Question about Ugly stick Shakespeare 176 18 Marine Big Stick Antenna
Shakspere big stick wont recieve when i hook up the cable
    Top Expert:
  • 14,553 Answers
Check the swrs to see if shorted---check cable ends etc.
Posted on Nov 06, 2012
Where do springs hook on carburetor model 12s907-1411-b1?
ok, if this is the one you have? pay attention. their should be a small metal hook with a loop on top, hook the Z shaped end into the butterfly of the carb. the other end goes to the gov,plastic lever, sticking out..the bigger longer spring hooks to the speed ajustment lever hook the other end in the big loop on the hook. the small spring, hooks to a flat metal post sticking up. the other end hooks into the big loop as well.to keep everything from bouncing around
May 10, 2014 | Mtd 22" Yard Machine Push Mower
Big stick cb antenna wont recieve
Have the radio tested first on a dummy load--if ok check the connector on the antenna--Big Stick antennas if old can break inside but a SWR check should reveal if a open antenna or a shorted one----you with a ohm meter should get a reading across the center pin to the threaded part of something like 50 ohms---either the antenna, coax or even the radio....
Nov 05, 2012 | Radio Communications
I have a pioneer djm mixer 400,I hooked it up to 2cdj mk1002. I want to run them through my pioneer reciever.which is a vsx 1020.im having a problem.IT works okay,if i run the cd player directly to cd...
If your CD player works hooked up to the DJ board, then try hooking the line out of the board into a auxiliary in or line in in or record in on your receiver using the appropriate cables.Try the CD in first and if there is too much signal then use the CD/Tape in. You need to match the output signal of your board to the input signal of your amp. Hope this helps.
Oct 22, 2010 | Pioneer DJm 400 Professional DJ Mixer
I have a vr-405 5.1 channels reciever, I have it hooked to nanlog out on tv per tv manual,tv speaker r off,there is a dvd/vcr hooked into video 1 and it works on tv speaker, where do i hook into the...
try to be a little more clear on what you are trying to do.do you have it connected to hdtv and cable box if so run hdmi cable from cable box to tv and then run optical cable from reciever to cable box you then must turn reciever to cd/dvd to listen to it leave reciever in auto mode go into cable box menu under audio and select dolby digital
Feb 21, 2009 | Kenwood VR-405 Receiver
Hooking up a tv to a surround sound and to a dig cable box
Ok, hook the cable box up to the reciever audio/video, find the monitor out from the reciever and plug it in to the TV input. sound will come from the reciever this way onto your speakers and the Tv will act as a monitor
Feb 02, 2009 | Audio Players & Recorders
CABLE AND SATRELLITE TOGETHER
hook up the cable box to component # 1 or hdmi 1 and the satelite reciever to component # 2. i'm not sure if this model has 2 hdmi inputs,but you can also hook the satelite reciever to hdmi 2 if it does.
Jan 18, 2009 | Samsung HL-S6187W 61 in. HDTV
Connecting up
Easy set up, Hook up all the components to the back of the TV normally and then use a stereo cable from the tv to your reciever.
Usually on the tv it says audio out or variable audio out, this will go straight to your reciever on one input allowing all devices on your tv to be hooked through your reciever on one cable and the sound will come from the tv and reciever at the same time or you can turn the audio off on the tv., you can also hook up any optical audio outs from your devices to your reciever as well. This will allow for surround sound to your reciever.
Dec 21, 2007 | Televison & Video
No audio from Samsung DTB-H260F
I have a sr605 Onkyo receiver and just hooked it up to a new Mitsubishi 73" and I could not get the picture to work, sound did though. Here is the problem the Onkyo is HDMI 1.3 but TV calls for HDMI 1.3a. There is a big difference between the 2 and the Onkyo will not work with TV. The newer model TV'S say in the manual Category 2 V 1.3a. You need to make sure that all your parts are compatable. It makes a big difference.
Dec 05, 2007 | Mitsubishi HD-6000 DTV Receiver / Video...
Tv hook up!?
First you must be on the audio outs in back of tv set. then you must go into menu, if not already and change audio to varible output, or external speakers or just what ever yours say in menu. then you must turn receiver to the right inputs to get sound. Hope this helps.
Sep 21, 2007 | Panasonic SA-HE100 Receiver
Ugly stick Shakespeare 176 18 Marine Big Stick Antenna Logo
37 people viewed this question
Top Ugly stick Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you an Ugly stick Radio Communication Expert? Answer questions, earn points and help others
