I have a Insignia NS-LCD26A and all of a sudden it has no display or sound. The green power light comes on and I have to hold the power button for 5 second to turn it off?
I have checked all of the voltages from the power supply and they all seem good and also checked then at the main board. I read a blog that talked about "re-balling" the video chip and I have done this process several time successfully on laptop motherboards so I tried it. It worked! but only from a few days... so I tried it again... same thing happened worked for a few days then dead again... I am only guessing but it seems to be the video chip so if the main board is replaced it should correct the issue?? Anyone have any thiughts or have seen this behavior before?? Thanks!!
  • 1,238 Answers
Probably yes!!!! it will fix the issue.
Posted on Nov 06, 2012
  • 41 Answers
SOURCE: Vizio 42 in L42HDTV10A no power no lights no nothing
Yeah if you don't have any power at all, no lights or anything its the power supply.
Posted on Oct 08, 2008
  • 1779 Answers
SOURCE: insignia lcdtv32 poewr on but no picture
You need to check the 12 or 24v source coming from the power supply to the inverter board, that's the board usually to the left and rather tall. Get your meter set, then turn the set on and see what happens, if the voltage comes up and then shuts down, you'll need to pull the plug for the inverter and measure the voltage again. If it stays up you have a bad converter board, if not then it's in the power supply, that's good old fashion trouble shooting from there on.
Posted on Feb 26, 2009
skotkolr
  • 558 Answers
SOURCE: Insignia TV model NS-LCD26A power up problems
you are correct power pack has bad capacitors, doing what you did may have damaged other components in the power pack, or main video board. let me know what you want to do.
Posted on Apr 05, 2009
  • 65 Answers
SOURCE: I have the same issue with a Insignia NS-LCD26A
I would suggest trying to repair the board first before buying a new one (unless you get a great deal on a replacement one). Its possible it was something simple like a fuse or busted capacitors.
Open up the TV and take out the power board and check it for any busted capacitors. Also check the fuse(s) with a multimeter. Try replacing everything with a soldering iron (shouldn't cost more than $10 for a fuse and capacitors). Try and see if it makes a difference. ONLY DO THIS IF YOU ARE CONFIDENT and SAFE with that type of work.
Posted on Aug 15, 2009
  • 8457 Answers
SOURCE: Replaced main board in Insignia NS-LCD19 TV and
Check all connections first,try agian.After that Change the LCD Inverter board might also dead.The inverter help backlight to screen to come on.
Posted on Jan 13, 2010
I have a insignia.MODEL NS-LCD26A. SERIAL #2881LC26HA37H05804. WHEN I TURN IT ON THE SCREEN IS JUST WHITE. WHAT IS WRONG?AND WHAT SHOULD I DO?
It sounds that the main digital board to this set is not functioning. There are many reasons for this, and is not a user repairable fault. Contact any service technician.
Oct 24, 2013 | Televison & Video
I have a Insignia 32 inch LCD TV Model number NS-LCD32. It recently started displaying no inputs. The backlight comes on but no inputs/ no sound. Green lines display if you press the menu,input, channel...
The first troubleshooting step would be to measure all the voltages from the power supply to the other circuits boards specially the 5 volts going to the main board. If you have the following: Insignia 6HA0112010 Power Supply, check FU502 for open conditions.
If all the voltages appear normal, then the main board should be replace since is hard to find individual components for a component level repair.
Let me know if you need further assistance.
Aug 21, 2010 | Insignia 32" 720p Flat-Panel LCD HDTV
Need base for Insignia NS-LCD26A
Parts for Insignia TVs can be ordered by visiting BestBuy.partsearch.com or calling 1-888-237-8289.
Apr 07, 2010 | Insignia LCDTV26 26 in. Television
INSIGNIA NS-LCD26A Model tv powers on with rainbow vertical line/blurry/cloudy/greyish etc. The sound Comes, SOUND OK.Capacitors on power module look fine,no bulging, but not checked with multimeter. Any...
if you check with multimeter, you know all worked fine, you need code programing of the tv, this code is for reconfiguring your tv, search by model, by device and brand, oh you need the remote control original, for solve this problem...
because the problem is programing electronic, the tv have a cpu and have a program, who can solve is expert electronic....
Mar 07, 2010 | Insignia LCDTV26 26 in. Television
The audio went out on my insignia NS-LCD26A. It
It's likely that the TV will require service. You may take the TV to the retailer of purchase to arrange for repairs.
Sep 23, 2009 | Insignia LCDTV26 26 in. Television
Insignia (ns-lcd26a) picture problems
ns-lcd26a
Hi,I fixed my here's issues i had and the fix i did..
ns-lcd26a
Every now and then i would get snow and a pink picture.
Then tv stop turning on .
To fix i seen on main board capacitor cp25 and cp28 near the heat sink was bad
They were both 470uf 35v...
on the power board i seen c531 47uf 50v was bad.
i also heated up the heat sink on the main board to resit the chip ,,
and tv now works
I didnt bother putting the huge shield back on main board i figure it was a issue to over heating the cpu instead take the hit to the brain from the fcc radio wave lol
First do the 3 caps and see if it works if not then do the blow dryer to the heat sink on main board
Aug 20, 2009 | Televison & Video
Mar 29, 2009 | Insignia LCDTV26 26 in. Television
Remote broke
The input button or volumn arrow key might work.
Aug 10, 2008 | Insignia IS-LCDTV32 32 in. Television
Insignia ns-lcd15
The problem i have seen is the main surface mount IC ( the one with the heat sink) runs hot and the connections go bad from expanding. poor design. somtimes pressing down on the heat sink while its on will yield a picture and then goes out.
Feb 12, 2008 | Televison & Video
Televison & Video Logo
130 people viewed this question
Top Televison & Video Experts
Electro Med Services...
