Sunbeam Microwave, 0.9 Cu.ft - Black Logo
Posted on Nov 05, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
ReSet clock reSet to Standard time
Anonymous
Level 3:
Top Expert:
  • Master 14,553 Answers
  • Posted on Nov 06, 2012
Anonymous
Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718286
Points
48227
Consult the owner manual or if lost Google the model number with "manual" to try to locate one. You should also be able to call customer service with the model number for live help--I suspect they are getting a lot of similar calls right now.
After each use, microwave clock disappears and microwave will not work until clock is reset. The clock will not allow itself to be reset unless we reset the circuit break which was not tripped.
Sounds to me like a fault with the main circuit board. Lets say the microprocessor on the board is bad and it locks up or just doesnt display the clock or time. When you reset the breaker you are resetting the main board. and it works until the processor fails again. Sound like may need new main PC board. Timer board. Caution!! Pricey??? Check cost of board before persuing, may be more wise to replace unit. and get new full warranty
I cannot reset clock
Touch Timer/Clock pad and number 2 pad.
Enter the correct time of day by touching the numbers in sequence.
Touch Timer/Clock pad again.
Clock display keeps resetting to "0"
1. Defective controller or its power supply.
2. Broken display panel.
3. Oven needs to be reset (pull plug for a minute or two to reset).
God bless you
How do I unlock the touchpad of my Profile 2.0 Spacemaker Microwave Oven # JVM2070
calvin,
If you have access to where your microwave is plugged in, unplug it for a few minutes and then plug it back in. This will reset your contol panel. Then follow your book directions to reset the time on the clock. Hope this helps!
2helpful
When you put something in microwave and push for time it will run for about 5 seconds and fan will change tone and it won't heat anything
HELLO.
TO MAKE YOUR MICROWAVE WORK AS REQUIRED BY YOU.TAKE THE RESET STEP
4 Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the GE microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
5 Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock.
Thanks.
Our 2006 Samsung Microwave has suddenly ceased to heat anything. The clock works and the turn table goes around, but that's it. We had a couple of power outages just before this happened. Could it be...
Press the "Off/Clear' button to cancel anything on the display, and reset the microwave. This is a soft reset and will simply get you out of any program you have started. Press it when the cooking complete reminder appears on the display.
1helpful
Clock Losing Its Memory
Our oven clock does the same thing every time the power blips, but we live way out in the boonies and expect occasional problems. Do your lights blink too? Check with your neighbors to see if they have power problems. If this is a chronic situation, contact your power company to see if they can repair the situation.
3helpful
Sanyo microwave clock reset
This is the generic instructions to set the clock. I have visited the sanyo site to aquire a owners manual with no success in locating one. This being said, here are the instructions.
  1. Unplug the unit for a minute then plug unit in.
  2. Press the clock (clock/timer) button once.
  3. Using the keypad, input the time you wish to set.
  4. Press the clock (clock/timer) button once.
  5. Press the stop/clear button, Time should remain.
Hope this works, if not, let me know.
Please take the time to give this solution a fix ya rating.
clarkco
HOW DO I RESET MY GE JE1549GW MICROWAVE
Terry I am assumming that you are referring to resetting the clock. If so, push the clock button then set the time then push the clock button a second time and you should be all set.
1helpful
How do i set clock for time of day
You can download your owner's manual free here.
From the manual:
SETTING THE CLOCK - When the microwave oven is plugged into an outlet, the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been
set, the time will appear with blinking colon,
unless the oven is cooking or defrosting.
NOTES:
- To reset the present time in the display window when the oven is off, press the CLOCK button and
reset.
- If you make a mistake when setting the time, press the STOP/CLEAR button.
- To recall the actual time while the oven is cooking or defrosting, simply press the CLOCK button
and the display will show the actual time for three seconds.
We're happy to help and we appreciate your thoughtful rating of our answer.
Top Sunbeam Microwave Ovens Experts
Paul Bade
john h
Are you a Sunbeam Microwave Oven Expert? Answer questions, earn points and help others
