Question about Philips FWC780 Shelf System
Manual for phillips fw 3996 stereo
Cant sort out what the eco does
    Master:
  • 689 Answers
The echo effect has to do with the surround functions, You might be able to down load a manual for it, From ,Manuals Online.Com, For no charge,
Posted on Nov 05, 2012
2 Suggested Answers
SOURCE: POWER ON
yes
Posted on Jul 13, 2008
Need User Manual & Remote Control
I set up this link that will take you to download your When you get scroll down and select there, select download
http://www.manualowl.com/m/Phillips/FW-C579/Manual/163091
Feb 05, 2012 | Audio Players & Recorders
I have a philips car 400 stereo that is coming up with 'safe' on the screen (the battery went totally flat on the car) the details are as follows GM90493281 4660103...
DELCO codes are only available from the Main Dealer or Radio Decoding Service
They are not available for free from anywhere on the Internet
Sorry
Mar 10, 2011 | Philips Car Audio & Video
I am tryin to remove the factory radio from a 2000 Nissan Altima and install an aftermarket radio. but i cant seem to figure out a way to get the trim panel around the radio and HVAC module out. And i can...
  • disconnect the negative battery cable from the Altima's battery.
  • 2
    Pry up the trim panel surrounding the gear stick. The trip panel is held in place by plastic clips that will disengage when the panel is pried up. Use a flat-head screwdriver to pry up the panel. The panel doesn't need to be completely removed, just pried up enough to reveal two Phillips screws along the bottom of the radio trim panel.
  • 3
    Remove the two Phillips screws along the bottom edge of the radio trim panel, just above the gear stick. Remove the two Phillips screws from above the radio. Remove the ashtray.
  • 4
    Pry the radio trim panel loose with your fingers or a flat-head screwdriver and remove it.
  • 5
    Remove the four Phillips screws holding the radio in place. Set the screws aside for use later. Slide the radio forward and disconnect the wires from the back of the device.
  • 6
    Slide the cage included with your new stereo into your dash adapter. Slide the stereo into the cage and dash adapter.
  • 7
    Connect the wires from the dash to the back of your new stereo. All stereos have slightly different connections methods, so refer to the owner's manual accompanying your new stereo for the proper connection procedure.
  • 8
    Slide the stereo and dash adapter into the dashboard. Use the previously removed Phillips screws to mount the stereo in place. Replace the radio trim panel and gear stick trim panel. Reconnect your battery.
  • If you are putting a aftermarket stero make sure you buy a stero harness that plugs into the cars harness, on the back side of the harness you just installed will have open wires to conet to your new stero. If you cut the wires from your car to try to splice it to the new raido it can cause problems with the electrical system includeing making the transmission shift or act funny. you can pick the harness at wall-mart, car auido, best buy, or any car auido place.
  • Dec 22, 2010 | 2000 Nissan Altima
    Philips fwd573/98
    i have philips system fw v787 when i plug in i goes to eco power mode and a word NEW displayes on screen
    please help me out
    Jan 19, 2009 | Philips FWC577 CD Shelf System
    Cant get it to start
    To reset the system to "install" mode press & hold the "play/pause" button in the center of the unit until "AUTO INSTALL- PRESS PLAY" is displayed. If this doesn't work then the unit may be too hot! I see on the philips web site that this model has a temperature sensor & will shut itself off. I am in Spain too & the temperature inside right now is 30C!! You can download the manual at: http://www.p4c.philips.com/files/f/fw-m355_22/fw-m355_22_dfu_eng.pdf
    Jul 14, 2007 | Philips FWM355 CD Shelf System
    Philips FWC780 Shelf System Logo
    65 people viewed this question
    Top Philips Audio Players & Recorders Experts
    Gyula Lacz
     Grubhead
    Grubhead
    Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
