Question about Epson Workforce 610 All-In-One InkJet Printer
Do I really need a need printer?
I have an error message telling me to turn off the power and turn it back on or call Epson. Epson asked me 2 questions and then told me i needed a new one. It is out of warranty at just 2 years and 2 months old and is only used occasionally for personal use. I can't believe that I need to purchase a new one. Any suggestions? The website and manual do not list this in their list of error message in the FAQ's.
  • Tina Woodruff Nov 14, 2012
    That should say DO I REALLY NEED A NEW PRINTER? Does anyone have any ideas on how to posible fix this?
  • 685 Answers
Can you give me the error message your seeing so i can help you
Posted on May 28, 2013
SOURCE: Epson CX9400 Fax has an error statement
when you open your cover and see the cartdredes lift them up and place them in the center while holding down the piece of metal with the bar code on it it gets cauth up there all the time that is what it is hitting when you turn it on and it makes a metalic sounding thud.
Posted on Sep 13, 2008
diddydaveh
  • 154 Answers
SOURCE: Epson Stylus CX6400 not printing
Hi, below the belt that pulls the head from left to right is a 'bail bar' which the head moves along. Put a little light oiul on the bar, check for any bits of paper jammed in the mechanism which may be obstrucring the print head.
Also check that the bushes which support the print head haven't been dislodged. You can tell because there will be a strange looking doughnut type thing sitting and looking lost on the bail bar. you can usually just push this back into place on the side of the print head.
Posted on Dec 06, 2008
SOURCE: Epson R320 printer will not recognize any of the ink cartridges
I tried two things of which one solved the problem. I am not sure which. Secondly, I have an R260 printer which is a less featured member of the printer family uses Claria inks like R360 and R380. I called Epson and they simply sent me replacement cartridges for the two black ink cartridges with which I had a problem. My printer did not recognize these new cartridges either. I noticed that both the ones I bought and the replacement ones have a slot hole near the green chip on the cartridge. The empty cartridge did not have this slot. They just had some circular depressions. So, I put a piece of masking tape over the slot and tried again but still no luck. However, when I removed the cartridge, this time a small piece popped out. This piece connects to pins on both sides. So, it is obviously an interface between the cartridge and the printer. I pressed this piece back in, replaced the cartridge with the tape on it back it and, voila, it works. Most likely this interface piece was loose and simply pressing on the cartridge didn't get it in far enough or who knows. You maybe able to take thiis piece out and replace it or merely push down on it with a pen but first, flash a light on it first to see if it is not sitting awkwardly.
Posted on Apr 13, 2009
cns assoc
  • 677 Answers
SOURCE: My printer will not recognise non epson cartridges
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!! How you were able to use generic is amazing. I was not able to do that!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
TRYING PURCHASING GENUINE, and see what happens? This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Jan 31, 2010
  • 5105 Answers
SOURCE: My Epson R265 is sending a message saying that it
If the lights are flashing alternately and slowly (with the power light off), then the waste ink absorbers are full.
The pads are near the bottom of the printer and can either be replaced (call the service department for the parts) or rinsed clean under running water. The hard part is usually extracting them (you need to disassemble the printer most of the time). Then (if reusing the pads, wait until they are dry) reinstall them and reset the waste ink counter. The reset requires a program such as the one available here: http://inkjetprinterhelp.us/epsonSSC.html . Do not run this utility until the pads are replaced, the ink will smear everywhere. Epson used to have a link for their own reset tool but I do not see it for this printer.
However, the printer is designed that under normally usage, the waste ink absorber will be full at the expected end of life of the printer. Thus additional failures may be coming.
I hope this helps.
Posted on May 04, 2010
First time changing ink unit it 2 weeks old getting error message 0x9A. Can't get past it. Powered off and on. Unplugged and powered on again, reinstalled ink cartridges...nothing.
If your printer is only 2 weeks old, I suggest calling Epson, and having them replace your printer. They will send you a new one, and you send the old one back.
May 26, 2016 | Epson Expression Premium XP 620 Wireless
"Printer error"
Try unplugging cable for ten minutes, did you reinstall drivers already?
Sep 09, 2008 | Epson Stylus CX5800F All-In-One InkJet...
Changing ink reservor on Epson rx620
Are you often to used refilled cartridge? That's possible your waste tank has been fulled. Hold down the 'Stop' AND the 'B&W' button while powering up. This seems to clear the error message and restore the printer. Worked for me--dunno how long it will last tho!
Please rate me SOLVED.
Regards.
Nov 20, 2007 | Epson RX620 All-In-One InkJet Photo...
Setup/configuration issue, error message, scanner error 0x10. How do I fix this?
unplug power at the wall outlet
wait 5 minutes
press and hold the power/on button for 60+ seconds
keep holding while plugging back in, and for another 60 seconds after, then release if that doesnt work it is an internal fault which would require repairs or exchange in your case
Jul 19, 2015 | Epson Expression Home XP-420 Wireless...
Epson t60 general error
For a lot of Epson there is a remedy:
1. Turn off the printer.
2. Press and hold both 'stop' 'maintenance' and 'power' buttons for about 10 seconds.
A message will appear on the screen.
3. Power off and back on for reset.
Jul 28, 2011 | Office Equipment & Supplies
How to fix a sysytem error message on a epson photo r320 printer. my printer is displaying a system error message and tells me to hold the stop and power button for 7 seconds. But, after I do this and...
The Solution is simple: Unplug your printer then remove all the catridges then turn it on. Then the printer will display error indicating no catridges then put back the catridges then it will automatically reset your printer thats all folks...Please comment if it works for u...
Jul 17, 2010 | Epson Stylus Photo R320 InkJet Printer
Epson printer r300 error code needs servicing
Is the waste pad full ?
If the waste pad is actually full and ink is about to overflow, then you need to install a waste container. You can see the waste pad by opening the access panel on the back of the printer.
1)Press and hold “Stop”, “Maintenance”, and “Power” buttons for about 10 seconds. A message will come on the screen saying counter is reset and to turn the printer off. The R200 and others don’t have a screen so just wait until the 10 seconds is up.
2)Turn the printer off, unplug the power cord. Wait about 1 minute and power the printer back up. The counter will be reset. That’s all there is to the reset procedure.
Mar 31, 2010 | Epson Office Equipment & Supplies
RX595 Printer error has occurred
try to turn off the printer for 5 min. and unplug the power, and then turn it on again, this worked for me, and apparently this error associated with all Epson printers,
mine is 8300
Apr 07, 2009 | Epson Stylus CX9400 Photo Printer
For epson stylus photo r300
Hi Anna,
After doing some searching, this was the best I could come up with:
Turn off printer
Press and hold 'stop' 'maintenance' and 'power' buttons for about 10 seconds. A message will appear on the screen. power off and back on for reset
Allegedly, this is a pre-set maintenance routine epson implements as a service reminder...though I could not confirm this one way or another. I hope this works for you, as the epson website seemed to be utterly useless in finding a suitable resolution.
Good Luck,
Jem
Jan 04, 2009 | Epson Stylus Photo R300 InkJet Printer
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson Workforce 610 All-In-One InkJet Printer Logo
109 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
