Magnavox dvd player model MDV2100/F7 november 2011 will not play dvds
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
If no disc or cannot read is the issue it is either a dirty or bad optical pickup in the player.
Posted on Nov 06, 2012
  • 814 Answers
SOURCE: dvd player will not reconize a dvd when trying to play
Try cleaning the dvd compartment of all dust and debris with a can of compressed air. Check and make sure all the dust and debris is cleared of the laser transport and lens. Use cotton swabs and small amount of isopropyl alcohol to clean off the laser lens and tracks and gears of the transport . Use a cotton swab with a small amount of alcohol on the tip to clean the laser lens. Rub the swab gently across the lens, until it appear bright and shines. Use the other side of the swab to remove any excess moisture from the lens. Use cotton swabs to clean the rails and gear of transport. Applie small amounts of alcohol to the tips to loosen caked on dust or dirt. Use compressed air again to clear the dust and debris from transport area. After the through cleaning. Try the player again, using a dvd to see if the operation returns to normal. If not, try resetting the dvd player to factory setting. You can do this using the on screen menu to go into the settings. Use the remote control and press the settings button. Use the up and down arrows to highlight the preferences section and press enter. Once in the sub-menu use the up and down arrows to highlight the default function and press enter. This will have reset the dvd player to the factory settings. Now try using a dvd to test the player to see if it operates normally. If it does not play normally, you may have a proplem with the spindel, check it to make sure its is making good contact with motor, if it appears loose, applie a drop of super glue to snug up the grip. After it dries completely. Test the player again with a dvd. If the unit still fails to operate normally, you may be having problems with either the drive motor or the power supply circuits. For these problems you need to contact a service center. They will have all the service information to troubleshoot these problems properly. You can call Phillips customer support at this telephone number 1-888-744-5477. They will be able to tell you how to get the dvd player tested and serviced. I hope this information helps you with your problem.
Posted on Jun 01, 2009
SOURCE: LG DVD player LG276
I picked up a LG DV276 DVD Player here in Australia but I am from the United States so I own region 1 DVDs. I unlocked my new player by instead 1. Open the tray. 2. Press 0 0 0 0 on the remote and a Menu will appear. 3. Press 0 for region free. 4. Press pause and power off.
I can play everything now, Aussie and US DVDs. Thanks LJ66.
Posted on Jan 01, 2008
SOURCE: recorded dvds wont play in other dvd players
You have to finalize the disc. if the disc goes to the end it will finalize the disc automatically. If there is some part of the disc not used you have to do it yourself. IN DVD MODE PRESS SETUP, THEN DISC EDIT, THEN FINALIZE. FINALLY PRESS YES. That should do it.
Posted on Sep 03, 2008
notsomot
  • 67 Answers
SOURCE: unlock code to unlock dvd player to play dvds from all regions
0082 0015 0089 0004 00F2 0033 0017 0010 0091 0013
make sure you have the disc draw open and enter the above code via your remote.
let me know if it works
Posted on Jan 10, 2009
SOURCE: Samsung P480 dvd player- To Play all region dvds
how can I play *.mp4 files in samsung dvd player model no P480?
Posted on May 17, 2009
I have a Emerson model LC320EM3F-A TV style ME2A1236181115. The model number for the Magnavox DVD Player is MDV2100/F7. How do I get it to work?
usually plug the proper wires from the DVD player into the proper input jacks on TV then select the proper input to the TV thru the menu
May 04, 2015 | Emerson Televison & Video
How do I connect a Emerson TV to a Magnavox DVD?
You will need either an S-Video connector and two RCA connectors, or three RCA connectors. Use either the S-video connector or one RCA connector to connect the video, and use the two RCA connectors to connect LEFT and RIGHT audio. Done.
May 04, 2015 | Magnavox Televison & Video
Magnavox mdv3000f7 does clearing my eeprom enable me to watch dvds of all region
Try it and get back to us lol. Do it and if it doesn't do what you want you just unplug dvd player for a hour and it will reset.
Apr 25, 2014 | Magnavox MDV3000/F7 Player
Dvd player wont power on
It probably has an issue with the Power Supply, however, it's not worth repairing. Sorry.
Jan 31, 2014 | Magnavox Funai Mdv2100/f7 Dvd Player...
Region Error Message on Magnavox Mdv2100 DvD Player
You maybe able to get a region free code for your player from these WEB sites.
Unlock DVD Players - Region Free Code
www.dvdexploder.com/ www.download-info.com/dvd/index_new.htm
Feb 22, 2013 | Magnavox Televison & Video
Magnavox Mdv2100 doesnt play
That's a probable drive failure
Jan 05, 2013 | Magnavox Mdv2100 DVD Player
Region code
Download the service manual to this set from internet. It will have all details. Most of the service manual sites will be paid ones.
Apr 21, 2012 | Magnavox Televison & Video
My magnavox ty / dvd player model number 32md359b/f7 keeps ejecting dvds . anybody have any ideas???
Yes the processor has some garbage in it and it you unplug the set from the wall for 40Min., it will start working correctly.
Mar 09, 2011 | SNK Magnavox 32MD357B_37 32 in. LCD...
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
Electro Med Services...
