Question about Zanussi 32 in. DE6755 Dishwasher
Machine doesn't work.
I have a power light when power button is pushed, but no lights on the right side which shows all the functions, and the machine doesn't work. Is it a PCB problem?
  • Gerard Matthews
    Gerard Matthews Jul 02, 2018
    My dishwasher has no power no program coming on check the power on plug no switch tripped it a zanussi temppoline plus s-no 12685077
I had this exact problem. I fixed it in 20 minutes - I turned off the power to the machine then unscrewed the front panels and discovered that behind the lights/buttons on the right is a white box. Underneath that box lots of wire connect to it, and 2 of these are connected by plugs that just push in and pull out. One of mine had fallen out. I replugged it, rescrewed everything back up and it works again !
Posted on Feb 01, 2010
    President:
  • 1,462 Answers
Probably is a module fault and part is expensive. sorry!
Posted on May 22, 2007
I have a singer curvy 8763, the foot control quit working, machine will not work and all of the lights are blinking???
Reset main power. perhaps power off by unplugging. If that won't work then find the main operating buttons on the right side and push each one.
You should have a manual on this fairly new machine that will help you.
Moses
Sep 21, 2014 | Singer 8763 Curvy
Reset clean light
Did you clean the machine? When you went through the cleaning steps it should have cleared the clean light. I will tell you what to push first Remove the front cover. If the machine is operating then push and release the harvest button. When the machine completes the Harvest cycle it will stop. Push and release the OFF button. Push and release the clean button. The yellow clean light will blink and display will show C. The machine will drain the reservoir and refill it. Go into the next step when the reservoir has filled. Allow the the ice machine to circulate water for at lest 10 minutes. Normally this is when you would add your cleaning solution but i take it you have already cleaned the machine. Now push and release the Clean button again. The yellow Clean light will be on continuously and the machine will drain and refill the reservoir repeatedly to purge out the ice machine. Now Allow the drain and refill process to continue for at least 20 minutes. Now Push and release the OFF button. The clean cycle will stop and the display will show 0. Now push and release the on button. This should have cleared the yellow clean light. Now with that out of the way if it did not clear it then you will need to replace the control board. The machine will steel make ice with no problem and you just clean the machine every 6 mounts. The yellow clean light is just to remind you that it is time to clean the system. The board is quite costly.
Apr 24, 2014 | Scotsman Ice Machine, Cuber, 1930 lb....
Push button switch does not work
Sounds like a really dead machine. You have to start at the outlet, with something to see if it's working.
If the outlet is good, are any lights or indication of power on the machine working?
If no indication of power shows, a technician needs to open the machine to see what's wrong.
Nov 27, 2013 | Electrolux Washing Machines
Monitor button is stuck in out possition
Only a suggestion.
Remove power cable from socket. Place machine so switch is facing up.
Very tiny amount of thin oil place sides of switch then push in and out, might do the trick. Most liely awitch has failed requiring replacement.
Jan 28, 2013 | Dell E551c
I have a hotpoint washing machine model wt746 1400 spin speed. the display shows a single red light and twiddling dials and pushing buttons does not affect the display. The machine doesn't work at...
Unplug your washer for 10 minutes, consult your users manual while waiting, then plug it back in, Still unresponsive, contact an authorized service tech.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Nov 26, 2017 | Hotpoint Washing Machines
My LG washing machine has power but no light display and doesn't work. I washed a bathrug and when I returned the machine had power (makes a tone when the on button is pushed), but none of the...
I have a LG WM2016CW and after I washed a med. rug none of the lights on panel wwould not work but it did ding when I pushed the start button. so after reading other solutions one said something about checking the door switch so I tried washer n woulnd'nt work so I opened the door and pushed on the door switch and it started. thank you I hope this works for u...
Oct 11, 2011 | LG WM2016C
I have a kenmore Oasis that powers up but wont start
Activate the Console and Indicators Diagnostic Test Mode to check the functionality of the .
Console and Indicators Diagnostic Test Mode Activation
  1. While in standby mode, press the following button sequence within four seconds: SOIL LEVEL>WASH RINSE TEMP>SOIL LEVEL>WASH RINSE TEMP
  2. Press the START button within five seconds of "dt" showing on the display. All indicators should turn on and "88" is displayed.
  3. Press START again. The two-digit display and the status indicators turn off while all other indicators remain lit.
  4. Press START again. The two-digit display and the status indicators turn on while all other indicators remain lit.
  5. Rotate the WASH CYCLE selector back and forth. The indicators will switch on an off.
  6. Press the buttons to check the function. The indicators will switch on or off and a beeping sound will be heard when a button is pressed.
  7. Press STOP or POWER button to exit diagnostic test mode.
  8. If no indicators light up or if no beeping sound is heard when a button is pressed or if some buttons do not light up indicators when pressed, check the user interface board and its connection to the main/control board.
  • Unplug the machine.
  • Remove the three screws on the back of the console.
  • Lift the console off the cabinet.
  • The control board is located on the right side of the console viewed from the front of the machine. Disconnect the middle wiring harness connector on the right side of the control board near the pressure transducer hose.
  • Clean the connector thoroughly to ensure a good connection.
  • Reinstall the console and reconnect power.
  • Run the diagnostic test once again.
  • Replace the user interface board if it fails the test once more.
Refer to the next post if no problem is found on the user interface.
Jan 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My Saeco Vienna made me a cup of coffee this morning, but know the light won't go on. Please help.
If you push the power button and the machine will not turn on and it a newer machine there is a reset button on the side of the boiler that needs to be pushed. This will get you power again. If the machine is older than 3 years there is a thermal fuse on the side of the boiler or a reset button on the back side that you can push but if that won't solve the problem you probably need a new board or power filter.
May 18, 2009 | Saeco Vienna SuperAutomatica Coffee...
Electrical problem?
Neither the needle up/down or the LED for the stitch selector will work if the bobbin winding pin/holder is pushed to the right (meaning pushed into the winding position). If you accidentally left the winding pin/holder pushed over, you will lose the functions of both the LEAD and the needle up/down button! (Neither of these functions can work while in bobbin winding mode!)
Nov 04, 2008 | Janome 4623 Mechanical Sewing Machine
Zanussi 32 in. DE6755 Dishwasher Logo
247 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Archie Ferrarini
Archie Ferrarini
Renee Knafel-Bullock
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
