Question about Independent (MLSS52SS) Kitchen Hood
Need fan knob for independent mlss52ss kitchen hood
How do I order switch and knob. This is broken and canit turn off fan
Posted on Nov 29, 2013
Whirlpool SC8720EDB cooktop stove independent vent switch is not starting downdraft exhaust fan, but the exhaust fan works fine when left side burners were turned on
Can you get to the switch terminals and try jumping them out with a piece of insulated wire? That would tell you if the switch is defective (my suspicion). Please be careful not to touch any live terminals - only the wire insulation you use for the jumper.
Aug 02, 2017 | Whirlpool Cooktops
KitchenAid KHTU160KSS Kitchen Hood makes noise
Remove the fan and motor assembly from the hood (the fan motor will plug into the hood housing) and using an electrical motor cleaner (such as CRC electrical motor cleaner available from your local auto parts store) wash the motor and fan as completely as possible, lubricate the end bearings (sparingly) with a very light oil such as sewing machine oil, gun oil or as a last resort 3 in 1 oil. Hope this helps.
Dec 14, 2011 | KitchenAid KHTU160KSS Kitchen Hood
How do you replace?
Kitchen hood replacement can be completed easily with a family member or a friend. While you may wonder why anyone would replace a kitchen hood, the answer usually is simple. Here is how to replace a kitchen hood.
Tools Needed
  • New Range/Kitchen Hood
  • Screws
  • Screwdriver
  • Friend
  • Wiring Nuts
  • Circuit Tester
Warning: Remember that you are dealing with electricity, so stay away from water and use all safety precautions issued by the manufacturer.
Step 1 - Shut off Electricity
Remember to turn off the electrical supply to the old kitchen hood. You will need to do this via the circuit breaker box. Wait for 10 to 20 minutes and then test the wires with the circuit tester to double check that no electricity is being supplied to the kitchen hood.
Step 2 - Remove Old Hood
After you know for a fact that it is not receiving an electrical current, you can begin the process of removing the older kitchen hood. You should first take off the electrical wiring cover that is located by the light fixture. Then have your family member or friend hold up the old kitchen hood while you remove any screws or bolts from it. Once that is done, you can then freely slide it off.
Step 3 - Check Wiring
Double check that you have at least 12 inches of wiring to connect your kitchen hood to the wall. It should be noted that if you have a kitchen hood without vents, proceed to step 5 next.
Step 4 - Find the Ducts
If your new kitchen hood has vents, you will need to locate the fan or vent duct. Once you have found it, you can open up the vent hole where it will belong.
Step 5 - Wires
Open up the covering for the wiring and put the covering in a safe area for easy reach.
Step 6 - Install the New Kitchen Hood
Have your friend or family member hold up the kitchen hood and mark the areas where the screws or bolts will be. Then have them put down the kitchen hood and screw in the screws half way into the holes. After that, you can slide in the kitchen hood.
Step 7 - Route Wiring
Lightly pull the wiring through the proper holes and connect both black wires from the new kitchen hood to the black wire from the wall with a wire nut. Then connect the two white wires from the hood with the white wire from the wall, again using a wire nut. Next, connect the green wire to the green ground screw. Then place the wire covering back on.
Step 8 - Tighten Screws
Finish tightening the screws in place.
Step 9 - Test
Check to make sure the fan and light work. If it is supposed to vent outside, make sure that the air is leaving the vent with no issues. If something does not work proper, repeat steps 6 and 7 until everything works well. Remember that you will be working with electrical equipment, so follow safety measures issued by the state or the city.
Jan 29, 2011 | Kobe RA9436SQB Kitchen Hood
Need New Fan knob for Viking VWH3048
You could contat any viking dealer and they would be able to help you, or you could go online to viking.com; finally you might find a replacement knob at a hardware store like a Valu where they usually have a large assortment to choose from.
Jan 31, 2009 | Viking VWH3048 Kitchen Hood
Kitchen extractor fan
hi! most of the time this will be sticky switch normally located on the inside edge of the extactor unit behind the filter mesh!.hope his helps
Dec 20, 2008 | Imperial C2036PS1-TW Kitchen Hood
Kitchen extractor fan just started making a screeching sound and slows down and stops as if something is holding it back Not sure whats happening
the motor is going bad. soon wont work. only 2 things to do either 1 replace motor. 2 replace hood. motora are usually cheap. $10-50 ...
Nov 23, 2008 | Fat extraction holder Kitchen Hood
Fan Switch
You need to take the unit down to access the switchs. The unit should be mounted to the top of the cabinet by wood screws or nuts/bolts that you'll need to remove. Before starting any project having to do with appliances, always remember to turn off the power to that appliance by switching off the circuit breaker in your house panel. Once you have removed the screws, the unit will lower and you will see the cover that you'll need to remove and it will expose the switches. Goos luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Viking VWH3048 Kitchen Hood
Independent (MLSS52SS) Kitchen Hood Logo
196 people viewed this question
Top Independent Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you an Independent Kitchen Range Expert? Answer questions, earn points and help others
