this solution is helpful please click a thumbs-up rating.
Have a great day,
martyshaw152
Nov 12, 2010 | Acer Aspire 5315 Notebook
My acer aspire 5315 wont turn on I press button and it lights up as if gonna come on but screen stays blank and then it powers out its only 1 year old help
Maybe the screen has some problems, or try clicking to the power button for some minutes, or Try charging the laptop, or try to change the laptop's battery.
This is all I know, wish it works :)
Jul 16, 2010 | Acer Aspire 5315 Notebook
I have an acer aspire 5315. Don't think I've wifi.
if you're using your pc as a gateway to connect to the internet you need to make sure the pc is turned on and connected before you connect wirelessly from your laptop. alternatively you can connect directly to your wireless router from your laptop, eliminating the need to use your pc to connect
Mar 01, 2010 | Acer Aspire 5315 Notebook
My Acer Aspire 5315 wont turn on?
remove the battery then try to turn on the laptop. if this works you probably have a bad/shorted battery
Dec 08, 2009 | Acer Aspire 5315 Notebook
Acer Aspire 5315 Touch pad problem
go to the control panel, mouse configuration , and try to turn on the touch pad
Aug 30, 2009 | Acer Aspire 5315 Notebook
How to restore my acer aspire 5315 back to factory settings i have tried every thing i can think i press f8 on startup then boot logging but nothing happens HELP?
Just after pressing Power button try to press and hold FN+F10 if this does not work try FN+F11, you can also keep holding a FN and simultanuously pressing F10 or F11. This should take you to the system recovery screen then follow procedures from the screen. Another way is to activate hidden system restore partition on the hard drive if there is any, the simply reboot your computer.
Jul 20, 2009 | Acer Aspire 5315 Notebook
Acer Aspire 5315 Notebook will not power on
disconnect the battery from the laptop and only hook up the ac adaptor. Turn the laptop on and if it still cuts off after 5 seconds then reseat the memory back into its slots. Also make sure your air vents are not clogged with dirt or dust as lack or air flow can cause the laptop to shut off. If that doesn't do it then take out the hard drive and dvd drive and turn on the laptop. If the laptop still cuts off then it has to be a faulty motherboard at that point which means to much voltage is going thru and the components on the motherboard are not regulating it properly.
Jun 04, 2009 | Acer Aspire 5315 Notebook
Acer won't boot up
when any computer posts/boots up.
it goes through a sequence of initialising things before booting.
i,ve been repairing computers for around 12-15 years.
1st i,d try removing the ram ( memory ) usually underneath the laptop, behind a screw cover. Or ocassionally under the keyboard.
if 2 sticks of ram are installed, remove the battery. and 1 stick of Ram. put battery on and try to boot. if no joy with that try the other stick of ram. and replace battery-Re-boot.
If this works you have 1 stick of faulty ram or faulty ram slot on motherboard. Failing this. I suspect that the CPU has overheated, and therefore a replacement Processor should solve the problem.
Thankyou for using fixya.
Mike @ compurepair.
Apr 20, 2009 | Acer Aspire 5315 Notebook
Acer Aspire 5315 Notebook Logo
55 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
